Who uses a torque wrench for spark plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Jul 19, 2021.
  1. Jul 19, 2021 at 1:22 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ll start off by say in this is NOT a question of should you?
    The question is - DO YOU?
    I personally have never used one when installing plugs.
    And don’t even own a Wrench that has a small enough setting for them.
    (Actually, I do but don’t trust it)
    My buddy has a Ford F-150 that has blown 2 plugs right out of the head.
    He was a mechanic and engine builder, so he knows what he’s doing.
    It was a bad design on the 4.6/5.4 where too little threads were used for the aluminum heads.
    Anyways, he does recommend using a TQ Wrench on those engines for precautionary reasons.
    Until now, I never gave it much thought?
    And let’s not turn this in to a Ford bashing thread.
    All manufacturers make mistakes and have design flaws.
    Even I owned a Ford Lightening with 5.4 and Supercharged.
    I did change the plugs, didn’t use a wrench, and “got lucky” I guess?
    04TacoRunner and blu92in99 like this.
  2. Jul 19, 2021 at 1:24 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I do.
    tarbal255 and TnShooter[OP] like this.
  3. Jul 19, 2021 at 1:25 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    yeah those 3v fords were bad news lmao.
    i had to extract all 8 out my dads 5.4, fun time.
    12TRDTacoma and TnShooter[OP] like this.
  4. Jul 19, 2021 at 1:25 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Bout wrist tight ought to do it.
  5. Jul 19, 2021 at 1:27 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Never have.
    I start the plug by hand with the plug on the extension. Add ratchet, turn until gasket contact, then add 1/4 turn. Done.
  6. Jul 19, 2021 at 1:27 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I don't use a torque wrench, because I use anti-seize on the threads which invalidates the FSM torque value. For new plugs I do half-turn with the ratchet handle past hand tight. Did this on a couple of 2nd gens, my Subaru, and yearly on my lawn mower (Honda engine, aluminum head).
  7. Jul 19, 2021 at 1:34 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Installing spark plugs in aluminum heads? I do use a torque wrench.
    Installing spark plugs in iron heads? I do not use a torque wrench.
  8. Jul 19, 2021 at 1:42 PM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Thats a whole separate argument I've seen on forums. whether to use anti-seize or not. NGK actually plainly says not to, as all their plugs have a chromium plating. Supposedly it can also cause grounding issues and some other problems. I've never seen any of that, but I trust the guys making them. I'm sure you won't have any problems either.
    Those Ford Triton heads were terrible. I saw tons of blown out spark plugs when I was an automotive machinist. The problem was so bad that a number of companies actually made tools to replace/repair the threads.
    To answer your question, I don't use a torque wrench. I run them in by hand with the extension, then tighten until I can kinda feel the crush washer compress.
    JGO, 12TRDTacoma, Larzzzz and 2 others like this.
  9. Jul 19, 2021 at 1:56 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    NGK does this to avoid confusing people. The torque specs will be different for dry- and lubricated threads. This is true for most threaded joints. The FSM torque was intended for dry threads. Applying anti-seize and torquing to FSM spec results in overtightening. However, tightening to an angle is immune to these friction coeff changes caused by lubricants.
    In the 1GR, removing the factory plugs (which were installed dry) feels really rough with grinding sounds after just 3 years. I wonder how it would be after 5-6 years.
    Put it another way - almost ALL the bolts on the truck were manufactured with some form of coating to guard against corrosion. Yet rusted and stuck bolts still occur often. "The guys making them" don't care for these inconveniences once the part is past warranty.
    Torspd likes this.
  10. Jul 19, 2021 at 1:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    Me too. Then another 1/4 uggs dugga. Gently.
    TnShooter[OP] likes this.
  11. Jul 19, 2021 at 1:59 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Torque wrench always.
    I've never used antiseize on a spark plug. Denso and NGK say "do not coat the screw thread with lubricant".
    blu92in99 and TnShooter[OP] like this.
  12. Jul 19, 2021 at 2:03 PM
    TnShooter
    Deogee
    STOCK
    I figured the Anti-seize topic would arise.
    I’ll add that, I almost always use it on vehicles not matter what the head material is made of.
    Never have used it on my small engine equipment.
    And when I do use it, it’s a LIGHT coat on the thread.
    In the grooves is fine , on top of the threads is too much.
  13. Jul 19, 2021 at 2:05 PM
    Knute
    FWIW......I've always used the copper based anti-seize on sparkplugs.
    Learned a hard lesson with a frozen plug. Since then, just a light track on one side of the threads is sufficient. No need to Rembrandt the things. The extra just rolls up under the gasket and turns into a ring shaped blob of goo around the plug.
    wi_taco and TnShooter[OP] like this.
  14. Jul 19, 2021 at 2:28 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    I respectfully disagree. NGK is not the only mfr who says this. And coatings have come a LONG way since our trucks were new. Ive tested many different coating in engines (main bearings, piston crowns, piston skirts, valve faces, cylinder head chambers, etc etc) and they make a huge difference. I also see the amazing technology available in coatings for carbide endmills every day. I have a 12mm endmill running in a part I programmed in which tool life was increased from 2 hours to 5 hours with nothing more than a coating. That's a long time when it comes to roughing titanium. I've stopped using antiseize on plated sparkplugs and haven't seen any issues. Just sharing my thoughts on the matter.
  15. Jul 19, 2021 at 2:40 PM
    coopcooper
    alberta canada
    I'm on the anti seize train, first time i did my plugs i thought i was going to snap them clean off in the head. Second time around they came out like butter. i dont care what "coating" they use it sucks.
    wi_taco, winkel and Naveronski like this.
  16. Jul 19, 2021 at 2:43 PM
    TnShooter
    Deogee
    STOCK
    Denso says “reduce TQ by 30%”
    I didn’t use a wrench, and did them the same as I always do.
    Don’t have the slightest of an idea what the TQ I applied to them was?
    I might not use any next time, see how it goes?
    I don’t know though?
    At the risk of being “bashed” - I’ll say that the 30k replacement interval probably isn’t something I adhere to. (But it might be:D) Mine have been in there “a while”. :eek: And that’s all I’m saying about that:argue:
    ToyoTaco25 likes this.
  17. Jul 19, 2021 at 2:50 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    :notsure: I've never had a problem and I install them dry in everything. But I haven't always. Only since they've began plating them. But hey, if anti-seize is working for you, I'm not judging, just adding to the discussion.
  18. Jul 19, 2021 at 4:58 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Being an old phart, I've never used a torque wrench on plugs. I have developed a feel for the washer crushing over the years. So far so good.
  19. Jul 19, 2021 at 5:19 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I use a torque wrench and I use anti seize. I don't use a lot and I reduce the torque as recommended.
    wi_taco likes this.
  20. Jul 19, 2021 at 5:20 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Steel plugs in aluminum heads - you bet!
    wi_taco likes this.
