Which Coolant?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by No Shoes Nation, Dec 23, 2021.
  1. Dec 23, 2021 at 3:10 PM
    No Shoes Nation
    No Shoes Nation [OP] Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Need to top off
    Currently has factory stuff in it.
    What is the factory/aftermarket stuff to use. Don’t want the pre diluted. I can add distilled water myself
    Brand name of best stuff to use? thanks y’all merry Christmas
    Biscuits, NAAC3TACO and IvanhoeTaco like this.
  2. Dec 23, 2021 at 3:12 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    whatever pink toyota coolant autozone has. I prefer zerex brand since that is what Mercedes specifies for coolant my old benz
    JimIowa, Geeves77 and NAAC3TACO like this.
  3. Dec 23, 2021 at 3:12 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Toyota super long life pink coolant. Xerex and Beck Arnley make it aftermarket. I’m sure others do too.
    Geeves77 likes this.
  4. Dec 23, 2021 at 3:15 PM
    No Shoes Nation
    Give me something that is NOT pre diluted
    Thank u
  5. Dec 23, 2021 at 3:22 PM
    No Shoes Nation
    That’s what I’m finding, bastards.
    So I gotta pay $30 for half gallon of antifreeze and half gallon of water, bastards.
    6 gearT444E and whatstcp like this.
  6. Dec 23, 2021 at 3:24 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    $17.99 at NAPA
    https://www.napaonline.com/en/p/ZRX675130
  7. Dec 23, 2021 at 3:46 PM
    No Shoes Nation
    Back
    1. [​IMG]
      So this is undiluted
      It is red
      It is said it turns pink when diluted
      Should I use this
  8. Dec 23, 2021 at 3:47 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    That’s the older Toyota coolant from the nineties. Not the same. My 98 Corolla used that.
  9. Dec 23, 2021 at 3:54 PM
    No Shoes Nation
    Looks like Napa tomorrow thanks y’all
    Luv ya
    Biscuits and NAAC3TACO like this.
  10. Dec 23, 2021 at 4:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    po35042, TnShooter and NAAC3TACO like this.
  11. Dec 23, 2021 at 5:02 PM
    No Shoes Nation
    I peeked down the rabbit hole, that hole is deep, and gave up
    Tomato tamato why did the simple things in life become so complicated
    Still going to NAPA tomorrow
    tacotoe and JimIowa like this.
  12. Dec 23, 2021 at 7:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Most places will have both concentrate and pre-mix on the shelf
    tacotoe and Biscuits like this.
  13. Dec 24, 2021 at 10:04 PM
    TacoTuesday1
    FL
    what would happen if you emptied the system and switched to European pink stuff
    Audi/VW/Mercedes?/Porsche G13
    they use similar metals. Iron or aluminum blocks, aluminum heads, etc.
    Funch likes this.
  14. Dec 25, 2021 at 3:59 AM
    slayer fan
    slayer fan Well-Known Member
    tommy
    ky
    2013 tacoma 4x4 regular cab
    2" lift.
    preston green is what i use in both my tacomas. i drain it every other year and put new in. it's cheap and readily available.
    Rob MacRuger likes this.
  15. Jan 23, 2022 at 7:48 AM
    Corn
    Corn Well-Known Member
    NC
    00' Tacoma 4x4 ext. cab 3.4 ltr
    Fog lights, suspension, wheels
    This has been my question recently, and the rabbit holes only make it more convoluted. Someone has even posted a .pdf of a service announcement from Toyota about how to handle it, and then, the arguments still continue back and forth.
    A simple question though, in the end:
    2000 Tacoma with a 5 year old radiator with the red long life coolant.
    The thermostat was replaced and it looks like they didnt feel the need to add more coolant, so the reservoir is below L when cold.
    I'd like to fill it back up to between L and F like it has always been.
    Can I add the pink- prediluted Super Long Life to bring that level up a little? Which means mixing the two types.
    Or do I need to buy the red -long life and distilled water to top it off?
    Some say yes, the two types can be mixed, some say no it is forbidden to mix or else you'll destroy your engine.
    Just curious if anyone here has any legit real life experience with this.
    tacotoe likes this.
  16. Jan 23, 2022 at 7:55 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    :facepalm:this same thing with coolant in another brand of vehicle I drive....SUPPOSEDLY, mixing the old and new makes it turn into jelly...and not conducive to working effectively.
    I made sure to get the correct juice.
  17. Jan 23, 2022 at 8:15 AM
    Corn
    NC
    Yeah that was the info that was most troublesome. Even if adding 500mL? Crazy.
    tacotoe[QUOTED] likes this.
  18. Jan 23, 2022 at 9:38 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    That sounds like an artifact from the GM dexcool old wives tale era. That problem was due to gasket material and system air intrusion, and not related to the coolant. (Ford even spec'd dexcool for their own vehicles starting around 2010 but I think switched back to yellow (Zerex G05, a hybrid OAT formula) in 2019).
    If you are a detail-minded person, you can mix whatever coolants you want to mix if you do the research, but for 99% of vehicle owners it's just less brain stress to stick with the factory color/spec.
  19. Jan 23, 2022 at 8:06 PM
    Corn
    NC
    Well the LL and SLL have different chemicals, so, it's related to the coolant.
  20. Jan 23, 2022 at 8:20 PM
    Waasheem
    Waasheem
    2007 xrunner
    At work, the factory started using dexcool. Told us nothing about it, or the consequences of mixing. So a few engines got mucked up with cottage cheese goop.
    tacotoe likes this.
