Whistle When Accelerating?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by weisnaw, Jun 6, 2024.
  1. Jun 6, 2024 at 7:33 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    Hey all,
    I've had this noise for as long as I remember on my 22 sr5 (bought truck new). In mostly 2nd & 3rd gear around 2500 - 3k rpms, I get this whistle (almost sounds like a turbo) when moderately accelerating coming from engine bay. After around 3k rpms it stops even when continuing acceleration. I have no loss of power or any other issues that seem to be prominent and I can continuously replicate it, especially when in manual mode. I don't think it has anything to do with the A/C since I have it off when this happens and It's really only loud enough to hear when the windows are down. Anyone else have this sound?
    Edit: I forgot to add that I cannot recreate the sound when I rev the engine in park or neutral. ONLY when driving.
    SwampGatorW2 and CrashZone like this.
  2. Jun 6, 2024 at 7:37 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Check the clamps on your engine air intake tubes - esp at the filter housing and before the MAF.
  3. Jun 6, 2024 at 7:44 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Mine sounded like that after the dealer forgot to close the air box correctly. My truck sounded like a g35 for a day.
    Road_Warrior likes this.
  4. Jun 6, 2024 at 7:45 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Could it be diff whine?
  5. Jun 6, 2024 at 8:02 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    Will check those and report back, thanks!
  6. Jun 6, 2024 at 8:04 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    Sounds like it's coming from engine bay, not sure if the diff would be the cause in that case? Sounds more like a high pitched whistle sound than a whine.
  7. Jun 6, 2024 at 8:04 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    Seems like it's closed correctly. I even took it off and re-clamped it.
  8. Jun 6, 2024 at 8:11 AM
    WA7
    WA7 Well-Known Member
    Craig
    PNW
    2021 Trail Edition
  9. Jun 6, 2024 at 8:18 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    I've been recreating the sound with ac and fans off and recirculation set to on
  10. Jun 6, 2024 at 8:41 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    Could be that what you are hearing is the A/C expansion valve and evaporator charging when the A/C kicks on. That is a complaint that others have posted for 3rd gens.
  11. Jun 6, 2024 at 8:42 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    Not postitive. But It seems that the issue is directly correlated with rpms and acceleration. Maybe something to do with the transmission?
  12. Jun 6, 2024 at 11:01 AM
    gobastard
    gobastard Member
    Quebec
    2020 Tacoma SR5 4x4
    Mine does the same exact thing, same gear and only when driving!
  13. Jun 6, 2024 at 11:22 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    I have searched far and wide for another thread on multiple websites and haven't found anyone else yet with this! I'm going to try and get a video so we can compare. It sounds like a high frequency whistle right? Not a howl?
    gobastard[QUOTED] likes this.
  14. Jun 6, 2024 at 11:23 AM
    abou824
    Aidan
    Central PA
    Yeah you're probably right on that then. Good luck figuring it out, stuff like that is infuriating
  15. Jun 6, 2024 at 11:25 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Do you have any stereo mods? I've had pretty bad alternator whine in other trucks that was exactly as you describe.
  16. Jun 6, 2024 at 11:26 AM
    weisnaw
    weisnaw [OP] Member
    2022 Tacoma SR5
    Bone stock!
  17. Jun 6, 2024 at 12:24 PM
    gobastard
    gobastard Member
    Quebec
    2020 Tacoma SR5 4x4
    i have really no idea but it doesn’t bother me!
  18. Jun 6, 2024 at 12:34 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    You loaned out your car to Bubb Rubb lately?
    WA7 likes this.
  19. Feb 24, 2025 at 4:07 PM
    SwampGatorW2
    SwampGatorW2 New Member
    2017 Tacoma 4x4 SR
    Hey folks, just coming across this thread. I'm having a similar issue in my '17. Were y'all able to figure out a solution?
