Who has tire chain recommendations?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gman2431, Nov 1, 2020.
  1. Nov 1, 2020 at 1:41 PM
    gman2431
    gman2431 [OP] Well-Known Member
    With it blowing snow here in michigan I cant but help thinking ahead for the winter...
    I've been stuck in some bad situations at boat ramps, and also on two tracks after big storms here, and want to have something for it.
    So those of you with chains whats a good brand? Are they all the same and find a deal? I got 17in rims on my sport so I assume something that says it fits will fit? Or am I wrong and need vehicle specific?
    Thanks!
  2. Nov 1, 2020 at 2:19 PM
    6300'asl
    6300'asl Member
    2020 dcsb sr5
    2-1 level 265/75/16 Rb20 running boards Weathertech vent visors Trifold cover
    I have been looking at these. Have never used chains before, but think I will get them for the taco vs tundra due to price. Not a huge need for them here, maybe 4-5 times a year for short distances.
    gman2431[OP] likes this.
  3. Nov 1, 2020 at 3:38 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    If you've never run chains before, you have a bit to learn.
    See:
    - https://www.youtube.com/watch?v=yWdUWUfVBZE
    - https://www.tirebuyer.com/education/tire-chains
    - https://www.autonationdrive.com/blog/2019/november/18/essential-auto-101-when-to-use-snow-chains.htm
    If you have, then you should already know most of the do's & don'ts.
    While I don't live in the mountains where heavy snow occurs, if I were to consider it I'd be most concerned about clearance between the tire and the inside & outside fenders. I use them on my tractor, but only when it's really icy or when there's a serious coating of heavy wet snow. Comparing a tractor to a Taco is not necessarily valid except for one very important thing - clearance. I have to be extremely careful about tightening the front wheel chains to ensure that the chains clear the steering linkage. A truck will be no different. Chains loosen after a period of use and must be retightened. If not properly tightened it's easy to spin them off. I wouldn't advise aggressive chains like I have for my larger tractor. Chains are also problematic on hardpack or bare pavement and result in a very bumpy ride.
    gman2431[OP] and vicali like this.
  4. Nov 1, 2020 at 5:44 PM
    gman2431
    I know quite a bit about them when it comes to equipment. Vehicles not so much...
  5. Nov 1, 2020 at 5:46 PM
    taco pops
    taco pops Well-Known Member
    Russ
    West Michigan
    2016 black SR5 Tacoma DCSB
    Side Steps, Tonneau cover
    Maybe threr is along distance truck driver who runs out west in the forum. He could give good advise on installation and where to buy.
  6. Nov 1, 2020 at 5:54 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Better check your Michigan laws regarding the use of chains on roads.
    I'm sure you can use on your private property. State roads.......could be a different story.
  7. Nov 1, 2020 at 6:03 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I use to sell Peerless snow chains in my auto parts stores so have a little experience with them, but frankly my advise is I wouldn't consider using them unless absolutely necessary.
    Personally, if the snow is so bad that I can't handle it with either my '96 Tacoma 4x4 or my 18' TRD Sport without chains then I'm going to stay home.
    Tacoblues2019 and gillies66 like this.
  8. Nov 1, 2020 at 6:28 PM
    Boco10
    Boco10 Well-Known Member
    ADK
    I bought a pair years ago from Napa. Used them once and forgot about them. I do a ton of driving in the snow and for me new tires and some weight in rear is best. I would suggest doing a test fit at home. Unlike myself who learned the hardway in an ice storm.
  9. Nov 2, 2020 at 3:14 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Tacoblues2019 and gman2431[OP] like this.
  10. Nov 2, 2020 at 4:20 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    I’m that guy. Ran chains on my truck over the Sierras, Sisters and Rockies. Went so far as running a community college CDL school, too. Had a lesson on chains where we discussed and installed. I prefer a cam-type chain, as they are easy to get tight.
    A few thoughts:
    1. They work great under the right conditions.
    2. Drive tires only.
    3. Always mount them before you need them.
    4. Avoid running them on concrete, blacktop or other hard surfaces.
    5. Keep speeds SLOW.
    6. Connect the inside chain first.
    7. Tighten with the outside chain.
    8. Run a short distance, check and re-tighten.
    I agree with the previous post that says to stay home if conditions are that bad. Good, cheap insurance for the unexpected, though.
  11. Nov 2, 2020 at 7:20 AM
    gman2431
    Thanks guys great advise!
    I dont plan on road running with them. Main problem is boat launches that don't get plowing. We are left plowing them ourselves the night before or dealing with stuck rigs and boats in the morning. It would be easy enough to chain up and proceed the 100 yards Into and outta the place. You gotta keep in mind I will have a boat in tow so there isn't time for changing it... not only will you have a stuck truck you will have a stuck boat.
    And I'm not staying home all winter... hahaha! Snow won't deter my plans.
  12. Nov 2, 2020 at 7:35 AM
    JCT86
    JCT86 Active Member
    2017 Tacoma TRD Off Road
    I think I remember reading something about only using them on the rear wheels on our trucks. Something to do with sensors up front? Could be wrong but worth looking into. It's probably buried in the manual.
    gman2431[OP] and gillies66 like this.
  13. Nov 2, 2020 at 10:01 AM
    gillies66
    2020 DCSB OR
    IME, never put them on the steer axle.
    gman2431[OP] and doublethebass like this.
  14. Nov 5, 2020 at 5:05 AM
    257Roberts
    257Roberts Active Member
    VA
    06 SR5 4x4
    I use them on unplowed FS roads during hunting season and for skiing...the kind of spots where one might be in 4 wheel low in the summer. Couple thoughts based on my limited experience:
    1. Cables do okay for straight ice, but not for packed snow. If you have large lugs on your tires (like Falken Wildpeak) they may get sucked in...and can take some pulling to get out. They will also fit on the front on 245/75r16s if you're in a real bad way (not recommending you do this). They take up a lot of space and are a pain in the ass to deal with.
    2. The Peerless Auto Trac work okay, but the auto tightening things are known to fail if you don't go easy. They provide a bit of extra side to side stability if you're playing in off camber situations. The negative is they don't get you moving forward as well as the more traditional cross tire chains. They take up a quarter of the space of the cables.
    3. I currently use the "for walmart" Peerless tire chains (#0322730) with extra chain tighteners (the blue ones). You must roll the vehicle forward to get these on. V Bars or square link chain might work better in the future, but these are what I'm sticking with for now.
    *Edit - the #3 chains are probably double the thickness of the Auto trac type, so better bite in snow...and unsurprisingly take up double the space as the auto trac type. I've pushed through 20 inches of snow with these on some sketchy FS roads without needing to use my locker.
  15. Nov 5, 2020 at 7:07 AM
    gman2431
    Great advice! Thanks
