Where to mount my scan gauge II
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jstrenn, Aug 13, 2016.
  1. Aug 13, 2016 at 7:16 AM
    jstrenn
    jstrenn [OP] Member
    2007 Tacoma 4X4 TRD Sport
    I got a scan gauge II about a month ago because I tow and want to monitor my transmission temp. So far I like the gauge, does everything I want and more.
    Now to my question, where does everyone mount there scan gauge? I put it on top of the steering column right in front of the gauge cluster but it kind of blocks the lower part of the cluster. So I can't see if my cruise light is on or if my low oil press light would come on. (I know it's a Toyota, shouldn't have to worry about oil press. LOL) I have to sit up and look over the scan gauge to see the lower part of the cluster.
    Where do you mount your scan gauge??
  2. Aug 13, 2016 at 7:22 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    https://www.tacomaworld.com/threads/simple-scangauge-ii-mounting-mod.134888
    https://www.tacomaworld.com/threads/scangauge-ii-mounting.21026
    https://www.tacomaworld.com/threads/scan-gauge-mount.131336
  3. Aug 13, 2016 at 7:39 AM
    jstrenn
    jstrenn [OP] Member
    Thanks tomwil.... Now I feel dumb, I guess I could have done a search too! Anyway that is exactly the info I was looking for. I may try to mount above the rear view mirror like in a couple of the threads. Thanks again
  4. Aug 13, 2016 at 7:48 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Please don't feel dumb. You're new, and it takes a while to get experienced in using the TW search engine.
  5. Aug 13, 2016 at 9:17 AM
    atavuss
    atavuss Well-Known Member
    I used heavy duty Velcro and stuck my Scan Guage on top of the rear view mirror. The wiring is run under the edge of the headliner, super easy to do.
  6. Aug 13, 2016 at 9:36 AM
    mx355
    mx355 Well-Known Member
    Trent
    TX
    2020 Trd Pro
    Kings, Method 316, Nitto Ridge Grappler
    I did mine in my drop down sunglass holder. Never use the holders so drilled i small hole for wire to pass through, ran wire in headliner and down A Pillar. This way when you dont want to see it you close your holder, when you want to see it you flip it down.
  7. Aug 13, 2016 at 9:41 AM
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    I velcroed mine to the top of the steering column in front of the gauges. Easy to get wire ran to obdII port, easy to see and monitor gauges.
  8. Aug 13, 2016 at 10:26 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I bought a blend mount and mounted mine over the mirror.
  9. Aug 13, 2016 at 2:51 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
  10. Aug 13, 2016 at 7:48 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    Double sided tape on top of the steering column up against the gauge cluster.
  11. Aug 13, 2016 at 8:24 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Bottom left corner of the windshield.
    Have to move it annually to replace the sticker, but otherwise a great location.
  12. Aug 14, 2016 at 8:00 AM
    jstrenn
    jstrenn [OP] Member
    Thanks for all the tips... I went out this morning and velcroed it to the top of my rear view mirror. Ran the wire under the headliner along the windshield and down the A-piller under the cover with the grab handle. Super easy to do, just removed 2 screws that holds the grab handle and the cover comes right off. Ran the cable under the dash to the OBDII connector. Probably took 20 minutes tops!!
    I would have never thought of doing this without the help of this forum.
