Which cap seal should I grab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DenverMoto, Dec 14, 2023.
  1. Dec 14, 2023 at 10:30 PM
    DenverMoto
    DenverMoto [OP] Well-Known Member
    Paul
    Tan 1999 Tacoma SR5 Xtracab
    Bone stock so far!
    My truck: 1999 Tacoma Xtracab
    My new-to-me purchase: A.R.E CX Classic camper shell
    My question: I've never owned a camper shell before, but I'll be buying one second-hand very soon and I wanted to see if anyone could help me figure out which width of cap seal I should be buying. I emailed the company and they haven't replied, I tried calling their number and my calls won't go through. Do I go with 1.5' or 2"? I can't really find a good reference for how to tell which one I should get. Thanks for any guidance!
    here are pics of the shell I'll be buying.
    upload_2023-6-10_18-26-32.jpg Image 12-14-23 at 11.24 PM.jpg upload_2023-6-10_18-22-58.jpg
    voodoomaster33 likes this.
  2. Dec 14, 2023 at 10:34 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’ve gotten the stuff from Home Depot for sealing garage doors and it’s worked fine - far less expensive than “purpose made” products.
  3. Dec 14, 2023 at 10:35 PM
    DenverMoto
    Paul
    Bone stock so far!
    Fair enough, but my sole purpose for the shell is to make it into a little camper, to sleep in and hopefully stay relatively dry in through all kinds of Colorado weather. I don't mind paying a little more for something that might work better. In any case, I still have no idea which width would work best, was hoping maybe someone here would :D
  4. Dec 14, 2023 at 10:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It’s more about where and how you apply it than how much you pay for basically the same product. Take measurements and focus on where it’s leaking using a hose to stress test.
    Trandoshan-Tickler likes this.
  5. Dec 14, 2023 at 10:41 PM
    DenverMoto
    Paul
    Bone stock so far!
    I won't be able to measure anything on the shell until I pick it up next week. And I'm stuck working 12s until then so I won't have time to spend with the truck (which lives in my detached garage during my workweek), so I figured I'd lean on the folks here as surely I'm not the only person who's ever put an A.R.E shell on a 99 Taco.
  6. Dec 14, 2023 at 11:01 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can just use whatever until you get a chance to properly take a look at the most effective approach - I’ve put 3 camper shells on my truck and never needed an expensive product.
    The most doable part for now is to get pics from the seller and measure your bed rails - anything wider won’t be worth it as it’s only the pressure of the shell and the rails being clamped together that will make anything waterproof.
    Also check to see if there are uneven levels between the bedsides and front of the bed and places where water could go into the corners - that’s where the most likely places are to miss a spot. You can always put a dab of silicone / rtv if needed for places that won’t stop leaking or only leak in strong wind / rain.
  7. Dec 14, 2023 at 11:05 PM
    DenverMoto
    Paul
    Bone stock so far!
    I mean... on a camper shell that retailed for around $3000 new (I'm lucky enough to be grabbing it for a fraction of that) I don't think a $60 sealing kit to make sure I'm warm and dry is expensive or unreasonable. I'd rather buy it once and not have to worry about it, than buy several different kinds and waste money and effort there. But thanks for the input!
  8. Dec 14, 2023 at 11:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I get your concern. Been there myself. But it’s been several iterations of camper shells since then for me.
    You won’t have to get it the first time - it’s four bolts and just do one side or corner once you figure out what is leaking. Never had an issue I couldn’t address with Home Depot generic material so idk what an advantage would be of buying “purpose designed” stuff that’s probably the same thing.
    ztwatson likes this.
  9. Dec 15, 2023 at 5:28 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    https://amzn.to/3GKrQuU
    I went with this one. The company actually contacted me after they found my post talking about how I liked it on here and offered to send me a tailgate seal for free.
  10. Dec 15, 2023 at 7:55 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Aren’t the regular cab shells different than Xtracab? I’d look into that before you buy this if you haven’t because it will be a weird fit at the back window. I have no good suggestion for brand other than to expect some sort of leak. It seems rare to have a perfectly water proof seal with these things.
  11. Dec 15, 2023 at 7:56 AM
    Wanderlust Bus
    Wanderlust Bus Well-Known Member
    Small Lake City
    2002 TRD Off Road
    DenverMoto[OP] likes this.
  12. Dec 15, 2023 at 11:47 AM
    DenverMoto
    Paul
    Bone stock so far!
    Perfect - thank you so much. How are you liking the tailgate seal?
    Sweet - I'm glad to see a few folks using this brand.
  13. Dec 15, 2023 at 11:48 AM
    DenverMoto
    Paul
    Bone stock so far!
    Yes, the rear of my cab is sloped slightly different from the reg cabs, but it's not severe enough for me to care. There will be a small gap at the top, but for the price I'm paying, I don't care. It still fits where it counts.
  14. Dec 15, 2023 at 12:26 PM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I ordered an A.R.E. "V" for my 2023 Access Cab.
    I bought it from the same dealer that sold me the last cap for my '91 truck some 31 years ago.
    Delivery time is about 8 weeks, and ARE will paint it in Toyota 040 Ice Cap white to match my truck.
    I ordered it without side windows... here in CA that is one less thing to smash and grab.
  15. Dec 15, 2023 at 1:35 PM
    voodoomaster33
    voodoomaster33 VoodooMaster
    Dave
    Asheville NC
    02 Std Cab 5 spd 4WD Mystic Gold
    Lifted a little.........
    WHAT A FINE LOOKING MACHINE...... BEST COLOR EVER!
    Fast1 and DenverMoto[QUOTED][OP] like this.
  16. Dec 15, 2023 at 1:38 PM
    voodoomaster33
    Dave
    Asheville NC
    Denvermoto what tires are you using?
  17. Dec 15, 2023 at 1:47 PM
    DenverMoto
    Paul
    Bone stock so far!
    These came from Les Schwab Tire - Back Country AT/2. I'm super happy with them, they hook up real well and are surprisingly quiet on the road. I think they're manufactured by Dean tire, if I'm not wrong? But for the price, they're working great. IMG_4069.jpg IMG_4068.jpg
