Which headlight assembly?
Discussion in 'Lighting' started by toystory, Jun 3, 2020.
  1. Jun 3, 2020 at 5:31 AM
    toystory
    toystory [OP] Active Member
    RB
    2014 reg cab 4cyl.
    3" fox 2.0 shox, SPC uca's, 3" expedition leaf, Walker Evans wheels, ARE topper
    too lazy to scroll thru 10,000 pages...
    asking for insight on aftermarket headlight assemblies...
    I'm seeing some questionable junk out there.
    anybody have some results to share on which headlight assembly product is most worthy?
  2. Jun 3, 2020 at 6:07 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    What exactly are you wanting out of them?
  3. Jun 3, 2020 at 6:14 AM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Do you just have a broken headlight, or looking for colors, BLM, or leds or something else?
  4. Jun 3, 2020 at 6:49 AM
    toystory
    RB
    2014 reg cab 4cyl.
    got a taste of a LED light bar, now wanting to boost up actual headlite performance, tried a replacement bulb that was given to me, didn't fit, learned later, maybe best not to do LED bulb in a halogen reflector anyway...
    have been looking at the sea of replacements along lines of projection beam, with LED halo...not seeing anything but a sea of varying prices, with little product description...
  5. Jun 3, 2020 at 9:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Few replacement LEDs actually work well in a projector assembly, as most result in the typical loss of focus and loss of distance projection as they are just too large.
    See this thread, specifically post #3:
    https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
    Hikari Ultras are the recommended replacement LED that performs best in a 3rd Gen Projector. If you want a full replacement LED assembly I’d look at Morimoto (also in post #3) or OEM Toyota LED headlights. Most replacement headlight assemblies are poor quality and perform worse than stock, so be careful what you buy. Something off the shelf with halos is unlikely to perform well. If you want to get that kind of look your best bet is going to be a custom retrofit build.
  6. Jun 4, 2020 at 7:07 AM
    TRSAndrew
    ATL
    Have you tested the GTR Ultra 2's yet? They're pretty strong performers
  7. Jun 4, 2020 at 2:28 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    See post #2816. Spoiler Alert: They're awful.
    Toy_Runner likes this.
  8. Jun 4, 2020 at 2:58 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, just recently actually. They are among the highest output but the focus is among the worst, the product is way too large and the emitters are oversized. They don't do a good job of replicating a halogen and as a result shift the beam pattern to produce more foreground light and don't keep the peak intensity up near the cut off where it should be for good distance light. When doing an extended distance performance test they are easily outperformed by the Hikari Ultras which are the best focused LEDs I have tried to date.
  9. Jun 4, 2020 at 3:59 PM
    Too Stroked
    Tom
    And don't forget, the halogens easily outperformed both of those LEDs.
    crashnburn80[QUOTED] likes this.
  10. Jun 4, 2020 at 4:01 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    2020 OEM LED heads are the best looking.
  11. Jun 5, 2020 at 3:15 AM
    TRSAndrew
    ATL
    They're not awful, perhaps just not best in these H11 projectors. Just wondering! :)
  12. Jun 5, 2020 at 3:30 AM
    Too Stroked
    Tom
    Awful in housings designed for halogens - which is pretty much the majority of applications for them. And as @crashnburn80 said, the design is awful too.
    crashnburn80 likes this.
  13. Jun 5, 2020 at 2:19 PM
    Tacospike
    Two Trucks
  14. Jun 5, 2020 at 2:40 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not a very good comparison when the lights are not adjusted properly on the trucks. From the video the AlphaRex actually look very poor performing, drastically excessive foreground light with less distance light than the Morimotos. Yeah they point to it and say look how much brighter it is, but it is brighter in the wrong spot. Massive amounts of short range foreground light is exactly what you want to avoid in a headlight, as it severely limits your distance vision and is not how a headlight is supposed to work. In the video the Morimotos have a much smoother pattern that extends further, which is better. The video is just a marketing video and not at all a scientific approach to evaluating what actually makes for a good headlight.
  15. Jun 5, 2020 at 2:46 PM
    Tacospike
    Two Trucks
    I agree completely. An abundance of variables come to play in the specs and tolerances in light spots and adjustment points.
    just a template reference point since both of these are becoming what seems to be a majority go to after market fully enclosed headlight.
    I’m not one to promote either, as I just ordered a set of OEM 2020 led headlights today, just spreading some information as I see more awareness of upcomers.
  16. Jun 5, 2020 at 10:05 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I think the more appropriate question is, how much are you willing to spend?
    BizzyB726 likes this.
  17. Jun 11, 2020 at 6:20 AM
    GlockLesnar
    GlockLesnar Well-Known Member
    Jon
    2020 TRD Off-road
    If you don’t mind me asking how much did you pay for them?
