White exhaust is still my problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zepolr13, Apr 5, 2016.
  1. Apr 5, 2016 at 8:38 AM
    Zepolr13
    Zepolr13 [OP] Member
    2000 Tacoma V6 2wd
    I have a 2000 Tacoma 2wd v6 that is still causing me some white exhaust smoke on start-ups and I'm trying to figure it out. I'm burning coolant somewhere. I've tried a compression test that checked out fine with readings average of 190psi and replaced the after market PCV valve in it with a factory original. The air filter had some oil soak to it that may have been caused by a bad after market PCV Valve (which I replaced) so the air filter was replaced also. Those remedies lasted about a day and now the smoke is back again but to some degree it is less. Again, the white smoke issue only happens and last during start up and drive off but clears itself. Help on this issue would be greatly appreciated..
    hondamxracer likes this.
  2. Apr 5, 2016 at 8:42 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    head gasket is going out is typically the culprit...I wouldnt say cracked head just because you did a compression check. From my experience its usually between two cylinders....thats why when it heats up it expands the metal and it stops. Is your coolant level going down?
    Zepolr13[OP] likes this.
  3. Apr 5, 2016 at 8:48 AM
    Zepolr13
    2000 Tacoma V6 2wd
    Been keeping an eye on the coolant and there was some minor loss, maybe a cup or so. I should try the typical quick fix of head gasket repair fluid before deciding to machine the head. This is a used truck that I'm thinking to purchase. Should I buy it?
  4. Apr 5, 2016 at 8:50 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    White smoke is not always coolant. If you are not losing coolant, it could be fuel burning off from a leaky injector, or just incomplete combustion until your engine warms up.
  5. Apr 5, 2016 at 8:56 AM
    Zepolr13
    2000 Tacoma V6 2wd
    I should consider a TBI rebuild? New injectors?
  6. Apr 5, 2016 at 9:58 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You have MPI, not TBI. I would have a leakdown test done on your engine when it is cold to determine if head gasket is blown.
  7. Apr 5, 2016 at 12:39 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I would call it condensation buildup in the exhaust when initially started. ALL engines blow white out of the exhaust when the ambient outside temp is cold. Consider it perfectly normal. Now once the engine is completely warmed up and several miles has been driven or it is 80+ degrees outside and blows white......then you MIGHT have a problem. If you think you have a head gasket leak...check the spark plugs.
  8. Apr 6, 2016 at 6:35 PM
    Zepolr13
    2000 Tacoma V6 2wd
    White smoke is back on start- up. Oil looks clean, coolant level is good but we got more oil in the air filter box and soaked the bottom edge of filter. Noticed this symptom yesterday after compression test checked out and PCV replacement. But after cleaning the box and replacing filter it's back oily and dirty again. Top end problem? Valve cover gasket issue?
  9. Apr 6, 2016 at 6:50 PM
    CD20H
    Ben
    North Texas
    How is the oil getting on your air filter?
  10. Apr 6, 2016 at 8:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Probably answered already but I dont recommend any 'add-some-goo" to any engine, maybe if an emergency getting already crippled vehicle home...
  11. Apr 6, 2016 at 8:12 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Also, has it over heated ?? Or a leak down test of engine done yet ?
    No "milkshake oil" but still losing coolant means more searching for leak, do the test...
  12. Apr 7, 2016 at 10:52 AM
    Zepolr13
    2000 Tacoma V6 2wd
    Gonna replace the valve stem seals
  13. Apr 7, 2016 at 11:08 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    White smoke could also be caused by burning off of PS fluid (actually ATF for Toyotas). There is an idle-up valve on the side of the PS pump that could go bad, allowing that fluid to get into the intake. Have you checked the PS pump level yet?
    Speedytech7 likes this.
  14. Apr 7, 2016 at 11:41 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    PASS do not buy
  15. Apr 7, 2016 at 12:09 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Bxnanaz likes this.
  16. Apr 7, 2016 at 12:23 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    srsly taste the drips of water from tailpipe and spit it out
    if sweet = coolant
    if arse = oil
  17. Apr 8, 2016 at 5:33 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    Try a block test (NAPA part# 700-1006) the fluid will turn yellow if you have exhaust gas in the coolant system. if the fluid turns yellow then your HG is gone or a head is cracked. Pull the plugs and take a good look at them, they can tell you quite a bit about what is burning and temp inside each cylinder.
  18. May 14, 2016 at 10:57 PM
    extremepaint
    extremepaint Well-Known Member
    denver
    04 with stuff
    did you find out your issue? im having a similar problem
  19. May 15, 2016 at 7:49 AM
    Zepolr13
    2000 Tacoma V6 2wd
    I did find the problem. And i returned it to ZubesAuto Import Cali, for a full refund. That was NOT a good experience. I let my better instincts get away from me and bought the lemon without further assessment. My bad. Buyer beware. Back to square one looking for a truck for my kids college transportation.
    Instead of fixng the engine or replacing it, which they said "we always do the right thing" to make the truck right if there are warranty related issues". ZubesAuto violated their warranty which specified all engine mechanical x 30 days of purchase. Instead they said they would not invest any money in it and gave my money back after 2 weeks of back and forth on the white smoke issue and having to take several 200 mile turnarounds for them to "do the right thing", honor the warranty and fix it.
    The final diagnosis on the truck was made by Zubes trusted mechanics of site of Zubes business. The trusted mechanics literally just opened the hood, opened the air filter box, saw the oil and said "i aint never seen that before, the engines shot! Might be piston wrings, but the lower half of the engine is shot. Wont be worth working on unless you swap a new engine". That was the quickest engine assessment I have ever seen considering I had, with my own money, had a Toyota dealership give the tacoma a multi point inspection, and a compression that all checked out as OK and compression within accepted psi. I further gave it a hydrocarbon test that came up negative leaving me to believe the engine might still be sound and worth further assessment for Zubes to conduct, find the problem and honor the contract. The only other conclusive test needed I believe was a leak down test to finally conclude the engine health one way or another. Nope, Zubes trusted mechanics just gave it the eyeball surface check and said we're experts, the engines shot. I all was a freakin nightmare working with Zubes, and one of the brother that owns Zubes had me short of kicking his ass for lack of class, and sneaking insults at me out of his SOB piehole. What a nightmare. Tough lesson for me to learn at this age when i knew better. My bad. Buyer beware. Stay away from Zubes Auto http://www.zubesimportauto.com
  20. May 15, 2016 at 8:25 AM
    extremepaint
    denver
    04 with stuff
    damn i was hoping you would have found the actual cause.
    glad to here you got it squared away though even if you haf to get a new vehicle. me ill be pulling plugs akd doing a leakdown test. :p
