Which Drop Hitch Should I Buy?
Discussion in 'Towing' started by Naterx, Feb 6, 2025.
  1. Feb 6, 2025 at 1:16 PM
    Naterx
    Naterx [OP] Well-Known Member
    Nathan
    2015 TRD Sport
    I recently inherited a pop up tent trailer, and I would like to use my Tacoma to tow it. I have never towed anything before so forgive my ignorance, but since my truck is on a 3 inch lift a standard hitch won’t work I assume. Do I need a drop hitch? And if so I’d love some recommendations.
  2. Feb 6, 2025 at 1:35 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Your trailer tongue sits level @ X (lets say 10"). Your trucks ball, shall we say, sits @ X (lets say 12")...
    12" - 10" = (2 inch drop hitch)
  3. Feb 6, 2025 at 1:41 PM
    545 Well-Known Member
    2015 Access Cab
    For stock Tacomas, 2” drop is usually good for single axle trailers, while most dual axle trailers sit higher, a straight one is better, like a triball hitch
    If you are 3” higher than stock in the rear, a 4” or 5” drop hitch would be good for a single axle trailers
  4. Feb 6, 2025 at 1:46 PM
    Naterx
    Nathan
    2015 TRD Sport
    aren't most of them adjustable?
  5. Feb 6, 2025 at 2:00 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    A non adjustable is usually cheaper, and sometimes stronger. I'm running an 11 inch drop on my Taco, thanks to a high clearance bumper putting my receiver up behind my license plate.
  6. Feb 6, 2025 at 2:01 PM
    Naterx
    Nathan
    2015 TRD Sport
    love your rig. what leaf springs are you running to carry all that?
    YF_Ryan[QUOTED] likes this.
  7. Feb 6, 2025 at 2:02 PM
    YF_Ryan
    Kent, WA
    Deaver U402 expedition Stage 3.
  8. Feb 6, 2025 at 2:06 PM
    2015 Access Cab
    Nah, most are fixed
    If you only have one trailer, just measure and get a regular drop hitch, much cheaper
    1 Limited Toyota and YF_Ryan like this.
  9. Feb 7, 2025 at 8:40 AM
    LFOD
    LFOD Well-Known Member
    2021 SR5 DCSB
    It's best to actually measure everything. Etrailer has a good write-up and will get you close. Depending on the tongue weight of the trailer there will be sag once you are hooked up. If you are between available sizes I would go with the shorter to account for sag. Adjustable is nice if you want to buy one and be covered for all situations but not needed if you only tow one trailer and don't plan to change.
    https://www.etrailer.com/faq-ballmount.aspx
    Double-check the weight rating of the ball mount you are buying. They may look similar but have different weight ratings. All 2" should work for a light trailer but is good to know what you are rated for.
    CVCV likes this.
  10. Feb 12, 2025 at 1:05 PM
    yota924x4
    yota924x4 Well-Known Member
    Pgh
    23 pro 6mt
    I use a 4" drop on my camper but every trailer and truck is different. Whatever makes it run level
  11. Feb 12, 2025 at 5:16 PM
    1 Limited Toyota
    California
    08 XRunner
    Ha ha this is a 6" flipped drop on y old TDI SportWagen
    Toyko Joe likes this.
