which fuses control tail lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Nov 19, 2012.
  1. Nov 19, 2012 at 7:42 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    i can only see the head light set of 4 fuses. but nothing on the diagram located on the inside of the fuse box lid indicates tail lights.
    can anybody point to how to locate the fuses that control tail lights?
    thanks
  2. Nov 19, 2012 at 7:44 PM
    FFRNDAN
    FFRNDAN Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    If you are referring to the tail lights for the truck, and not the trailer, its the illumination fuse I believe its called. Same fuse powers your guage backlighting. Its under the steering wheel behind the little cubby bin. Ask me how I know.
  3. Nov 19, 2012 at 7:47 PM
    foampile
    Mid-Atlantic
    yes, for the truck. so are you saying it is not in the regular fuse box that's under the hood on the driver's side?
  4. Nov 19, 2012 at 7:48 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    From the 2011 manual.
    Toyota Tacoma 2011 Fuses.pdf
    Frank
  5. Nov 19, 2012 at 7:49 PM
    foampile
    Mid-Atlantic
    basically, my tail lights and my stop light is out. the rear blinkers are fine on both sides. i also have a set of 4 wires (2 black and 2 red) that power the stop light on my camper as well as a little light inside the camper (2 for each, i guess). those are also out, i tried with the multimeter.
  6. Nov 19, 2012 at 7:52 PM
    foampile
    Mid-Atlantic
    thanks, i still can't figure which are the tail lights on the truck -- the ones that are on when you drive at night. i only see trailer tail, which i assume is for the trailer. i need just the regular truck tail lights.
  7. Nov 19, 2012 at 7:53 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Tail light fuse in the cab on page 415.
    Frank
  8. Nov 19, 2012 at 9:08 PM
    foampile
    Mid-Atlantic
    yep, that was it. now they are all working ;)
  9. May 6, 2017 at 12:03 AM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    It's 2:00 AM and I'm pulled over on the side of the road trying to figure this one out. And of course I think "google search" instead of "open the damned glove box and look at the owner's manual." :D
    Glad TW is here for me :) yay!
  10. May 6, 2017 at 12:07 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    lucky it was a 6 speed. if it was an auto, the transmission would be locked in park. Same fuse is part of that safety system.
