Which HID conversion kit is the brightest and best
Discussion in 'Georgia' started by WillRedd, Sep 4, 2015.
  1. Sep 4, 2015 at 4:07 PM
    WillRedd
    WillRedd [OP] Member
    Will
    Athens, Georgia
    2010 Tacoma TRD Fully loaded
    Z&N cold air intake , chrome bull bar , 2. K C off road lights
    I rode in a tundra that had been converted to HID and it was unbelievable but he had already replaced 1 ballast and was getting ready to replace both ballast and I keep reading a bunch of different things but I want to get it right the first time help me!!! Thanks
  2. Sep 5, 2015 at 3:30 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    If you really want to do it right the first time you should go for a full retrofit. It'll cost you around $900 or so but if you sell your OEM housings you can recoup a lot of that, and your lighting will be safe for other drivers. HIDs may look good too you behind the wheel but other drivers are saying "fuck that guy" because the light is scattered all over the damn place like Rock Lobster said. On top of that these cheap HID kits are likely to fail as your buddy has found out.
    Not to mention a full projector retrofit is going to look badass.
  3. Sep 6, 2015 at 1:23 PM
    WillRedd
    Will
    Athens, Georgia
    Thanks man, I have been looking at 2 different housings, one smoke or slightly tinted and 1 chrome more like the stock housing would love if anyone had pictures of there Tacoma's with a andel eye halo aftermarket housing for the projector style housing for his lights. Thank you so much for your help!
  4. Nov 18, 2015 at 4:01 AM
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    My projector retrofit was nowhere near $900 more like $300. I got it thru @TRSAndrew who works at the Retrofit Source. They give a TW discount. They are local in Atlanta you can go pick up your items there in the ship. The light output is astounding and will blow away the stock configuration I got the 55w ballast, mini projectors, Apollo shrouds and the switchback halos! The components are top notch and Andrew was great to work with.
    Here are pictures of the retrofit with just the halos on showing the switchback function etc.
    Large likes this.
  5. Nov 18, 2015 at 4:03 AM
    Large
    Large Red
    I am sure he was meaning for someone to do it and sell it instead of all DIY material.
  6. Nov 18, 2015 at 4:25 AM
    JohnNP
    Hobe Sound, FL
    Ha I hope so otherwise he got it up the tailpipe :)
    If the OP doesn't want to DIY I believe @TRSAndrew offers that as a service for a fee and can do some pretty neat things to the projectors and bowls and housings etc.
  7. Nov 18, 2015 at 4:28 AM
    JdevTac
    Josh
    GA/WA
    2nd gen
    Yeah I was referring to if you bought them pre-done/all in by someone here on TW. $900 just for parts would be a damn ripoff and no one would ever retrofit except die hard headlight nuts.
