which one? Fuel Anza or Boost?
Discussion in 'Wheels & Tires' started by kevin96, Jan 24, 2014.
  1. Jan 24, 2014 at 2:52 PM
    kevin96
    kevin96 [OP] Well-Known Member
    I'm thinking about getting either the fuel black matte Anza wheel or the fuel boost. Can't make up my mind. It would be for my double cab white tacoma. What do you think would look better,im trying to go with the storm trooper look.
    Boost
    Anza
  2. Jan 25, 2014 at 8:15 AM
    N.GA Taco x3
    N.GA Taco x3 Well-Known Member
    Kevin
    Georgia
    11 Pre DC Sport- 02 Pre DC OR- 12 DCSB 4x4
    Anza. If you get these let me know please how they work out and what size, Part #, backspacing, offset, etc. that works. I'm assuming you have a 2nd gen. I'm looking at the fuel anza anthracite with black lip and i have found no one yet on these forums whom has them. Good luck and thanks.
  3. Jan 25, 2014 at 9:49 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Anza. It looks like a truck wheel. The other belongs on an escalade.
  4. Jan 25, 2014 at 9:51 AM
    4bangerowner
    4bangerowner Well-Known Member
    Eddie
    Orange county
    PreRunner 2.7 4 cyl
    none yet
    Boost. Personally I think the all black looks sweet.
  5. Jan 25, 2014 at 5:02 PM
    noahsimpson
    noahsimpson Member
    beulaville
    2014 tacoma sr5 prerunner four dour
    Link to both if you will
  6. Jan 25, 2014 at 8:26 PM
    Ridendirtywhips
    Ridendirtywhips Well-Known Member
    Sacramento
    06 prerunner
    I am looking at the same one also..
  7. Jan 26, 2014 at 7:40 AM
    dxpsman
    dxpsman Well-Known Member
    Brandon
    Oceanside, CA
    14 TRD Sport PreRunner
    AFE MACH Force-Xp 3" Cat-Back Stainless Steel Exhaust System w/Black Tips, Complete OME 3" lift, debadged, Body Armor 4x4 side steps.
    So... the Anza's just a split-spoked Trophy. I'm running Trophies on my truck to give you an idea. Not sure how the anachrite gray lip would look on a superwhite though...
  8. Jan 26, 2014 at 8:56 PM
    kevin96
    Will do, I believe ill get the anza this Tuesday if all goes well and will post pics with feedback. I'll let you know!
  9. Jan 26, 2014 at 9:00 PM
    kevin96
    I may paint the lip white since i'm trying to just go either white or black on my truck but I don't know either how'd that look, will definitely post pics and I do too love the Trophys.
  10. Jan 26, 2014 at 9:04 PM
    Houston-76
    Houston-76 Well-Known Member
    Montgomery Co Tx
    08 trd pr dcsb
    Tinted windows - weathertech floor mats - removed front mudflaps - no seatbelt chime mod - fogs on anytime mod - Borla catback exhaust - afe throttle body spacer - K&n filter - Kmc Xd hoss wheels 17X9 4.5 backspace - rubbers are 275/65 17 yokahama geolander a/t's - Maxtrac 4" lift spindles - allpro standard leafsprings - 1.25 rear wheel spacers - arctic white headlights and fogs - kings coming soon - supercharger coming later
    Boost's, no doubt ;)
  11. Jan 27, 2014 at 6:47 AM
    dxpsman
    Brandon
    Oceanside, CA
    That would definitely be unique! Keep us posted.
  12. Jan 28, 2014 at 9:29 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    I just Put on dark gray Anza's last week and I'm happy with my choice. Was kind of a rush decision since I was changing out my wide rims due to not passing safety here in Hawaii. These are 17x8.5 with -6 offset and 4.5 backspacing. The sidewall sticks out just under an inch. Here's couple pics:
  13. Jan 29, 2014 at 9:32 AM
    N.GA Taco x3
    Kevin
    Georgia
    Those look good. Did you have to buy different lug nuts such as some spline drive ones or did the factory lug nuts work? And also did you have to use hub centric rings? thanks
  14. Jan 29, 2014 at 9:37 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    I was able to use the spline drive lugs from my previous set and as far as I know (dealer installed) there was no mention of needing hub rings.
  15. Jan 29, 2014 at 6:23 PM
    kevin96
    So I was going to get the 18x9 of the anza's but apparently the offset wont work out so i'm going with the 17x8.5 and tomorrow they be installed.
  16. Jan 30, 2014 at 8:27 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Sweet, post a pic once their on!
  17. Feb 8, 2014 at 10:49 AM
    kevin96
    So after a flat tire and some fun in the mud here are the 17x8.5 Fuel Anzas sitting in some 265/70r17. I like love them so far!
    I thought this was a sign to move up to some 33's...sadly not yet
    And now I have no idea on why the pictures wont show....
  18. Feb 8, 2014 at 11:13 AM
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    Anza :cool:
    Kind of looks like the trophys.
  19. Feb 8, 2014 at 3:45 PM
    StormRunner
    StormRunner Well-Known Member
    Josh
    Austin, TX
    08 Tacoma white "n" black SR5
    I just put my boost wheels on today only have very minor rubbing do to some loose plastic.
    :cool:
  20. May 18, 2014 at 4:10 PM
    Crusher69
    Crusher69 Well-Known Member
    Sean
    Denver
    '05 Built
