Which front camera mod?...Car Solutions or Anytime?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pogue_Mahone, Sep 1, 2020.
  1. Sep 1, 2020 at 5:58 AM
    Pogue_Mahone
    Pogue_Mahone [OP] Well-Known Member
    2020 TRD Off Road 4X4 DCLB
    Which one do you guys recommend for a 2020 Taco? The CS one seems easier since I dont have to get under my dash to wire up a separate switch. Any downsides other than the camera comes on for a little while when you put it in drive?
  2. Sep 1, 2020 at 6:01 AM
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    I was in this position. All of the units to get a front camera working with the factory head unit represent a fair amount of what it would take to get an aftermarket head unit that already has this functionality. Ended up going that route and got all the other benefits therein.
    kbenn likes this.
  3. Sep 1, 2020 at 6:08 AM
    Pogue_Mahone
    What did you end up going with? Does replacing the Toyota Entune unit have any downsides as far as normal operation of the truck?
  4. Sep 1, 2020 at 6:37 AM
    TheSt|G
    CSL Bits
  5. Dec 3, 2020 at 7:38 PM
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    Does this support an “anytime” feature where you can turn the front or rear camera on at any time?
  6. Dec 3, 2020 at 8:32 PM
    sak29
    sak29 Member
    I would stay away from "anytime" I made a purchase with them and received a broken switch. When attempting to get the problem fixed i was just ignored and not responded to. I ended up getting car solutions. I have zero issues with it and it was an easy install.
    IndyTac likes this.
  7. Dec 3, 2020 at 8:37 PM
    S2KON2
    S2KON2 Well-Known Member
    So Cal (SFV)
    CS gets my vote. Quick double click of MODE and camera is on. No fussing around for button.
    Having the camera turn on when put into drive is not necessarily a bad thing. Helps you see any kids or pets that could be in front, out of view.
  8. Dec 3, 2020 at 9:14 PM
    TheSt|G
    CSL Bits
    Yes.
    IndyTac[QUOTED] likes this.
  9. Dec 4, 2020 at 12:58 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    @Pogue_Mahone
    I went with a stand alone setup, for many reasons. Here's what I did:
    Stand alone Front Camera 2019 SR5
  10. Dec 4, 2020 at 7:21 AM
    IndyTac
    Indianapolis
    Did you use the actual camera that CS sells? If so, how’s the quality?
  11. Dec 4, 2020 at 7:27 AM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    i have the anytime backup camera unit because i prefer the switch (i want my truck to feel like a spaceship). it's been over 2 years now and no complaints.
    Justinhisle likes this.
  12. Dec 4, 2020 at 3:07 PM
    S2KON2
    So Cal (SFV)
    No. Ended up buying a Natika on Amazon. Worked really well for exactly 1 yr. Then just died. Here's the link to it.
    Then I bought a cheaper one. DO NOT buy this. FOV is pretty bad. I'm considering buying another Natika.
  13. Dec 4, 2020 at 4:15 PM
    Pnciv66
    Pnciv66 Well-Known Member
    Louisiana
    Anytime for me mainly bc I want the switch. Taking apart the dash radio area is not that hard just held on my clips. I followed some of dash meso install guides before I did mine.
  14. Dec 4, 2020 at 4:21 PM
    IndyTac
    Indianapolis
    Excellent, thanks. Just bought the Natika. Seemed like best available option.
  15. Dec 4, 2020 at 6:25 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’ve had both. Started with the ABC with a Natika. All worked great. Decided to upgrade to the CS and kept the same camera. Really happy still.
    Great camera choice!
  16. Dec 5, 2020 at 3:17 AM
    CG256
    CG256 Well-Known Member
    '19 TRD OR
    I bought the Car Solutions for when I'm off roading. I liked not having to take my hands off the wheel to turn the camera on.
    I regret the Natika camera I bought. It's angle is too wide so it distorts the picture so much that it is difficult to use off road.
  17. Dec 5, 2020 at 3:26 AM
    MaxT
    MaxT MaxT
    St Marys, GA
    2022 Blue Crush TRD Sport MT
    Go Rhino Power Steps, MESO Puddle Pods, KDMAX Tune, Accumulator delete MOD, Mud Flaps, OEM Power Tailgate Lock, Hood Struts, Kicker Key Amp, New Speakers, New Shift Knob, OEM Bed Mat, MESO Total LED Taillights, LED 3RD Brake Light, Hitch 4TH Brake/Running/Backup Light, Scan Gauge III, Borla Cat-Back Exhaust, Jowett Oil Filter Cap, MESO Map and Dome Dual-Color Lights, Driver's Side Grab Handle Future: OEM LED Headlights, Peragon Bed Cover, Borla Exhaust Mid-Pipes
    Car Solutions and Natika camera in my 2021.
    Put the same system in my wife's RAV4 2 years ago, and it is still working great!
  18. Dec 5, 2020 at 5:59 AM
    mdh_us
    mdh_us Well-Known Member
    Which head unit do you have in your 2021, I have what I think is the basic one and wonder if the Car Solutions will work? How did you mount the front camera?
  19. Dec 5, 2020 at 6:04 AM
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    I like the switch of the anytime instead of the CS version. Upgraded to a nakita camera and made my own bracket to work on the 2020 TRD grill.
    Figure out how you would like to activate the camera. Getting to where to plug in the switch isn’t hard at all to install in the dash.
  20. Dec 5, 2020 at 6:19 AM
    MaxT
    MaxT MaxT
    St Marys, GA
    I have the JBL system. There is an actual camera mount that you can buy that screws right into the standard grill. I ordered that and it was easy to install, two screws and grill was already setup to accept it.
    There is a video on installing the CS system. Let me know if you need any hints.
