Which EMU spring 2880 or 2881?
Discussion in '1st Gen. Tacomas (1995-2004)' started by skycamper, Nov 13, 2021.
  1. Nov 16, 2021 at 2:51 PM
    skycamper
    skycamper [OP] Well-Known Member
    Abraham
    2001 Tacoma 4x4 2.7L Ext Cab
    3" Lift w/ 5100's and EMU 882 springs , General Leaf Spring and AAL in rear with 5100. Diff drop, carrier drop, 3 degee axle shims. Trail Gear Tube Bumper. Tundra brake mod.
    Whats with greaseable shackles being $200 bucks?? This is the one they said I needed for stock springs: Thanks for the heads up on loosening them while greasing.
  2. Nov 16, 2021 at 2:58 PM
    bbeyota
    bbeyota Active Member
    Sacramento
    04 Tacoma 2.7
    See link below for the ones that were included in my kit. The ones I got were gs12 (no lift). I had no idea they were that expensive even at $120.
    skycamper[QUOTED][OP] likes this.
  3. Nov 16, 2021 at 3:16 PM
    skycamper
    Abraham
    I went over those with Cory over at Wheelers and the description says:
    • For use with OME CS046R Dakar leaf springs
    **NOTE: Requires Old Man Emu Leaf Spring Bushing Set (SB88) or Wheeler's Leaf Spring Bushing Set available separately
    But my springs are from General Spring and have bushings that need to be popped out and the link I provided has bushings in it. The one you link is for Dakars , is that what you have?
  4. Nov 16, 2021 at 4:12 PM
    bbeyota
    Sacramento
    04 Tacoma 2.7
    Yes, sorry they were for Dakar leaf set. Sucks the general ones are $200. I bought from Wheelers due to their set came with the shackles. Cory and the crew are an awesome resource. Also wanted to mention that if this all doesn't work out, I saved my 881s and are just sitting in my shed. You can have them if u want. My wife wants me to chuck them in the trash.
    skycamper[OP] likes this.
  5. Nov 16, 2021 at 4:28 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    Ive used the Hankook Dynapro AT and currently have Falken Wildpeak ATs, both are great but the Falkens are narrower and spin up faster, zero road noise.
  6. Nov 16, 2021 at 7:38 PM
    skycamper
    Abraham
    Also, your build is awesome, how is
    Probably more than I deserve sir!! Id take you up on that but id have to buy them from ya! id even buy them to keep just as spares! Lol.
  7. Nov 16, 2021 at 7:39 PM
    skycamper
    Abraham
    Im currently running that same hankook tire and I have zero complaints about them.
  8. Nov 16, 2021 at 10:23 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    So did I, but i have a regular cab 2.7 which is significantly lighter and I only seemed to get an inch or so. Rides good though. I wonder if you’re on a different clip than the lowest?
  9. Nov 17, 2021 at 4:17 AM
    FinsFan909
    FinsFan909 Well-Known Member
    1996 4x4 Tacoma V6
    No Im on the lowest. The previous owner never changed the shocks or coils so I’m thinking it was just time. I can drive through crappy roads and I’m not jumping all around anymore lol
  10. Nov 17, 2021 at 11:03 AM
    skycamper
    Abraham
    Im having trouble sourcing the stock BFG K02 in my area. However the larger 265/75/16 version is in stock. What do you think about the problems this would have as far as rubbing despite the lift? MPG? Power? Worth it? Any pluses here?
  11. Nov 17, 2021 at 11:57 AM
    bbeyota
    Sacramento
    04 Tacoma 2.7
    I had the 265/75/16 version. There was rubbing at stock height at full lock (did not effect performance), no rubbing at all with 881s/Dakar (no AAL), minor but noticeable power loss (no need to regear), negligible MPG changes, and worth it? Yes. The 2.7 can handle these E rated tires but effected the performance enough that I knew regearing was a must with 33s.
  12. Nov 17, 2021 at 12:10 PM
    skycamper
    Abraham
    Oh thats great to hear! I was running 245/70/16 so I think I will notice some power loss. Great deal at Costco $876.03 after $110 special and 2% cash back on their credit card we use. I think it will be worth it! I hear mostly good things about this tire.
  13. Dec 6, 2024 at 10:06 AM
    Javi's Taco
    Javi's Taco Active Member
    Did you get new shocks all around?
    Did you compress the taller 882s to fit your current shocks?
    Did you add the extra leaf and kept your existing rear shocks?
