Which Tacomas came with 3.73 gears?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomatt602, Jun 13, 2015.
  1. Jun 13, 2015 at 6:26 PM
    tacomatt602
    tacomatt602 [OP] Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    For a 7.5" rear end. I have 3.58s but I'm looking to get better acceleration out of my 5-lug and to be able to hold 80 or 85 without the tranny kicking down a gear constantly. I would prefer 3.91s but I was told those only came in 8" differentials. And there are quite a few junk yards around where I live, so I'm pretty confident I can find the right Taco to pull them off of.
  2. Jun 13, 2015 at 8:41 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    you have a 2.4 engine, doing 80-85 is all its got for the most part so you can play with gears all you want but the issue is that's all the power the engine can give you, its got nothing to do with the gearing.
  3. Jun 13, 2015 at 8:58 PM
    tacomatt602
    Phoenix, AZ
    85 might be pushing it.. but 80 is more realistic. I drive over 100 miles a day installing real estate posts all over central AZ. It just sucks not being able to keep my speed up..
  4. Jun 13, 2015 at 9:06 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  5. Jun 13, 2015 at 10:25 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    You need lower gears if you want more acceleration, 3.73 is really high. My 3.4 V6 has it and it's plenty adequate, but that's the difference between a V6 and 4 cylinder. You need to be looking into 4.10 gears my friend. I think all the 4 cylinder 4x4 Tacos have 4.10 rear ends, my 2011 did.
  6. Jun 13, 2015 at 11:22 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    He is looking for a 7.5" diff for a 5 lug. All 1st gen 4x4 Tacos have either an 8.0" or an 8.4" rear diff. Your suggestion wouldn't help him. For gearing the 1st and 2nd gens are quite diffrrent. The 1st gens are lower geared and not all 4 cylinder 4x4 Tacos have 4.10 gearing by any stretch.
  7. Jun 13, 2015 at 11:28 PM
    xcmtb83
    Iowa
  8. Jun 14, 2015 at 11:50 PM
    tacomatt602
    Phoenix, AZ
    Would you guys know if 1st gen and 2nd gen 7.5 rears are identical, in that their gears could be interchanged?
    And does anybody know what other size gears came in the 7.5 rear, >3.58? Even though it wont help with my top speed problem, its gotta help out acceleration, right?
  9. Jun 15, 2015 at 9:52 AM
    keakar
    karl
    louisiana
    compare part numbers, if the numbers are different then they are not interchangable
  10. Jun 15, 2015 at 4:04 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    pretty sure 1st Gen 4cyl 4wd came with 4.56 (manual) or 4.88 (auto), or 4.38? 4.10 was 6cyl (auto or manual)
    2wd I have no clue but I think it would be more limited
    didn't 3.73 come on the '05+ TRD Sport? but that would still be 8" (not 5-lug either)
  11. Jun 15, 2015 at 8:50 PM
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    01' Tacoma 4x4 3.4l 5 spd
    My 98 4x4 2.7 came with 3.58 gearing and to say it's a turd is an understatement lol! I want to install 4.56 in it.
  12. Jun 16, 2015 at 5:16 AM
    beardawg
    beardawg Member
    My 95.5 2.7 has 3.58's in it, my step dads 99 2.7 4wd has 4.10's. His truck feels like a sportscar compared to mine.
  13. Jun 16, 2015 at 5:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    Those are opposite goals. Using gearing to improve one will hurt the other.
