Which OME Springs (Medium or Heavy)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lanceputnam, Apr 9, 2018.
  1. Apr 9, 2018 at 1:14 PM
    lanceputnam
    lanceputnam [OP] Well-Known Member
    2018 DCSB OR
    I will be ordering and installing an OME Lift. I'm torn between what springs to go with when I order the complete kit.
    Details:
    Front: I will be installing a hybrid bumper with a Warn 8000 lb winch with synthetic line.
    Rear: Normally, bed is empty. But.... when I travel it will be loaded with 250-300 lbs of gear AND I have a Turtleback Expedition Trailer which fully loaded weighs in around 2200 lbs. So I will need to be sprung in the rear to compensate for the tongue weight of the trailer.
    Thanks!
  2. Apr 9, 2018 at 9:24 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Prob 888. Lots of info in the suspension thread.
  3. Apr 9, 2018 at 10:06 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    I just ordered the ome
    jeffkimkp and cblow5 like this.
  4. Apr 9, 2018 at 10:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Front, do 888s. They'll provide roughly 2.5"-2.75" of lift on your stock truck and will lower a smidge with the bumper/winch combo. For the rear just to standard dakars. IIRC their load rating is 330 lbs over stock and will maintain a few inches of lift.
  5. Apr 9, 2018 at 10:15 PM
    mustardfj40
    mustardfj40 Active Member
    Ken
    What's load rating for the HD Dakar? Thanks
  6. Apr 9, 2018 at 10:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    mustardfj40[QUOTED] likes this.
  7. Apr 10, 2018 at 8:52 AM
    Ajsmith1990
    Ajsmith1990 Well-Known Member
    2016 Quicksand Tacoma OR DCSB
    I went with the heavy duty rear Dakar leafs and the 888 up front, all I have up front is a hidden winch mount/winch and sliders. Wish i just did the 886. Slight rake now with everything settled so I may add a 1/4” spacer on top of the struts now to level it. Rides great though! Very happy
  8. Apr 10, 2018 at 10:44 AM
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    Get the 886 they have a higher spring rate which you will benefit from after putting the bumper and winch
    cblow5 likes this.
  9. Apr 10, 2018 at 10:52 AM
    tw0leftskis
    0xApes
    Meta Verse
    With tears spring
  10. Mar 19, 2019 at 10:29 AM
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    Im also curious of this on the hd ome??
  11. Mar 19, 2019 at 12:27 PM
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    Yes it is.
  12. Mar 19, 2019 at 12:52 PM
    Mack411
    I believe I have landed quite a bit more than intended lift somehow on front and even rear with my new set up and the ride is a bit rough for what is on the truck.I currently do not have any weight in the rear but will have my rack/rtt on once rack is coated and hope to get a rear bumper/swing out but I still dont believe it should be as high as it is. My center hub to fender measurement is right at 25 inches on the rear so I'm considering removing a leaf.I'll have to do some research to see which one and how exactly it will affect everything.
  13. Mar 19, 2019 at 1:22 PM
    fortis44
    fortis44 Well-Known Member
    Colorado Springs, CO
    2016 TRDOR DCSB Black
    OME Nitros, 888s, HD Dakars, 285s
    I run 888s up front (nothing up front) and heavy duty leafs in the back. Love the setup!
    TheTacomaInn and Motomandan like this.
