Which Optima battery for me?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justinlhc, Dec 24, 2016.
  1. Dec 24, 2016 at 4:28 PM
    Justinlhc
    Justinlhc [OP] Not looking for a relationship
    My battery just failed me. I've noticed it has been cranking a bit slower lately so it's no surprise. I updated the firmware on my head unit and it died in my garage during the process.
    I've decided on an Optima, but I don't know which color. Red or yellow? I don't use the battery much with the engine off if that matters. I have no winch or huge power draws other than my stereo(2 amps).
  2. Dec 24, 2016 at 4:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Red. I'm running one.
  3. Dec 24, 2016 at 4:42 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    Red is a standard battery - yellow is deep cycle. If you plan on running it down and frequently recharging, then yellow. If not, red. I have one of each. Red to start the truck, yellow to run accessories.
  4. Dec 24, 2016 at 4:44 PM
    Justinlhc
    Even though I don't plan on drawing it down, why wouldn't I just get the yellow?
  5. Dec 24, 2016 at 5:24 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Actaully the black case optimas are all for starting. Gray case optimas for deep cycle.
  6. Dec 24, 2016 at 5:27 PM
    Justinlhc
    So the cases AND tops are different?!? :goingcrazy:
  7. Dec 24, 2016 at 5:28 PM
    sawed off
    Randy
    Idaho
    Call your optima dealer they will tell you about case color differences
  8. Dec 24, 2016 at 5:37 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Why not get a more reliable battery than an optima and go with an Odyssey or a Northstar?
    abarber11, Bray1197, ChamYota and 4 others like this.
  9. Dec 24, 2016 at 5:51 PM
    Justinlhc
    It seems like more of a personal preference than actual facts behind which is more reliable. :notsure:
  10. Dec 24, 2016 at 6:18 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Unless they've really upped their game in the last year I wouldn't pay for an Optima. I've had two die early, had two family members have them die early and know of several others. I don't know anyone running Optimas anymore.
    abarber11 and shakerhood like this.
  11. Dec 24, 2016 at 6:20 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    This is a very nice setup!
  12. Dec 24, 2016 at 6:23 PM
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
  13. Dec 24, 2016 at 6:24 PM
    Pigpen
    Dan
    Northwest Montana
    Northstar AGM 27F
    spiralout462 and Norton like this.
  14. Dec 24, 2016 at 7:00 PM
    Speedytech7
    I've both had and seen Optimas fail to perform prematurely, can't say the same for my Odyssey or my buddies' Northstars. Ever since Johnson Controls bought the Optima name they seem to have gone downhill with longevity and at this point you're just paying more for a goofy looking case and a colored top.
    Bulljolly, Bray1197 and shakerhood like this.
  15. Dec 24, 2016 at 7:02 PM
    dpi
    dpi Well-Known Member
    Dan
    Tulsa, OK
    AFE Stage 2 SI CAI Banks 3" Mandrel bend Cat Back dpi Rock Sliders
    What about one of these?
    https://m.samsclub.com/ip/auto-grp-24f-34ragm-36-mo-free/prod9510083
    • 20 amp hour rate:55
    • Battery Electrolyte Composition:Glass Mat
    • Battery End Type:Top Post
    • Battery Purpose:Starting Lighting Instrumentation
    • BCI Group Size:34R
    • CA at 32 degrees F:890
    • CCA at 0 degrees F:775
    • Freight Class:65
    • Polarity:Right Positive
    • Reserve Capacity:120
    • Terminal Type:DIN
    • Volts:12
  16. Dec 24, 2016 at 7:05 PM
    EricL
    Greenwood, SC
    2015 Slowmobile
    SC2SC and Speedytech7 like this.
  17. Dec 24, 2016 at 7:05 PM
    Speedytech7
    I don't know who is making Duracell's auto batteries (they sure aren't), we have a "Duracell" motorcycle AGM battery and it has been pretty good so far, good CCA and the GoldWing seems to be happy charging it. But like I said I don't know who the real OEM of them is, it very well could be a trusted name like Odyssey or Interstate.
  18. Dec 24, 2016 at 7:05 PM
    omega supreme
    omega supreme Well-Known Member
    2011 TRD sport,lb
    None
    Optima is junk now. Odyssey.
  19. Dec 24, 2016 at 7:11 PM
    dpi
    Dan
    Tulsa, OK
    There was a review saying that Penn makes them. Whoever Penn is.
    http://www.eastpennmanufacturing.com/wp-content/uploads/Intimidator-Complete-Line-Brochure-1721.pdf
  20. Dec 24, 2016 at 7:13 PM
    Speedytech7
    Oh, then it is likely a good battery, East Penn Manufacturing makes big brands like Deka and such
