Which obd2 scanner is the best value?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, May 19, 2017.
  1. Mar 7, 2021 at 10:25 AM
    #61
    BuelltonTacoma
    BuelltonTacoma Well-Known Member
    2000 Tacoma 4x4 V6 3.4L MT
  2. Mar 9, 2021 at 7:02 AM
    #62
    AZDude
    AZDude Well-Known Member
    1996 Tacoma base
  3. Mar 9, 2021 at 4:17 PM
    #63
    BuelltonTacoma
    It shows live engine feedback but I’m not sure how detailed it gets w the sensors. I have mainly used it to confirm and clear a phantom p0420 that trips once in a while. If there’s a specific sensor reading you’re looking for I can plug it in tonight
  4. Mar 9, 2021 at 4:38 PM
    #64
    AZDude
    1996 Tacoma base
    Thanks for doing this! Can you check if it can graph the voltage O2 sensors? I think that will be beneficial for troubleshooting future emission problems.
  5. Mar 10, 2021 at 9:57 AM
    #65
    BuelltonTacoma
    There is no ability to graph O2 sensors. Just this “status” — my reading of INC seems . . . well, not good lol then again, I’ve been called worse. Hope that helps!
  6. Nov 12, 2021 at 12:20 PM
    #66
    nismo14
    nismo14 Well-Known Member
    Hawaii
    2015 4x4 DCLB TRD Sport
  7. Nov 12, 2021 at 2:58 PM
    #67
    reallifeonhold
    reallifeonhold Well-Known Member
    Travis
    2004 4WD 5MT
    I've been pretty happy using the Torque app. It was a little more expensive but I went with a Bluetooth scanner (vLinker MC) that has a sleep mode so I can leave it plugged into the OBD port at all times.
    nismo14[QUOTED] likes this.
  8. Nov 14, 2021 at 2:53 PM
    #68
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    Yeah I’ve use it on my Subaru Impreza and Forester and a couple of my friends vehicles, Jeep and a Chevy truck and the vehicle can be cleared while going down the road which is better than my tethered scanner which has to be not moving/running.
