Which speed sensors control the speedometer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by victorgennett, Dec 21, 2021.
  1. Dec 21, 2021 at 3:54 PM
    victorgennett
    victorgennett [OP] Member
    Victor
    schuylerville 12871
    salvage/rebuilt NY Tacoma
    Another salvage truck question: For a 2011 4x4, with auto trans, which speed sensor(s) control the speedo/odo? I have a po500 code showing and it won't pass inspection.
    Thanks for any help,
    Vic
  2. Dec 21, 2021 at 4:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the Speedometer working?
    If so, it’s probably not a speed sensor.
  3. Dec 21, 2021 at 4:13 PM
    victorgennett
    Victor
    schuylerville 12871
    No speedometer or odo. A cheap scanning device said "po500, speed sensor A"
  4. Dec 21, 2021 at 4:21 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is your ABS light on? On the automatic transmission trucks the vehicle speed signal comes from the ABS module to the Combination Meter (instrument cluster) and then the cluster sends the speed signal to the PCM.
    b_r_o and TnShooter like this.
  5. Dec 21, 2021 at 4:27 PM
    TnShooter
    Deogee
    STOCK
    Not sure on sensor A?
    The wheel sensors are code 31,32,33, or 34.
    I know the manual transmission uses a separate sensor on the transmission.
  6. Dec 21, 2021 at 4:35 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Sensor A basically means sensor 1 or single sensor as far as the PCM is concerned, the ABS uses one of the rear sensors for the vehicle speed signal output but I'm not sure which one.
    TnShooter[QUOTED] likes this.
  7. Dec 21, 2021 at 4:40 PM
    TnShooter
    Deogee
    STOCK
    Someone post which one it was, but can’t remember. It’s been awhile since it was posted. I believe it was Muddinfun, he was pretty versed in this subject.
    I’ll see if I can find it later.
  8. Dec 21, 2021 at 4:53 PM
    TnShooter
    Deogee
    STOCK
  9. Dec 21, 2021 at 4:57 PM
    TnShooter
    Deogee
    STOCK
    I’ve never seen a definitive answer.
    But I’ve seen the question asked more than once here. Which one drives the speedometer?
    I’m curious if one could jack up the truck and place the truck in neutral and somehow spin a tire fast enough to “know for sure”.
    Or is there a better way?
  10. Dec 22, 2021 at 4:37 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Hook up a scan tool and you can view all the speed sensor inputs to the skid control ECU. I don't believe a "single sensor" drives the speedometer, it is what the skid control ECU knows to be the speed, this is taking a speed from all 4.
    blu92in99 and TnShooter[QUOTED] like this.
  11. Dec 22, 2021 at 5:40 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Attached is the best I could find about how Toyota has designed the "black box" of the ABS/skid control ECU. I have to imagine the input sensors being monitored and the speed signal that's being developed is a result of some median voting logic, with a known bad sensor being thrown out of that voting. If for example, you're going down the road and one speed sensor fails or locks up due to ABS actuation, you don't see your speedometer immediately drop off. That is only a best guess at this point because I have not been able to confirm how the SPD signal is actually developed inside the skid ECU. A simple test would be to set yourself up a 4 channel signal generator with an oscilloscope and monitor the output of the SPD signal. Vary the signals generated or disconnect one sensor and see what the resultant SPD signal looks like.
    GilbertOz and TnShooter like this.
