Whining bearing noise from pulleys
Discussion in '1st Gen. Tacomas (1995-2004)' started by echo8287, Jun 1, 2022.
  1. Jun 1, 2022 at 1:44 AM
    echo8287
    echo8287 [OP] Active Member
    David
    Ga.
    99 prerunner
    I wonder if you guys could help me out on some whining bearing noise coming from the belts or pulleys. This is on a 1999 Pre-Runner 3.4 L. with 240,000 miles. I can't tell if it's an alternator, power steering pump, idler pulley or A/C. Is there any easy way to isolate one of these items? When I turn the wheel back and forth it doesn't get any louder on the power steering pump(it's full of fluid). I thought I could just buy an idler pulley and take that off with the corresponding belt, crank it up and see if that eliminates the sound. Then go from there. Any suggestions? Thanks for any replies!
  2. Jun 1, 2022 at 3:37 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    use a stethoscope, if you don't have one a piece of wooden closet pole or wooden dowel will transmit sound very well. try and place either of these as close to the suspected noise maker as possible and listen for the squeal. You can also remove each belt one at a time and start the truck, just don't run it for more than few seconds. This method will help eliminate what is making the noise.
    AmherstAndy likes this.
  3. Jun 1, 2022 at 9:03 AM
    mbeers6
    mbeers6 Well-Known Member
    East bay, ca
    03 tacoma double cab 4wd
    Air filter
    Easiest and quickest way is to get a spray bottle with just water in it. With the car running, spray one belt at a time. If the noise goes away then you know it is the belt you just sprayed.
    vanrynd likes this.
  4. Jun 1, 2022 at 9:17 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You don't need to remove the belt to change the idler pulley. Just loosen the adjuster, you can then dismount the pulley. The bearing in the OEM idler pulley is swap-able so it's worth saving that pulley.
  5. Jun 1, 2022 at 8:32 PM
    echo8287
    David
    Ga.
    99 prerunner
    Thanks to all who replied, I will try the spray bottle tomorrow. While driving around today I turned the A/C on and off> it made no change in the sound. My wife works at a doctors office so I will see if she can bring a stethoscope home and I will try that next. It's not a whining/screeching sound kinda of a low groaning sound. Mr. Digiratus thanks for that info,I didn't know you could just change the bearing in that pulley. Do you have to go to Toyota to get that bearing or somewhere else. I put all new belts, hoses, water pump, timing belt and tensioner on it at 212,000. All were Toyota parts.Thanks to all, Dave
  6. Jun 1, 2022 at 11:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is the what I use.
    https://www.amazon.com/dp/B07BY6Q45L
    It is a little cheaper to purches a 2-pack instead of a 10-pack, but not a whole lot less. Either way, cheaper than buying an OEM replacement and will last just as long.
    https://www.amazon.com/dp/B07BYFF42...9bb1c55e1182&s=industrial&smid=A3RMJZMAP3U4RK
  7. Jun 2, 2022 at 8:28 AM
    mbeers6
    East bay, ca
    Air filter
  8. Jun 2, 2022 at 11:45 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    OP,
    I normally 4 wheel in deep mud/high water which kills that low hanging idler pulley bearing quick! That is usually the source of any squealing noise on my '97 V6 Taco. Have probably changed it a dozen or more times in 25 years. The OEM bearing in the idler pulley is usually a JAPAN NGK or JAPAN Nachi which you can get off Ebay for $9 shipped: 6301-2NSE9 NACHI bearing 6301-2NSE seals 6301-2RS bearings 6301 RS Japan | eBay. It's a cheap and easy fix. Good luck!
    EDIT: The type bearing is a 6301-2RS which has seals on both sides. But the different companies have their own nomenclature for that type bearing. The JAPAN bearings last longer for me. I think I am currently running an NGK JAPAN bearing.
    Tuluk and sinks88 like this.
  9. Jun 6, 2022 at 12:40 AM
    echo8287
    David
    Ga.
    99 prerunner
    I have not replaced the lower idler pulley ever. I have changed the timing belt, the water pump, all the belts and hoses, cam bearing but I guess I overlooked that lower idler pulley. Toyota's are fantastic for the durability of the parts. I don't know how many people have tried to buy mine over the years, but I will never sell it.
    Thank all of you for the assistance!!! I am working on it now and I will post what I find. Thanks for the ordering info as well. I love Tacoma World as it has a lot of great guys on here. I have been a member since 2014. Thanks so much for the help, David
    Digiratus likes this.
  10. Jun 6, 2022 at 1:55 AM
    TreeBass
    TreeBass Well-Known Member
    Second this method, I use a long flat screwdriver, and put my ear to the end with the engine running, just be careful not to have loose clothing and a long beard.
  11. Jun 12, 2022 at 10:29 PM
    echo8287
    David
    Ga.
    99 prerunner
    Thanks to all you guys. I did order a stethoscope and listen to all the suspect items. Man it was a lot louder than I thought it was going to be with the stethoscope. Anyway I think it is the alternator bearings, so I am ordering those and the lower idler pulley too. The truck has 242,000 miles so I don't mind changing a few things. I will post what happens when I change each one of those items. Thanks so much,Dave
    leid, AmherstAndy and Rastopher like this.
  12. Jun 13, 2022 at 9:53 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Good luck man, looking forward to your updates!
  13. Jun 13, 2022 at 3:12 PM
    mbeers6
    East bay, ca
    Air filter
    Same here ^, I have 232,000 and wondering if I should replace my alternator bearings given the mileage. Original alternator as far as I know.
  14. Jun 13, 2022 at 3:18 PM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Thanks for the update. I strongly suggest you consider replacing the alternator brushes while you have it out of the truck.
  15. Jun 13, 2022 at 3:19 PM
    AmherstAndy
    Andy
    Masshole
    This would help isolate a squealing belt, but would not help isolate a whining bearing, as described in the OP.
    Bivouac likes this.
  16. Jul 7, 2022 at 9:27 PM
    echo8287
    David
    Ga.
    99 prerunner
    My Toyota brothers, I changed the idler pulley bearing yesterday, going to test it tomorrow. I think it may be that as I cranked it up after installation and I don't think I hear the whining. I will let y'all know after I drive it. I did order the alternator parts(bearing's), and to Andy, I did order the brushes too. I'm sure many of you know about Amayama for Toyota parts. It's pretty crazy that you can order genuine Toyota parts from Japan or United Arab Emirates cheaper than anywhere in the USA. When I rebuilt my front end I saved about $500 on all the parts buying from that place. It didn't take that long(7 days) to get the parts and they were genuine Toyo parts.
    Anyway for everyone's help> I ordered some extra idler bearing and for the first 3 people that reply and need or want one of these,I will send you a free one, sort of a pay it forward freebe. I guess you would have to pm me on here with name and address. The part was a 6301-2RS bearing, I will pay the shipping.(which is more than the part). If anybody wants one, let me know.
    Madjik_Man, leid and Digiratus like this.
  17. Jul 7, 2022 at 10:04 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I was looking at their website after reading your post, and they don't list the 1st Gen Tacoma for parts. Did you order these from the 4 runner option.
  18. Jul 7, 2022 at 10:49 PM
    echo8287
    David
    Ga.
    99 prerunner
    I used my Vin number when I order from them>
  19. Jul 7, 2022 at 10:51 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    thanks for the reply, I'll try that and see what parts show up.
  20. Jul 8, 2022 at 11:36 AM
    mbeers6
    East bay, ca
    Air filter
    I would love to get a bearing since I'm going to be rebuilding my alternator very soon (225,000 miles). I will send you PM with my name and address. I can paypal or venmo you the shipping. Also thank you for the info on the website, will look into before I order next set of parts.
