Who here runs 285/75R17?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dbbowen2, Apr 12, 2019.
  1. Apr 12, 2019 at 10:13 AM
    dbbowen2
    dbbowen2 [OP] Former Rock Crawler.
    TN
    2017 TRD OR Taco/2001 Land Cruiser/ 1976 FJ40
    too many to list
    Looking for insight from anyone who runs 285/75 R17. NOT 285/70-17. NOT 285/75-16.
    Trying to see if the 34 inch tire would be worth it. Not able to find much on this size. Thinking of 3 inch lift, Sema wheels, and trying to figure out what trimming I would need to do. CMC, pinch welds, etc.
    Thanks!
    ChristianBruhhh likes this.
  2. Apr 12, 2019 at 10:42 AM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Falken Wildpeaks & I believe BFG K02's come in that size. Just a tad more meaty & will surely need CMC & trimming
    I don't have em but others on here have posted on them tho
  3. Apr 12, 2019 at 10:45 AM
    dbbowen2
    TN
    too many to list
    I keep finding 2nd gens with them, but haven’t found any 3rd gens with them. Hoping to go with 3 inch fox lift and trying to see how much trimming is required. I’d rather not trim the fenders and flares. Going with cooper st maxx
  4. Apr 12, 2019 at 10:53 AM
    MrBrooks
    Midwest
    Yea a lotta 2nd Gens with HUGE tires but most of the wheel is sticking out the side of the truck.
    That lift should do the trick but the main thing will be wheel choice of offset & backspacing. Tons of info on here & hopefully one of them guys will chime in here...
  5. Apr 12, 2019 at 10:54 AM
    dbbowen2
    TN
    too many to list
    Hope so too. The wheels I’m using are 17x7 with 4mm offset
  6. Apr 12, 2019 at 11:09 AM
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    waterlogged77 likes this.
  7. Apr 12, 2019 at 11:14 AM
    dbbowen2
    TN
    too many to list
    Geeze, my googling skills are usually pretty good too... so Im going with Sema wheels 17x7 4mm offset, and Camburg UCAs. Your post has made me feel A LOT better about this. Already dont have mudflaps, Planned on molding the fender liner with heat and CMC. Hell yeah man!
    So since youre running the 34s, did you have to re gear? I had 35s on a 22re 4cyl 4runner back in the day and regeared to 5.29, and had 315s on my 80 series and regeared to 4.88. Kinda hoping I dont have to regear the taco with the newer V6 motor. Kinda the whole reason im not trying to go 315 to be honest, that and fender cutting
  8. Apr 12, 2019 at 11:26 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    At 33's, the truck already feel sluggish but still ok. Main reason I keep a smaller, lighter spare set.
  9. Apr 12, 2019 at 11:29 AM
    dbbowen2
    TN
    too many to list
    I gotcha. Its looking like 4-5* of caster is the ticket with the cmc to not have it rub in that area with the 34 inch tire
  10. Apr 12, 2019 at 11:37 AM
    KanPanic
    State of Jefferson
    2018 OR
    5.29’s and a Harrop go in next week. But I am AT and do a fair amount of mountain driving.
    Yep negative offset wheels will rub more too. I have zero offset so you should be less than me. I might bend (not hammer) my pinch weld. Still need to see how much it rubs stuffed and cranked.
  11. Apr 12, 2019 at 11:43 AM
    dbbowen2
    TN
    too many to list
    Nice I am AT as well, my first AT truck lol, well if you dont count the 80 series. Going to give it a go with the 285/75, sema wheels with 4 degrees offset, and stock gearing. I dont have any other weight on the vehicle.
  12. Apr 12, 2019 at 11:44 AM
    moosedrool52
    moosedrool52 New Member
    2016 tacoma trd
    I am running the Falcon wildpeak 285/75 17s on my 3rd gen. i have the cab mount and pinch seam done with the icon stage 5 kit with ome heavy dutys 3 inch leafs in the rear. should probably also mention my truck is a 6 speed manual.
    jachal and Tachord like this.
  13. Apr 12, 2019 at 11:46 AM
    Black1Tacoma
    Black1Tacoma #TRUKTOY
    Carlsbad
    2017 Black Tacoma TRD OffRoad 4x4
    I run sema rims 285/70/17 KO2 with a 2.5 level Bilstein 5100 in front and stock Bilstein in rear and an AAL. No rub at all. I also use thinner mud flaps.
  14. Apr 12, 2019 at 12:35 PM
    dbbowen2
    TN
    too many to list
    Great! This thread is making me feel much better. I think I’m going to go fox 2.5 front and resi rear with cam burg UCAs and a full allpro leaf pack in the rear.
    Those wheels just look soooo good
  15. Apr 25, 2019 at 9:50 AM
    Domane
    Domane Well-Known Member
    North Vancouver
    2017 Barcelona Red Tacoma TRD Sport
    Did you do a CMC with that set up?
  16. Apr 25, 2019 at 9:57 AM
    Black1Tacoma
    Carlsbad
    CMC? Sorry
    If that is cut up the wheel-well ...no not modification was needed to not rub
  17. Apr 25, 2019 at 10:06 AM
    dbbowen2
    TN
    too many to list
    Hey yall, it looks like im going to be adding regearing to 4.88s to the equation so trying to cut costs. Looks like Fox coilovers and shocks are on the cutting floor.
    Can anyone confirm that this setup would work with the 285/75/17 setup?
    -Bilstein 6112 Front set at 2 inches
    -Bilstein 5160 Rear
    -Allpro leaf pack
    -Camburg UCA
    Of course I am going to be doing an aggressive CMC and heat mold the fender liners. Im also going to shoot for 4 degrees of caster on the alignment. Just wanted to be sure this setup would work.
    Thanks!
  18. Apr 25, 2019 at 10:07 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    "Cab Mount Chop"
  19. Apr 25, 2019 at 10:55 AM
    Jetboy818
    Jetboy818 Well-Known Member
    Lax
    2019 Cement D-Cab Tacoma Trd Off Road 4x4 M/T
    285/75/17 Nittos
    24A74D6A-5833-43D0-9DFF-162931880ADE.jpg 03AB6FCF-68A9-4B0E-912E-2981F3C21067.jpg
    Mlofthou, Taco#50, chungish and 21 others like this.
  20. Apr 25, 2019 at 11:15 AM
    dbbowen2
    TN
    too many to list
    Hell yeah man! whats your suspension set up? Did you re gear?
    sweatytaco69 likes this.
