Which Tires for the best Fuel Mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by 71burton, Feb 13, 2014.
  1. Feb 13, 2014 at 11:02 AM
    71burton
    71burton [OP] Member
    McMinnville, TN
    1999 tacoma 96 hybrid
    I bought a set of BFG All terrains a few months ago new. I paid $835 for them at dealer cost through a family member who works at the Ford dealer I got them from. I bought an E class tire (10 ply) because they were $40 cheaper a piece. My fuel mileage has suffered bad. I went from 17-18mpg city and 21 hwy to about 13.5-14mpg city and 15mpg hwy. My truck is a 2.7l Automatic 4x4. I am thinking about buying a set of Nitto Trail Grapplers in the same size I have now (265/75/16) but not in a 10ply and selling my bfg's. Would the lighter tire even though it is a "mud terrain" give me better fuel mileage than my heavier all terrians?
  2. Feb 13, 2014 at 11:31 AM
    jdob
    jdob Well-Known Member
    jeremy
    Mandeville, LA
    19 DCSBOR MT
    A heavy tire will kill mileage. No need for a E rated tire on a tacoma. Find a c rated tire you like. I know the duratrac has a huge following. A skinner tire will also help with MPG. Goodluck
  3. Feb 13, 2014 at 11:33 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Dude whats up im in Viola
  4. Feb 13, 2014 at 11:39 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Typically speaking, the lighter and less aggressive the tire the better your fuel economy will be.
    The bigger the tread blocks and the more aggressive the pattern the more rolling resistance you will have. More rolling resistance--> more work that your engine is doing--> more fuel consumed.
    Also, the higher the ply rating the heavier the tire. Heavier tires get worse gas mileage because it takes more work to get them rolling.
    Also, keep a close eye on your inflation pressures; even a couple psi low can put a dent in your MPG's.
  5. Feb 13, 2014 at 6:33 PM
    71burton
    McMinnville, TN
    Holy crap its a small world! I'm in Viola also! hmu sometime and we'll cruise or someting
  6. Feb 13, 2014 at 6:38 PM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    Well I was, I think I know who your are :cool: Actually I do, I just followed you on instagram the other day I think
    Im in WA again, should be back in TN for a few weeks in may.
  7. Feb 13, 2014 at 9:39 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    this is a good question, my 33 grabbers chew through a tank of gas like nothing...
    i want to go back to some 31 inch all terrains, but which ones get the best MPGs?
  8. Feb 14, 2014 at 7:10 AM
    dbd
    dbd Well-Known Member
    Dave
    WV
    2003 Tacoma 4x4 5spd
    2" leveling kit
    Michelins seem to have lower rolling resistance and are a higher mileage tire. They are also lighter built to save you some weight which makes a big difference. My tires vs some of the others are 10-15 lbs lighter. That's weight against the drivetrain not just carry weight. Same thing when you go to steel wheels, even more weight. I've seen guys go from 31x10.50's on aluminum wheels to heavy mud tires on steel wheels and lose an easy 2-4 mpg.
  9. Feb 14, 2014 at 7:53 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    bfg makes the radial long trail which is a highway tire. and as bad as the OE tire is they are highway rated.
    bridgestone makes decent tires too
    I currently use Firestone Destination AT and have had them for four years (whatever clout that has :p )
    edit: 235/85-16 is equivalent for O.D. and is lower roll resist
  10. Feb 14, 2014 at 7:57 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    P rated tires is what you want. Not LT.
  11. Feb 14, 2014 at 8:01 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I don't normally pop in to a thread just to argue with the OP, but there's no way a set of tires cost you 6 MPG on the HWY. We're not talking 38's ... It's just not possible.
    I've driven trucks my whole life and on all of them I've gone from whatever came stock to aftermarket tires. 32's, 33's, 35's ... I would even be questioning 3'ish MPG loss. 1/2-2 is more likely.
    You said you bought them a few months ago. Are your before new tires MPG numbers from summer? Are you in 4WD a lot more now? Did you develop a lead foot with the new look of your truck? Any other mods done? How are you tracking the MPG?
    Something else is going on ..
  12. Feb 14, 2014 at 8:08 AM
    medic2230
    Murph
    Bama! Roll Tide
    A highway tread tire will give you the less resistance and like said above a P rated tire. Also a stock size on the 1st gen of 235's will be best for fuel mileage. Like above thought I think there may be something else going on. It's hard to believe that the tires made you drop that much.
  13. Feb 14, 2014 at 8:26 AM
    egebhardt
    egebhardt Well-Known Member
    Eric
    Rapid City, SD
    '99 4x4 Xcab 5spd V6
    None
    I'm shopping for a faster tire too, but I don't want to mess with the speedometer or the looks. A truck with tiny tires looks stupid.
    I have Bridgestone 31 x 10.5 now. That is the stock size for the 4x4 6-lug wheels.
    I'm looking at 265/75 r15 because they are a 1/5" narrower and 1/3" shorter (overall diameter). Not much smaller, but anything will help over time.
    Use this calculator to see the actual sizes.
    http://www.tacomaworld.com/forum/tirecalc.php?tires=265-75r15-31-10.5r15
  14. Feb 14, 2014 at 8:32 AM
    Koov
    Koov Well-Known Member
    Seattle
    2019 DCLB TRDOR
    Michelins MS2 will be one of your best bets for Fuel Mileage. I run these tires and they are very smooth and quiet.
  15. Feb 14, 2014 at 9:13 AM
    DSMJRV
    justin
    Corona, CA
    im in the same boat as the OP, my mpg dropped 4mpg when i went from stock to 33 grabbers... i think this is pretty normal, weight + diameter + roll resistant tread = poor MPGs..
    however OP you have to count in the fact that your new tires are going to throw off your speedo and odometer... find a tire calculator and see how much larger the your tire is % wise, and add that to your current MPG findings.. like if i get 240 out of a tank its actually 270 or something like that... If you have a in car gps, that is probably the easiest way to track your real mileage per tank..
  16. Feb 14, 2014 at 10:49 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Depends alot on your right foot. Less plys means less weight,,so yes. The Mud Terrain is based off of the All Terrain platform. They created and upgraded the All Terrains for Baja wins,,and they did that at a 6ply 110mph+ beadlocked tire. They would turn into pizza cutters at that speed, until the upgrade to the Tri Guard 3 ply sidewall,,then not so bad and much better wear and durability.
    A excellent tire you have, but your 4 plys to many. 10 ply is for logging road running, towing heavy, ect, if you do alot of that. If you keep them, rotate often.
  17. Feb 14, 2014 at 12:33 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    You can buy stock size Mastercraft Courser STR's for like 90.50 ea online. I have beaten the living shit out of them (trust me) An alloy wheel helps a lot, too
  18. Aug 22, 2023 at 3:45 PM
    Tennessee Caveman
    Tennessee Caveman New Member
    Vollie
    2013 Tacoma 4x4 crew cab
    None yet
    My basic question, after viewing these replies is: Are P rated, Falken AT3ws going to make THAT much difference in mileage vs regular highway tires?
    I have a (new to me) used 2013 4x4 Crew Cab Tacoma that used to be a fleet vehicle. This truck has had no mods at all and I'm due new tires, and want to get something a bit more aggressive looking, but the truth is, my off-roading is typically farm fields and gravel roads, with 95% being hwy miles. I'm looking at at the P rated Falkens
  19. Aug 22, 2023 at 3:55 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    Youre going to see a slight drop. Maybe an MPG or two on the highway but that's what I got on my old truck with slightly larger than stock Nokian Rotiivas. Yokohama Geolandars are pretty mild A/Ts. If you want a good highway tire that has decent offroad capability I've heard the Michelin Defender LTX M/S are pretty good and will return good MPGs.
  20. Aug 22, 2023 at 4:01 PM
    tjv504
    tjv504 Taco n00b
    Tom
    NOLA
    2023 Tacoma TRD Sport Lunar Rock
    Pro Grille, TRD skid, Spidertrax 1.25" spacers, Cali Raised cat shields, Seat Jackers, 67Designs Taco Rail, WeatherTech floor mats + bug deflector + side window vent shields, demon (nipple) rings, Hitchhiker's Guide to the Galaxy reference on the tailgate, Tyger tri-fold tonneau cover
    Cub Scout Pinewood Derby chief here. The lighter the better. Heavy wheels are less efficient and waste energy. In the case of a pinewood derby car that energy is gravity, and in a Taco it's fuel. Plenty of rules in the derby in terms of wheel modding/lightening because of this (and people still try it bc it works so well). Lightweight tires should be more fuel efficient, generally speaking.
    Then again I'm no physicist. Just always assumed that rule carried over...
