Where to get rear axle shaft
Discussion in '1st Gen. Tacomas (1995-2004)' started by twblanset, Sep 12, 2018.
  1. Sep 12, 2018 at 10:17 AM
    twblanset
    twblanset [OP] Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    I need a rear axle shaft for a first gen electric locking rear end/ABS. I'm not positive what year it is, but I think it is a 2001. I bought the rear axle second hand and I can't remember the year but I think all the electric locker axle shafts are the same.
    I'm having a hard time finding one other than at the dealer (which is nearly $500). Low Range doesn't have them.
    Does anyone have one lying around they would sell me?
    Does anyone know where to get one?
    I've checked the recycle yards and they will only sell the whole rear axle.
    I'm located in CA between SF and Sac.
    Thanks
  2. Sep 12, 2018 at 10:23 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    The first thing you should do is find the VIN of the truck, then call your Toyota Parts dealer. Give him the VIN and ask him to tell you what year your truck is. That way, there will be no questions when you do your shopping.
    $500 sounds (to me, anyway) like an awful lot of money for a rear axle. When I bought a front axle for my TRD last December it was around $420 and included shipping (Genuine Toyota Part).
  3. Sep 12, 2018 at 10:36 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    since the axle was purchased 2nd hand, the VIN won't help...
    These are a few chromoly replacements I found just in a quick search: might be something to look into...
    http://www.trail-gear.com/product/4789/longfield-4340-chromoly-rear-tacoma-axle-shafts
    https://www.summitracing.com/parts/lsa-141042-1-kit/overview/make/toyota/model/tacoma
  4. Sep 12, 2018 at 10:49 AM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    The first one of those is for non-ABS. I've found those no problem. The second one doesn't list whether it is for ABS or not (which makes me think it's not).
    Thanks for the try though.
  5. Sep 12, 2018 at 11:59 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Does anybody know what the difference is? Can non ABS shafts be used and it just forces you to delete ABS or what? Or are they totally different?
  6. Sep 13, 2018 at 9:20 AM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    I know they aren't interchangeable, but I don't know why. I asked on an earlier thread and I was told that they would appear to fit and then they would fail (someone had tried it).
    E30325 likes this.
  7. Sep 13, 2018 at 6:27 PM
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    The ABS axles should have a longer shoulder to allow for the ring to be pressed on and then the oil seal. Not sure why they would fail if you tried using a non-abs unless the non-abs shaft didn't have enough shoulder to get the oil ring in the proper position.
    At some point there was a transition on the design of the bearing shoulder on the shaft where it transitioned from a square shoulder to a rounded one. My only info on this is from experience with my 99 (abs, non-locker) having a square shoulder and an 03 (abs, locker) having a rounded shoulder.
    Not sure if this can help but I used this axle as a replacement for my 99:
    https://www.rockauto.com/en/catalog/toyota,1999,tacoma,3.4l+v6,1357589,drivetrain,axle+shaft,10439
    I suppose if the measurements matched with what you have (lenght, spline count, ect) and you used the proper bearing for the shaft it should swap in without issue. This is just speculation of course, good luck with the search
  8. Aug 3, 2021 at 12:13 PM
    GillyMac
    GillyMac Well-Known Member
    Albert
    2004 White Tacoma Xtracab V6
    Does anyone know if/how the spline count differs?
  9. Aug 10, 2021 at 8:38 AM
    GillyMac
    Albert
    I found that the correct axle for my truck has 30 splines. My truck is an '04 3.4L 4x4, but I have an E-locker rear end from an '02 or '03 DC (according to previous owner).
  10. Aug 10, 2021 at 9:17 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    all e locker axles are 30 spline.
  11. Aug 10, 2021 at 9:20 AM
    GillyMac
    Albert
    Good to know, thank you! Do you know if that PN is 4231135350, or if there are any other PNs with 30 splines?
  12. Aug 10, 2021 at 9:21 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    The yukon chromos will work, but you need to use 95-00 wheel bearings.
    Been running them in my '01 elocker for years with no issues.
    Wulf likes this.
