Which way seat belt buckles face?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tool Pants, Dec 28, 2013.
  1. Dec 28, 2013 at 8:43 AM
    Tool Pants
    Tool Pants [OP] Active Member
    San Jose
    2001 Xtra Cab 2.4L 2wd
    On my drivers side the buckle faces out. Passenger side in. Which is correct.
  2. Dec 28, 2013 at 8:45 AM
    medic2230
    Murph
    Bama! Roll Tide
    Driver's side way
  3. Dec 28, 2013 at 9:52 AM
    Indy
    Indy Master of all I survey.
    The buckle should be facing in, 1st picture. Facing out would put a twist in the belt when its being used.
  4. Dec 28, 2013 at 9:53 AM
    medic2230
    Murph
    Bama! Roll Tide
    And rub the plastic trim on the B post.
  5. Dec 28, 2013 at 10:03 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Buckle out.
    Mine doesn't get twists in it. Facing in puts a twist on it.
  6. Dec 28, 2013 at 10:06 AM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    mine is set up just like yours, id love to know a simple way to fix it.:confused:
  7. Dec 28, 2013 at 10:07 AM
    medic2230
    Murph
    Bama! Roll Tide
    Facing in it pulls straight across you to the latch. :confused:
  8. Dec 28, 2013 at 10:08 AM
    Ice Horse
    Lauren
    Colorado
    But then the belt would be in the way, so you'd have to twist it.
  9. Dec 28, 2013 at 10:19 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Put a half twist on the strap, fold flat, pull the buckle past the fold.:D
  10. Dec 28, 2013 at 10:22 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Drivers side is the way mine are. I hate the buckle towards the door!! Irritates me!!
  11. Dec 28, 2013 at 9:19 PM
    Tool Pants
    San Jose
    This is confusing as to what is in and what is out. So I took 2 more pictures of just the drivers side, which I call facing out. The buckle faces out on the drivers side.
    I sometimes do get a twist when I unbuckle the drivers side. That is why I wonder if I should have the buckle facing in like the passenger side.
  12. Dec 28, 2013 at 9:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Driver's side is correct.
    It'll twist if you just throw it off without allowing it to retract.
  13. Dec 29, 2013 at 8:03 AM
    Indy
    If yore sitting in the vehicle and see the shiny side, its facing in and is correct. If younsee the back side and the buckle itself is between the 2 layers of belt, its incorrect. The belt when used should lay flat, no twists anywhere.
    A twist across your body will cut down on the surface area to spread pressure in a wreck. That small point *can* cause more injury than having the pressure spread over a larger area.
  14. Dec 29, 2013 at 8:10 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    What are these seat belts you speak of ?
  15. Dec 29, 2013 at 8:56 AM
    Ice Horse
    Lauren
    Colorado
    I think the confusion is everyone has a different meaning of in and out :rofl:
    When I said out I was meaning you should see it outside the belt, shiny out.
