Which valve spring compressor tool?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dankgus, Apr 9, 2022.
  1. Apr 9, 2022 at 3:55 PM
    dankgus
    dankgus [OP] Well-Known Member
    Dan
    2002 3.4l Tacoma
    I borrowed a valve spring compressor tool from AutoZone, I just can't see this thing being helpful. It's not the right variety. Pretty sure I'll need the kind that looks like a big C clamp.
    Anybody got tips on a proper tool?
    5VZ-FE
  2. Apr 9, 2022 at 6:23 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    treyus30 likes this.
  3. Apr 9, 2022 at 7:43 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Good to know. Any tricks to using this or was it pretty straight forward? Run into any snags?
  4. Apr 9, 2022 at 7:50 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Yep, that's the one I've got and used, just in a red box. No way it got anywhere near flexing. The 5VZ's springs aren't "heavy" by any standard (think they're around 60lb). I've compressed 90lb springs with it no issue.
  5. Apr 10, 2022 at 11:13 AM
    dankgus
    Dan
    2002 3.4l Tacoma
    Really straight forward. Get a little magnet on a stick at any auto parts store if you don't have one already, use it to pick up the valve keepers when you compress the spring. Super, super easy.
    Nessal[QUOTED] likes this.
  6. Oct 13, 2022 at 11:13 AM
    Nessal
    Texas/Bay Area
    Does this tool help when changing out valve shims when adjusting the valve lash with the motor still in the vehicle?
  7. Oct 13, 2022 at 11:58 AM
    dankgus
    Dan
    2002 3.4l Tacoma
    No. No it doesn't. For that you'll need to remove the cams and just leave the valves in place.
