Which oil filters are acceptable for 05 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adrianm2627, Feb 22, 2011.
  1. Feb 22, 2011 at 2:22 PM
    adrianm2627
    adrianm2627 [OP] Member
    California
    05 PreRunner V6 SR5
    Hello all,
    I am brand new. I have had the prepaid maintenance plan for the past 5 years so i have never changed the oil for my truck until now in a few hours.
    I went to Walmart to purchase an oil filter for my 2005 Tacoma 4x2 v6 sr5. Im not much of an enthusiast for cars, so that is all I really know about the type of Tacoma I have.
    Anyway...as i was about to change my oil i noticed that the recommended oil filter that the Walmart vehicle accessory prompt computer they have listed that I buy a much small filter than the existing oil filter. I did not notice this until after the fact I drove and went home and opened the hood, my mistake.
    The one I got at Walmart was the Fram HM3614. The existing one is a HM 22A22 Toyota Parts (is all i can really see).
    So to save a trip back to Walmart, Is it okay, if the oil filter is replaced with a slightly smaller one (the Fram HM3614)?
  2. Feb 22, 2011 at 2:26 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. Feb 22, 2011 at 2:32 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Frams not that great. If you run it, change it out in 3,000 miles.
    The Toyota one is good, but the K&N and Mobil 1 (same filters) and Wix/Napa Gold are also very good filters. I think Bosch is the same as the Wix design too, but not 100% sure.
    I get my oil change supplies at Autozone where they usually have a 5 qt oil jug of synthetic and a free K&N/M1 filter for under $30
  4. Feb 22, 2011 at 3:18 PM
    adrianm2627
    California
    05 PreRunner V6 SR5
    Cool.
    Thanks guys, for the input.
    Much appreciated!
  5. Feb 22, 2011 at 3:23 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  6. Feb 22, 2011 at 3:29 PM
    KevLot17
    KevLot17 Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
    The new Bosch is 'supposedly the best.. this is what ive run since i bought it new, now at 20K.. and i use Valvoline Synpower full synthetic.. i am switching to Mobil in 2K miles! but i will stick with my Bosch!.. oh and as for the K&N... ive heard nothing but bad about it.. and NAPA gold was the best on the market before i heard about the bosch...
  7. Feb 22, 2011 at 10:45 PM
    Janster
    Jandy
    Lancaster, PA
    Gave up what? :confused:
  8. Feb 22, 2011 at 11:00 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    You can get the OEM filter from the dealer for around $4-$5. The more you buy, the better the discount. I bought a case & they worked out to I think around $3.50 each. Also buy the plug crush washers.
  9. Feb 23, 2011 at 1:48 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I think I am going to have to go get a box of OEM filters, they seem to be the best quality, and are way cheaper than the mobile 1 filters? D:
  10. Feb 23, 2011 at 1:57 AM
    mixplatexr
    mixplatexr NGDEUCE
    Palani
    Wahiawa, HI
    2007, SWB X-Runner
    RGM, FLM, Morimoto Mini D2S Retros, BSP/SMOKE Tinted Taillights/3RD Brake Light, SS W/3INCH REAR, QA1s, WeatherTech Vent Visors, WeatherTech Digifit Floormats, Kenwood DDX719, 2 RF HE Punch 12s, aFe Stage 2 SI, NST Crank Pulley, DTLT Headers, SpinTech Super Pro Street, URD SS W/Coupe Arm, 18x9.5 White XXR 522, Viper 5901
    I went with the OEM filter when I do my oil change
  11. Feb 23, 2011 at 2:05 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    I am NEVER going to tell anybody what brand of oil filter I use, but I got 2 years of free service so I will hold my nose when the dealer installs a factory Toyota Filter!
  12. Feb 23, 2011 at 4:25 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The NAPA gold line is made by Wix and uses the same part numbers...I got a Master Pack (case of 12) 1348 filters, will fit the Tacoma and the wife's Jeep Sahara. No more using FRAMs from wally world to avoid making a special trip to the Friendly Local Auto Parts Store (FLAP)...
    The big key is keeping the oil clean. If you can read the dipstick through the oil, you should be good.
    Howard
  13. Feb 23, 2011 at 4:37 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    The oem filters are decent and you can't go wrong using them, but are not the best quality on the market
