Where's my old woodruff key??????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoson2sdays, Jul 3, 2017.
  1. Jul 3, 2017 at 10:35 AM
    Tacoson2sdays
    Tacoson2sdays [OP] Member
    Corey
    Mississippi Gulf Coast
    2000 Taco 3rzfe
    My crank was spinning freely inside my harmonic balancer. I'm guessing the key got sheered off. How do I locate the key way on my crankshaft and get the old key out of it?? At a stand still. Any help is greatly appreciated!!!
  2. Jul 3, 2017 at 12:17 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    First, last time I did my timing belt, I did NOT pull my radiator, but seeing how much room you have, Kind of wish I would of.
    Secondly, your crank/pulley may now be garbage.
    I would get a scotchbrite and shine up that shaft, see if you can uncover its mysteries.
  3. Jul 3, 2017 at 12:21 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  4. Jul 3, 2017 at 12:50 PM
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    Were you able to find pieces of the woodruff key when you removed the pulley? That crank snout does not look good. I'm with greensystemsgo, try and cleanup the crank to see if you can find where the rest of the key is however I would also try and find the specs for the snout and measure it out, I fear it may be garbage now. In that case you're going to have to either repair it or replace, both of which would require the crank to come out...
    -chris
  5. Jul 3, 2017 at 12:54 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Try sandpaper or scotchbrite as previously mentioned. If that doesn't work try a mild acid to etch the snout and it may become easier to identify. Depending on how worn the snout is you could try a speedi-sleeve.
  6. Jul 3, 2017 at 1:00 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    The crankshaft snout is shot--simple check, measure the OD of the crank snout and the ID of the pulley. I think you will find the key and keyway were ground into into specks of rust. Age and/or an improperly torqued crank pulley bolt are the likely culprits; this was a common failing on the early 1.6 L Miatas if the bolt was not torqued correctly...
  7. Jul 3, 2017 at 1:11 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    It looks to me like this is where it was supposed to be judging by the square edges. :fingerscrossed::notsure:
    RacecarGuy and Greensystemsgo like this.
  8. Jul 3, 2017 at 6:16 PM
    Tacoson2sdays
    Corey
    2000 Taco 3rzfe
    At first I only had the radiator out. When I couldn't find the key way i pulled the ac condenser. Finally got aggravated enough to
    pull my bumper off. Glad I did.so much easier to work and not much effort to pull parts out of the way. Of course my ac leaks Freon so that didn't bother me opening lines up as they were empty and needed vacuums pulled anyway. My headlights are sanded buffed and baked open ready for paint tonight. I have a brand new front main seal, crank bolt, and balancer.
  9. Jul 3, 2017 at 6:20 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  10. Jul 3, 2017 at 7:40 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    busy busy, good to do it all now when your in, good deal.
  11. Jul 3, 2017 at 7:52 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The key should face upward when the #1 piston is at Top Dead Center (TDC) on the compression stroke. You can see that by orienting the little notch on the pulley with the TDC 0° mark on the oil pump housing. The key slot on the pulley should be on the top.
    Edit: It actually doesn't matter if it's the compression stroke or exhaust stroke. Key is up at TDC.
  12. Jul 4, 2017 at 5:04 AM
    christsay
    chris
    That's a good idea. Maybe a long wooden dowel through the spark plug hole as an indicator or is there some other way to tell if you're at TDC on this motor?
    -chris
    cruxofthebisquit likes this.
  13. Jul 4, 2017 at 5:41 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I'd blame it on the cat
  14. Jul 4, 2017 at 6:51 AM
    christsay
    chris
    You're right, looks very guilty.
    -chris
  15. Jul 4, 2017 at 7:23 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    crankshaft needs to be replaced, the spinning of the pulley after the key sheared has taken valuable metal away to insure a tight fit of the pulley on the shaft end.....huge bummer...
    wilcam47 likes this.
  16. Dec 3, 2018 at 6:03 PM
    Yota.Dies
    Yota.Dies Member
    Firstgen 2002 Tacoma prerunner 2wd 4door 3rzfe
    Yes it is yes it is SHARED with the timing chain gear sprocket
  17. Dec 3, 2018 at 6:08 PM
    Yota.Dies
    Yota.Dies Member
  18. Dec 3, 2018 at 6:18 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Good info
    It's been over a year, I'm sure OP has been dying in anticipation though :luvya::luvya::luvya::luvya::luvya::luvya:
    Running Board Man likes this.
  19. Dec 3, 2018 at 6:37 PM
    Yota.Dies
    Yota.Dies Member
    I'll give all I can to help another man so shall another man pass on to another and the cycle continue thanks for reading hope OP is all right
    Toyko Joe likes this.
  20. Dec 3, 2018 at 6:45 PM
    Yota.Dies
    Yota.Dies Member
    Mines been sitting for years apart so iam posting mine engine crankshaft soon pics will be coming in tomorrow....
