Which replacement fuel pump?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logger, Aug 31, 2020.
  1. Aug 31, 2020 at 12:36 PM
    Logger
    Logger [OP] out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    The title is derpy, I know.. probably right up there with which lift to buy.
    My fuel pump shit the bed, luckily at the end of my driveway and not in the middle of nowhere. What is a decent replacement for a 3.4? Better yet, what is one to stay away from? I think I should replace the assembly and not just the pump and I have a feeling I will be replacing the tank as well seeing as it's a MN truck. Thank you for any recommendations on which brand pump to buy.
  2. Aug 31, 2020 at 1:53 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Your sure it is the pump that failed?
    Denso # 951-0001 Unless your looking for more fuel volume then stock
    Get a fuel pump bracket if possible.
    It can turn into a Major project with rusted seized fuel lines.
  3. Aug 31, 2020 at 1:54 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    +1 on the Denso. Also recommend picking up a new gasket for the sending unit.
    Logger[OP] and BillsSR5 like this.
  4. Aug 31, 2020 at 2:00 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Logger[OP] likes this.
  5. Aug 31, 2020 at 2:03 PM
    Logger
    Sam
    Thank you for your reply. Not entirely certain, but the gauge went out a couple of years back, but the low light warning still worked until Friday. I thought I was possibly out of fuel so I put in 2 gallons and it still cranks and cranks. Prior to it not starting, I noticed a slight surge at partial throttle and bucking under harder acceleration. I attributed it to a failing pump. I have a CEL on but it shows an evap code and nothing else. I'm pretty certain the top of the tank is crusty and leaking as I smell fumes near the side of the truck.
    I did have a frame replacement along with new lines done a few years back, so I'm hoping it won't be too terrible. I guess I'm just preparing for the top of the tank to be bad. I looked here on TW and saw a parts list for the tank and associated parts; holy shit that is gonna add up! The OG pump and tank have 210k on them.
    GQ7227 likes this.
  6. Aug 31, 2020 at 2:09 PM
    BillsSR5
    bill
    2014 SR5
    the fumes you smell and EVAP code is most likely the seal on top of the gas tank is leaking because of corrosion around that sending unit cover, if you get a flashlight peak in between the gap between the rear of the cab and front of the bed youl probably see wet spots around that fuel sending flange and the top of the gas tank leaking gas, my 04 access cab had the exact same scenario,
    Logger[QUOTED][OP] likes this.
  7. Aug 31, 2020 at 2:13 PM
    Logger
    Sam
    great thanks. I'll take a look, not sure if the position is different on my double cab, but I'll see. Maybe I'll get lucky and just and need a seal around the flange? That would be nice, what did you end up doing with your leaking scenario?
  8. Aug 31, 2020 at 2:25 PM
    BillsSR5
    bill
    2014 SR5
    I would replace the pump with a new DENSO while your in there that's what I did at over 200k miles you wont regret not doing it later, use a thin layer of grey RTV on the new seal helps, the EVAP code senses a leak in the sealed system. if you smell fumes stepping out of the truck 99.9% of the time its that seal and corrosion. just look for wet spots around that top sending unit flange that'll be it. easiest way remove the bed slide it back gives you access, search the web on how to bed removal pretty easy, better than dropping the tank
  9. Aug 31, 2020 at 2:28 PM
    BillsSR5
    bill
    2014 SR5
    GQ7227 likes this.
  10. Aug 31, 2020 at 2:34 PM
    BillsSR5
    bill
    2014 SR5
  11. Aug 31, 2020 at 6:11 PM
    1997tacomav6
    Denver
    Stay with the DENSO pump,
  12. Aug 31, 2020 at 6:17 PM
    Logger
    Sam
    I’m trying to determine if denso offers a complete assembly and not just the pump. So far I’m not seeing an option for the entire assembly.
  13. Aug 31, 2020 at 6:18 PM
    BillsSR5
    bill
    2014 SR5
    you get just the pump and a new filter sock, you take out the old one and put together the new one with the new sock, easy, no need for new assembly I think the gen2 trucks get a full assembly
    1997tacomav6 likes this.
  14. Aug 31, 2020 at 6:20 PM
    1997tacomav6
    Denver
    X2, and hope the gas line comes off ok :)
    Logger[OP] and Wyoming09 like this.
  15. Aug 31, 2020 at 6:25 PM
    BillsSR5
    bill
    2014 SR5
    no problem hardest part is lifting off the bed after you break the bed bolts, impact wrench makes short work of the bolts, also the bed bolts are of high grade steel and wont snap like a lot of others, you might hear a lot of screeching when they start coming out, once you get them broke loose alittle hit a couple shots of WD40 on the threads area, after that 2 guys pick up the bed and remove easy with the short quad cab bed, then the fat lady sings
    1997tacomav6[QUOTED] likes this.
  16. Aug 31, 2020 at 6:31 PM
    1997tacomav6
    Denver
    Ive gone through two pumps in 630k miles, just put a new DENSO in last year
  17. Aug 31, 2020 at 7:00 PM
    BillsSR5
    bill
    2014 SR5
    if you have a short quad cab, its 4 bolts unplug the taillights/license plate lights, unbolt gas filler neck lift off the frame and work on it with the gas tank still in place
  18. Aug 31, 2020 at 7:03 PM
    BillsSR5
    bill
    2014 SR5
    I had the access cab 6 bed bolts zip zip zip with an impact wrench
  19. Aug 31, 2020 at 7:07 PM
    BillsSR5
    bill
    2014 SR5
    if you need a new tank you probably need new straps also, SPECTRA brand makes those replacements at ROCKAUTO
  20. Sep 11, 2020 at 8:48 PM
    Logger
    Sam
    Working on the fuel pump tonight. I did order a new sending unit from Spectre and a Denso pump. While examining the wiring harness for the pump and sending unit, I found most the wires are frayed and broken! I suspect that’s why my gauge and pump don’t work.
    I still plan on replacing the sending ol unit and pump, but does someone make a pigtail for the sending unit? This thing is a mess, the pic is shit, but it’s the gray lead.
    six5crèéd likes this.
