where's the tow converter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HarleyLee, Mar 3, 2017.
  1. Mar 3, 2017 at 8:09 PM
    HarleyLee
    HarleyLee [OP] Member
    Robin
    somewhere in the sunny South
    2010 Tacoma TRD Sport 4x4
    Replaced the 7 prong and got the 4 prong adapter...used a Hopkins (might regret wiring into it ...not sure yet). My trailer lights are not working right, really odd acting. After reading other posts, I've come to the conclusion it's probably the converter. I've done everything recommended....checked all the fuses and made sure the connection is good. Where is the tow converter located? Only had this truck a little over a year.
  2. Mar 3, 2017 at 9:18 PM
    HarleyLee
    Robin
    I have a fuse for tow(ing) converter ...I'd think it'd have to be on the truck somewhere
  3. Mar 3, 2017 at 9:21 PM
    medic2230
    Murph
    Bama! Roll Tide
    You talking about you bought the converter that plugs into the factory 7 pin and gives you a 4 pin connection?
  4. Mar 3, 2017 at 9:38 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    tow converter? the only converter is the one in the trd model bed. it has its own fuse. not to sure about what a tow converter is though.
  5. Mar 3, 2017 at 9:41 PM
    medic2230
    Murph
    Bama! Roll Tide
    I'm kind of thinking now she replaced the 7 pin on the truck with another connector with only 4 pins.
  6. Mar 3, 2017 at 9:43 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    maybe or she's talking about the junction block for the trailer lights under the bed
  7. Mar 3, 2017 at 9:50 PM
    medic2230
    Murph
    Bama! Roll Tide
    The wiring part has me confused. If you need 4 pin off of the 7 pin it's too easy to just use one of the plug in converters and be done. Less than $10.
  8. Mar 3, 2017 at 9:59 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    The functions for the wires in the factory harness are:
    White - Ground
    Red - Left Turn (will also come on with brakes)
    Brown - Right Turn (will also come on with brakes)
    Black - 12v (this is the constant hot wire it will only be on when the ignition is on)
    Blue - Electric Brake
    Yellow - Reverse Lights
    Green - Tail Lights
    HarleyLee[OP] and File IFR like this.
  9. Mar 3, 2017 at 9:59 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I know right. why would anyone wire in a 4 pin when you could just buy a plug
  10. Mar 3, 2017 at 10:00 PM
    medic2230
    Murph
    Bama! Roll Tide
    :notsure:
  11. Mar 3, 2017 at 10:19 PM
    HarleyLee
    Robin
    you guys got chasing rabbits... not even my question...
  12. Mar 3, 2017 at 10:20 PM
    medic2230
    Murph
    Bama! Roll Tide
    Well, if you rewired something then that could be the cause of the trailer lights not working. What are we missing?
    Guess we should start with, do you have the factory tow package?
  13. Mar 3, 2017 at 10:21 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    enlighten us
  14. Mar 3, 2017 at 10:39 PM
    HarleyLee
    Robin
    The 7 pin connector on was truck was bad... I put a new one on. Got the 4 pin adapter with it. I have it wired right. The lights when I hook it up to a trailer act all strange. That's why I was asking about the converter. I'll get it. So my terminally is not as perfect as yours...excuse me. Thanks and goodnight.
  15. Mar 3, 2017 at 10:45 PM
    medic2230
    Murph
    Bama! Roll Tide
    Well alrighty then. Sorry we didn't understand what you were trying to get at. Jake said above that the converter is located under the bed. No one said anything about your terminology. We were trying to help. Have a good night. :wave:
  16. Mar 3, 2017 at 11:10 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Seriously...you weren't clear...they asked questions....you got butt hurt...welcome to the Internet
    arthur106 likes this.
  17. Mar 3, 2017 at 11:13 PM
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down
    Hi there,
    As you have a TRD Sport, I assume you originally had a round 7 pin wiring connector. Just to be clear, what happened was that connector was replaced with another 7 pin connector (made by Hopkins) and you are now also using a 7 pin to 4 pin adapter? Please let us know if that is not right.
    I'm not trying to be picky, just that with wiring there a lot of places where something can go wrong so it's good to get all the details.
    Also, what are the odd things your trailer lights are doing? Sometimes working, sometimes not? Lights coming on when others where supposed to, or none supposed to?
    We''ll get it figured out together!
    HarleyLee[QUOTED][OP] likes this.
  18. Mar 3, 2017 at 11:47 PM
    Strxn
    Strxn Active Member
    PA
    '10 BSP DCSB 4x4
  19. Mar 4, 2017 at 3:49 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Get a test light. Check the prongs on the 7 pin to see if they're functioning correctly first. If they are, it's your 4 prong adapter. I've had a faulty one myself.
    If the 7 pin is indeed not working correctly, dig deeper.
    HarleyLee[OP] likes this.
  20. Mar 4, 2017 at 4:00 AM
    Fish12South
    Fish12South Well-Known Member
    Steven
    Ruther Glen, VA
    2008 Indigo Ink AC SR5 6 Speed V6
    Not Enough.
    Define acting strange. I've been selling hitches and trailers for 16 years. I can't guarantee it, being as it's electrical and we're trying to get it figured out over the Internet, but I'm pretty sure I can help you get it figured out.
