Which models have which size Differential
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 25, 2015.
  1. Aug 25, 2015 at 10:08 PM
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    So after reading a few threads with people asking/curious about this, I thought I'd check and clear it up.
    L4 5MT: 8.8" 3.91:1 without Locker
    L4 6AT: 8.0" 4.30:1 without Locker
    V6 6MT Except TRD Off-Road: 8.8" 4.30:1 without Locker
    V6 6MT TRD Off-Road: 8.8" 4.30:1 with Locker
    V6 6AT Except TRD Off-Road: 8.0" 3.91:1 without Locker
    V6 6AT TRD Off-Road: 8.8" 3.91:1 with Locker
    Summary: All manual transmission models have the 8.8" differential (even the 2.7). For automatic transmission models, only the TRD OR gets the 8.8" diff, all other automatic transmission models have the 8.0" diff.
    Jeff
    Bronxguy, TexasG, Shveet and 16 others like this.
  2. Aug 25, 2015 at 10:14 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    woohoo. thank you Jeff
    NTSALL4 likes this.
  3. Aug 25, 2015 at 10:26 PM
    tubesock
    tubesock Well-Known Member
    What does this say about adding a toyota locker to a 8.8" differential that didn't come with one? Would it basically be a drop in component or is the differential case different, or the gearsets?
    AdventureKid likes this.
  4. Aug 26, 2015 at 12:00 AM
    Jeff Lange
    Calgary, Canada
    The rear axle housing is the same with or without diff lock, as are the ring & pinion sets. The differential housing/pumpkin is different to allow the lock actuator coil wiring through and provides a mounting point for the position switch/sensor.
    Jeff
    jmneill and shotgunbilly420 like this.
  5. Aug 26, 2015 at 1:09 AM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    So Toyota is going back to the 8" diff on non TRD OR Models instead of the 8.4" that is currently used? Seems odd if it is true. Also, if the TRD OR uses an 8.8, is it a mechanical locker or computer controlled diff via brakes and such? And last, the 8" axle housings are not the same regardless of if it has a locker or not. They are the same basic housing and a non locker housing can be modified to fit a locked 3rd member, but it isn't simply a pull and swap deal as the flange on the locker housing is cut to allow clearance for the locking mechanism etc.
  6. Aug 26, 2015 at 1:49 AM
    tubesock
    You're a wealth of information. Thanks for taking the time.
    What is the difference between an axle housing and a differential housing? I always thought of those as the same thing.
    I'm dreaming of a world where the only difference between the 8.8" 4.30 axle with and without the locker is that the locker components are simply missing, and wiring ports plugged with a fancy cork. Much like how the old SR V6 didn't come with fogs but was wired for them. You just had to remove the plastic inserts and plug in factory fogs, the relay, and a switch. If only it could be so simple.
  7. Aug 26, 2015 at 7:09 AM
    Jeff Lange
    Calgary, Canada
    Maybe I should have said differential carrier. The axle housing is the rear end minus the differential, the differential is the pumpkin/what bolts into the axle housing.
    Jeff
    shotgunbilly420 likes this.
  8. Aug 26, 2015 at 7:10 AM
    cgalloni
    cgalloni Well-Known Member
    Thanks Jeff, Another reason to get the M/T
    OG_Tacoma and scottalot like this.
  9. Aug 26, 2015 at 7:24 AM
    Jeff Lange
    Calgary, Canada
    As I said in the other thread, the 8.4" is actually an 8.0" ring gear. Toyota does not call it an 8.4" It's the same size ring gear as the 8.0" and it is an 8.0". Ring gears are not measured on the OD. It has 12 bolts instead of 10 and a slightly different bearing cap design, but they're both the same size.
    The differential on the new one is not smaller.
    Jeff
    jmneill likes this.
  10. Aug 27, 2015 at 12:32 AM
    Z50king
    Eric
    Southern California
    Stock and loving it
    The rear end of the OR is a mechanical locker. The front end is an LSD controlled by the brakes
  11. Jun 2, 2016 at 8:22 PM
    Haikin
    Haikin Well-Known Member
    Jeff can you tell me the fluid capacity of my rear diff? I can't seem to find an exact answer. '16 OR 4x4 AT.
    Thank you
    Pic of door jam sticker
  12. Oct 2, 2019 at 3:50 AM
    danthemanx07
    danthemanx07 Well-Known Member
    Daniel
    New Bern, NC
    So will the 3rd gen 8.0” carriers fit in older 8.0” housings? Or is the 3rd gen 8.0” akin to the so-called 8.4” differential?
  13. Oct 2, 2019 at 4:09 AM
    Stitz
    Stitz Well-Known Member
    South Jersey
    2024 TRD OR Supersonic
    Just curious, why would you be looking to swap 3rd gen gears into an older truck? Why not just get aftermarket parts that you know will fit
  14. Oct 2, 2019 at 4:18 AM
    danthemanx07
    Daniel
    New Bern, NC
    Picking up a used 3rd member can be a cheap and easy way to regear - 3.73 to 4.30 for example.
    CBrob and Thuguon2.7 like this.
  15. Oct 2, 2019 at 6:16 AM
    Stitz
    South Jersey
    gotcha...didn't even think about re-gearing
    Thuguon2.7 likes this.
  16. Oct 5, 2021 at 9:55 AM
    89hatcher
    89hatcher Well-Known Member
    Wonder if the older 8.0 can fit on the newer tacomas?
  17. Feb 15, 2022 at 4:47 PM
    Cannonballpoolsfl
    Cannonballpoolsfl Member
    Jim
    Florida land of the FREE
    98 4WD Tacoma SR5. Beat to hell, but no rust! 343,727 miles
    None
    Hello all.
    Was hoping I can get some info from the experts.
    I have a 98, SR5, 4x4, 6 cylinder, manual transmission, with manual hub locks, NOT TRD, 2.5 inch lift.
    Here's what I think must have happened. Without my knowing, the needle bearings on the drivers side of the my front diff (the ones ECGS makes the replacement bushing for) exploded long ago which allowed the splined input hub of the CV axle to work its way loose from the front diff. By continuing to drive the truck like this for who knows how long, with the CV axle just rolling around in the drivers side diff opening, the CV axle wore that opening out so much it's no longer round and trying to install the ECGS Clamshell Bushing is impossible because the opening is so wallowed out the bushing has nothing to hold it in place. Not to mention the seals were disintegrated and sand and water got in there etc. It's a brown mess.
    I'm assuming I need to replace the front diff.
    The code on my door sticker says AT/M B06A/ R150F so from what I found, the gear ratio should be 3.91.
    This ain't easy to find.
    I have found 1 front diff for 98 Tacoma with 3.91 ratio but it has automatic disconnect. I've seen on YouTube that this can work if I work a little magic on the automatic disconnect. Can I do that and will it work?
    The other issue that was brought to my attention was in the first post of this page. According to the OP, I have an 8.8 inch carrier. If the front diff I found online to replace my current worn out diff is from an automatic transmission that would make it and 8.0. Would I still be able to use it as a replacement or would it be too narrow or simply unusable?
    I have asked the question from the seller if the diff is from an automatic or standard transmission, but have not heard back yet.
    I know almost nothing about this stuff except what I already mentioned so I'm sure I'll have many more questions if anyone replies to my posting.
    Thanks, and I hope someone can help.
    Jim
  18. Feb 15, 2022 at 5:26 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Thank you
  19. Feb 15, 2022 at 5:33 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Six year old thread lol.
  20. Apr 10, 2022 at 11:17 PM
    Jeff Lange
    Calgary, Canada
    You're welcome.
    Jeff
