Which brand of O2 sensor to buy
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jeremy Martin, Feb 2, 2021.
  1. Feb 2, 2021 at 8:14 PM
    Jeremy Martin
    Jeremy Martin [OP] Well-Known Member
    1st Gen Taco
    Bank 1 sensor 2 is bad on the Taco. It's the downstream and those seem to be a little cheaper but my local stealership still wants $155 for it. I usually try to go with OEM when I purchase sensors but this one seems a little steep for just an o2 sensor.
    Does anyone have any luck with Denso, Delphi or NTK sensors?
    Blaspheorion and Black DOG Lila like this.
  2. Feb 2, 2021 at 8:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Downstream isn't as critical as the upstream a/f sensor.
    Denso or NTK are both great choices for Tacoma.
  3. Feb 2, 2021 at 8:20 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    joe25rs, CS_AR and TWJLee like this.
  4. Feb 2, 2021 at 8:24 PM
    Jeremy Martin
    1st Gen Taco
  5. Feb 2, 2021 at 8:27 PM
    Black DOG Lila
    Virginia
    Have another keeper :D
    :thumbsup:
    http://japan-parts.eu/toyota/us
    Run your VIN# Toyota parts catalog
  6. Feb 2, 2021 at 8:35 PM
    Jeremy Martin
    1st Gen Taco
    Just placed the order $65 to my door from Rockauto for the Denso. Thanks all, I appreciate the help saving a little cash.
    Black DOG Lila likes this.
  7. Feb 2, 2021 at 9:32 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Denzo all the way. Almost no car likes aftermarket O2 sensors.
    Seagull233 and Black DOG Lila like this.
  8. Feb 5, 2021 at 6:56 PM
    SATX_Tacos
    SATX_Tacos Well-Known Member
    San Antonio
    '02 Tacoma TRD Pre-Runner
    Since yall are talking about sensors, would any of yall happen to know where the upstream air fuel sensor is located?
  9. Feb 5, 2021 at 7:17 PM
    Black DOG Lila
    Virginia
    At the top of exhaust pipe after Ypipe and before the 1st catalytic converter.
    SATX_Tacos[QUOTED] likes this.
  10. Feb 5, 2021 at 7:24 PM
    SATX_Tacos
    San Antonio
    Boom! Thank you!
  11. Feb 6, 2021 at 6:55 AM
    Blaspheorion
    Blaspheorion Member
    Gar
    Central Florida
    1997 tacoma
    Bully Liner paint job (color) burnt red Swapped 5vz-fe 3 inch fab tech lift Pro comp 5089 16" wheels No spacers yet
    I just did 5vzfe Swap on my 97 last week and yesterday light came in went and got it chked an came back p0141 bank 1 sensor 2 to be changed pretty sure i got same problem lol thanks for the parts site appreciate it
  12. Feb 6, 2021 at 8:02 AM
    Woodcutter
    Woodcutter Well-Known Member
    St. Petersburg Florida
    96 Taco 4 x 4 SR5
    Replaced these last year with Denso, purchased at Rockauto, for 1996 TACO. no problems with install, running well post-change. suggest you use the 02 removal tool, and spray sensors the evening before with PB rust blaster and sit overnight to soak in for easier removal in am before driving. install with some anti-seize for an easier time next time. https://duckduckgo.com/?t=ffnt&q=Chris+fix+install+02+sensor&iax=videos&ia=videos&iai=https://www.youtube.com/watch?v=CtngAVxJxkE good luck! Woodcutter
    CS_AR likes this.
