WHICH AIR BAG SUSPENSION KIT CAN I GET
Discussion in 'Street Trucks' started by Buga2wd, Jun 29, 2014.
  1. Jun 29, 2014 at 12:38 PM
    Buga2wd
    Buga2wd [OP] Active Member
    Miami,fl
    05 2wd tacoma
    Hello taco family I want to bag out my truck and I'm going to be doing all the work myself. But I need to buy the whole air bag suspension kit but don't know if there is a specific one that I have to buy or can I just buy a universal kit? Obviously do some custom work install them. Well if anyone has any info that they can give me would gladly appreciate it.
  2. Jun 29, 2014 at 3:35 PM
    ponchosportal
    ponchosportal Well-Known Member
    Kansas City
    2014 DC TRD TOW
    Tailgate reinforcement, mud-flap removal, weathertech floormats, Pop-N-Lock, ARK Power Pak, Bed-rail shovel mount, Hose-clamp tailgate, equalizer WD hitch, Firestone Ride Rite Air Bags w/Daystar cups,
  3. Jun 30, 2014 at 12:45 PM
    Buga2wd
    Miami,fl
    05 2wd tacoma
    Subd??? What's that lol
  4. Jun 30, 2014 at 12:50 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    he be scribin to yo thread......................baggin as in lowering or additional load handling?
  5. Jun 30, 2014 at 12:52 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Are you just talking about adding air bags to your current suspension?
    I used the Firestone RideRite kit, they are vehicle specific. Not sure what your truck is specifically, though, and if there is one available.
  6. Jun 30, 2014 at 4:43 PM
    Buga2wd
    Miami,fl
    05 2wd tacoma
    I get you he's just typing w.e to add it to his post statistics. But yeeaaa I'm trying to find out what air bag suspension kit can I use to lower and slam my truck. Would like to sit nice and flush on some 18s possibly lay frame.
  7. Jun 30, 2014 at 4:45 PM
    Buga2wd
    Miami,fl
    05 2wd tacoma
    I have 2005 tacoma regular cab and want to slam it on air bags. Sit flush with some 18s.
  8. Aug 7, 2014 at 1:12 PM
    black09
    black09 Well-Known Member
    chris
    elkton Maryland
    2009 black 2wd base
    4.5/ 5.5 drop color matched front bumper smoked tails frenched plate in tailgate shaved tailgate handle molded rollpan fogs suede headliner suede inserts in seats with headrests removed suede arm rest kenwood double din tv mtx 12" sub with 500 watt amp trd hood full billet grill setup
    im about to lay mine out there are a few ways you can go the front is tricky you can ether get a universal strut bag set up and hope it works or cut everything off that has to do with the struts and weld on a old school torsion set up and weld a plate on the stock lower control arm the rear is just like any other truck 3 or 4 link 2500 lb bags notches most bags setups are all universal just depends on which way you go with it
    mikeb14 likes this.
  9. Aug 8, 2014 at 11:12 PM
    Buga2wd
    Miami,fl
    05 2wd tacoma
    Yeeaaa I'm looking already ahead for a good company that sells good air bag kits and so it doesn't make a hole in my pocket.
  10. Aug 23, 2014 at 4:39 PM
    2000toyotatacoma
    2000toyotatacoma New Member
    Tony
    El Dorado, AR
    2000 Tacoma
    Pretty much build your own kit.
  11. Jan 13, 2019 at 7:32 PM
    4ondflr
    4ondflr Well-Known Member
    2002 Bagged Taco, 2013 Double Cab Daily
    Bagged, back half, sheet metal bed, custom paint, narrowed rear, 20’s
    Yea. To bag it all you really need are bag mounts in the front and do the ball joint flip. You won’t lay the frame flat unless you Z the frame in the front. Back is just whatever link kit you want. I suggest Thornton’s.com as Jason builds really nice stuff that doesn’t break the bank. I run a Slam Specialties manifold and MC.1 controller with 0 issues. Mine isn’t Z’d yet but will be doing a stock floor body drop so will be working the Z in with the BD.
    pinktaco808 likes this.
  12. Jan 14, 2019 at 8:30 AM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    I just pieced together my kit (not installed) and it cost me about $1200 for parts. I will still have to get the mounts welded.
  13. Jul 11, 2020 at 7:41 AM
    Chico@1230
    Chico@1230 New Member
    Jared
    Bagged Tacoma
    Airride dually conversion full custom stereo interior turbo engine
    I have bought a set of bolt in front cups for my 2003 Tacoma just like my s-10 the bolt into the top spring pocket and sits over the lower spring perch I got these cause the air struts are expensive af and I can run stock arms rear I’m fabricating a three link keeping it simple
