whining noise while engine is idling
Discussion in '1st Gen. Tacomas (1995-2004)' started by lshouse35, Jan 12, 2015.
  1. Jan 12, 2015 at 4:16 PM
    lshouse35
    lshouse35 [OP] Active Member
    Lawrence
    Havelock nc
    04 tacoma 2.7
    my 04 extra cab has a 2.7l while idling i have a whining noise almost like a power steering whine.. but i have a brand new rack w power steering pump... i check the idler pulleys for both the power steering and ac compressor they are not the culprit either i took each belt one at a time an tested while idling alternator is good ac compressor is good and power steering my only thought could be the crank... has anyone had this before ... i was considering a new harmonic balancer if anyone has gotten in to this any advice and wisdom would be awsome :):):):):)
  2. Jan 12, 2015 at 8:25 PM
    Taco04lifted
    Taco04lifted Member
    Rapid City South Dakota
    Crawler 04 taco
    6 inch lift, 5.29 gears, 17 inch wheels, 35 inch tires, ect
    I have the same problem with my 3.4 if you find anything let me know please
  3. Jan 12, 2015 at 8:39 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    water pump maybe? Mine does this too but only on the first start of the day. Only whines for maybe 5 seconds then goes away. My issue though I know is the water pump...had to replace probably 5k ago.
  4. Jan 12, 2015 at 10:12 PM
    herbsicecream
    herbsicecream Member
    Mason
    Calgary, Canada
    1999 Toyota Tacoma V6 5 speed 4X4
    Only cosmetic. (For now)
    I have the same issue in my 99' 3.4. I replaced the water pump and timing belt myself and it began making that whine as soon as the new parts were in it. Everything was replaced and I torqued all the bolts to spec. So far I have almost put 5000miles on it and nothing has changed in terms of performance/fuel economy, just whines in the lower RPM/idle range. Zer0 Mine whines like that on coldstart up too, but its a much different whine as you said and lasts for 5 seconds ish. My taco has to start in -5 fahrenheit (-20C) daily and it makes that noise when it is really cold. But that other whine is always there no matter what engine temp. If anyone know's what this phantom whine is let me know too, I'm almost tempted to go back in there and check everything to set my mind at ease.
  5. Jan 12, 2015 at 10:39 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
  6. Jan 12, 2015 at 10:59 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Fan clutches on most 1st gens do that on start up for a few seconds
    & you say idlers are good, got any audio ?
    also how does the fan blade feel when you turn it by hand ?
  7. Jan 14, 2015 at 6:49 PM
    Taco04lifted
    Taco04lifted Member
    Crawler 04 taco
    for mine it dose not stop the noise it don't matter how cold or hot it is only at low RPM even if its been running for a long time it still dpes it and the fan turns fine
  8. Jan 14, 2015 at 7:45 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Any chance you drive a manual? In neutral the input shaft (main shaft) is spinning a rack of gears and can whine if the tranny bearings are wearing out or if you have gears that are under lubricated. Mine make a little whirring noise when in neutral with foot off the clutch.
    Currygoat likes this.
  9. Jan 15, 2015 at 8:54 AM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    It is a manual tranny but is makes noise when it's in gear or in neutral I'm a 143k miles the engine runs great only thing I need to do is replace rear main seal there is a tiny bit of oil seaping out the bottom of my bell housing it doesn't burn oil ... The clutch fan doesn't have any play in it ... I'm thinking it has to be the crank pulleys or harmonic balancer
  10. Jan 15, 2015 at 8:59 AM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    Correct me of I'm wrong i took the ps belt of first ran at idle same noise put that belt back on took the ac compressor belt of same noise put it back on an took alternator belt off same noise would nt that test all three to stop the noise if that was it ?
  11. Jan 16, 2015 at 11:58 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    That whine is the supercharger dude. Didn't you even know you had one?
  12. Jan 16, 2015 at 1:47 PM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    Nah man its boosted goes real fast haha
  13. Jan 16, 2015 at 2:06 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    That seems like a pretty solid test for the pulleys to me... when did the noise start? recently or has it always been there?
    Edit: I'm thinking maybe the timing chain is getting loose considering your mileage... possibly rubbing on some components under the timing cover, or on the timing cover itself causing the noise.
  14. Jan 16, 2015 at 3:01 PM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    It has done it for at least 4000 miles it gets a little louder and more noticeable at higher Rpm I know the timing chain hasn't been replaced Ive got time to get into it this weekend and the weather isn't as shitty I'll try to take some pics and post them
  15. Jan 16, 2015 at 5:19 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yea I'm betting on the timing chain...
  16. Jan 17, 2015 at 6:18 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    see if you can wiggle the outer pulley on the balancer. I just had to replace my balancer because the outer ring where the belt rides seperated from the rubber and would spin on the rubber.
  17. Jan 17, 2015 at 11:49 AM
    ELMO67
    ELMO67 Well-Known Member
    Ct.
    04 Tacoma 4wd reg. cab
    If it is the input shaft bearing it WILL make the noise in or out of gear. Does it still make noise when you depress and hold down the clutch pedal?
  18. Jan 18, 2015 at 12:10 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I put this out there earlier.. OP, get some fucking audio up dude, this "whats that noise? " bullshit is getting old, it'll help alot
  19. Feb 17, 2015 at 5:03 PM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    It was a combination of water pump, the two idler pullys and alternator ..... Now it runs a lot better and quiet as a mouse
