Whining noise from transmission like a power steering pump with low fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by cooptoytoyota, Feb 2, 2016.
  1. Feb 2, 2016 at 9:05 PM
    cooptoytoyota
    cooptoytoyota [OP] New Member
    1999 Toyota tacoma
    Do not drive far as the fluid is not getting to the transmission valve bodies . the cause of this is the filter has collected too much burnt material in the transmission . This collection of burnt fluid has varnished the filter screen to create a seal of the filter screen . Removing the screen and cleaning the filter or replaceing the filter will stop the noise and stop slippage .Remember to clean the pan and magnents in pan & put magnets back in pan before installing pan and filler tube to transmission . Alyays fill with new fluid . Synthetic Dextron 4 or better works best if you haul a ton in the back of your bed .
    Fenwick1993 likes this.
  2. Feb 3, 2016 at 7:33 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    You said do not drive far as the fluid is not getting to the valve bodies. I have a whine like my power steering pump is going out like it did on my 99 Tacoma that I once had. I replaced it on that truck and the whine went away. How do you tell if it's the tranny or power steering pump besides moving the wheels back & forth and that's when you hear the whine. If you drove with that whining sound but your transmission shifts fine and the level of fluid is fine in both the transmission & power steering pump. Then what should I do next? I have a 3.4 V6 TRD 4x4 with an automatic transmission
  3. Feb 3, 2016 at 9:43 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    YMMV...but I have been driving with mine for the past 30K miles with a bit of a transmission pump whine. It changes with the gear changes and then drops off in OD. Not as much pressure is required. When I replaced the engine in my truck I changed the filter and cleaned it up and stuff. It is more annoying than anything else. Keep the fluid fresh and it should be okay. Going to swap out the tranny one day, but not today.
    How many miles are on it, and how long has it been doing it? Mine has 270K, been doing it since I bought it at 242K.
  4. Feb 3, 2016 at 9:57 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I have 238,400 miles. Just started a couple weeks ago.
  5. Feb 3, 2016 at 10:02 AM
    2scars
    Brandon
    RVA
    Change the fluid much? Have you ever done the filter? May be time...
  6. Feb 3, 2016 at 10:47 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I changed the fluid about 6 months ago but not the filter.
  7. Feb 4, 2016 at 6:57 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I noticed this morning my truck didn't have that whining noise till it warmed up. Then the whining started. Still can't isolate to the PSP or the Tranny. The college I go to has a auto shop so after school today I'm going to have the teacher try and diagnose it
  8. Feb 4, 2016 at 8:20 AM
    2scars
    Brandon
    RVA
    Hmmmmmmmm...check your fluid level when warm and make sure the level is appropriate. And the color. I changed mine just last year. It is starting to get a little dirty looking. Does it follow your shift points or is it constant. How is your power steering level? Does the rack leak?
  9. Feb 20, 2019 at 8:47 AM
    Muck
    Muck New Member
    Nate
    99 4runner
    Do you think it could be the tranny pump if it makes the whining noise in park, neutral and drive?
  10. Feb 20, 2019 at 9:11 AM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Mine did the same it was a bad torque converter. It sounds like a turbo as you raise speed.
  11. Feb 20, 2019 at 9:21 AM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    How often are you supposed to change the fluid/filter/do other transmission maintenance. Asking for a friend...
  12. Feb 20, 2019 at 11:59 AM
    Luv my yota
    00 turd lift 33's
    If you pull the trans dipstick it needs to be cherry red so mileage may vary depending on how hard you drive so going by mileage is out. I would change if dirty never flush and keep changing every 500 miles until it gets back to red color to be safe with the transmission, it also helps to change the filter in the pan its a p.i.t.a. Good luck its lots of money if you don’t get it saved by drain and fills, use dextron 4 and up. I have good luck with mobil 1 synthetic transmission fluid.
