Where to Find Windshield Molding
Discussion in '1st Gen. Tacomas (1995-2004)' started by zinx, Apr 6, 2024.
  1. Apr 6, 2024 at 8:50 AM
    zinx
    zinx [OP] Member
    hello, i am looking to replace my windshield on my 03 Tacoma and cant find any information on where i can get the black molding that goes around the windshield, looks to be discontinued. i have the part number 75531-04010 which is the cold climate spec molding but no luck finding it. is there any aftermarket equivalent that's reputable?
  2. Apr 7, 2024 at 4:39 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I have that gasket- OEM, I’ll part with, but I had an issue where Safelite said they couldn’t install it. Did you find an installer who said they’d install it on a new windshield?
    I have no doubt the people at Safelite were incompetent, but 2 separate places refused to use it, the second of which tried to explain why, basically stating it was over their heads
  3. Apr 7, 2024 at 4:48 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    The last 2 windshields installed on my Tacoma used a universal molding. Every Tacoma I've seen over the years with a replacement windshield has had the universal molding.
    What is the difference between cold climate and not?
    This shows as being the equivalent to that part # https://www.dkhardware.com/precisio...99-rc-windshield-molding-product-4892558.html
    If you purchase and use it during the windshield install, please post up. I will need to have my windshield replaced in the near future and might go with that OE style depending on feedback.
    Rpkrantz and ControlCar like this.
  4. Apr 8, 2024 at 7:46 AM
    zinx
    zinx [OP] Member
    that's interesting how no one would touch it, especially safelite. I've done a few windshields and plan on doing the install myself. The only issue i could see is installing those 2 little foam blocks at the bottom of the windshield.
  5. Apr 8, 2024 at 7:52 AM
    zinx
    zinx [OP] Member
    i don't know the exactly differences but both part numbers are discontinued. going to buy this today but probably wont install it until it gets a little warmer out.
    will do.
  6. Apr 8, 2024 at 8:09 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
  7. Apr 8, 2024 at 9:01 AM
    Gen1andDone
  8. Apr 8, 2024 at 9:08 AM
    Gen1andDone
    What are the details of the foam blocks? I've had 2 windshields installed on my 02, the first install was followed by rust forming within a couple years. The second was installed after the body shop took care of the rust and along with prep and paint. After that windshield install my dash rattles like crazy and the A pillar trim rubs....it now also has a half circle crack in the bottom corner. I need to find a competent installer, but also one that will do it like factory.
  9. Apr 8, 2024 at 9:29 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yes, it's more of a weather thing. It was more common on trucks bound for northern states but was also tacked on other trim levels/option packages.
    99 sales brochure
    [​IMG][/url]
  10. Apr 8, 2024 at 9:30 AM
    zinx
    zinx [OP] Member
    The only details i have about the foam blocks is that there are 2 different styles of them with separate part numbers being 56116-24010 & 56116-35030. I currently have 2 of each and part number 56116-35030 is taller and wider then 56116-24010. I believe its a similar story to the molding? ones specific to cold climate, but I'm not sure on that. Also something else I'm not sure on is how many you need, i bought 2 of each because my assumption is that you need 1 on each corner of the bottom of the windshield.
    I'm pretty sure i read a thread on here with a guy that had a similar issue to yours and the foam blocks were brung up.
  11. Apr 8, 2024 at 9:40 AM
    zinx
    zinx [OP] Member
    my response is above, forgot to quote.
  12. Apr 8, 2024 at 12:03 PM
    Gen1andDone
    I guess that is also not something that would necessarily be on window sticker either. Nothing like that is on my window sticker. I'll have to do a little more research to see how I might know if I also have the HD starter and wiper motor.
  13. Apr 9, 2024 at 9:04 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Optional equipment, second line.
  14. Apr 9, 2024 at 9:30 AM
    Gen1andDone
    Yeah, not listed on mine, but mine is an '02. Maybe it became standard? Or maybe just that molding became standard. The only part of it that I can say with 100% certainty that my truck came with, is the windshield molding w/rain channel. Not sure how to ID the rest of it.
    Edit- Starter part# comes back as cold spec.
  15. Apr 9, 2024 at 12:18 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Totally agree with this. There seems to be quite a bit of "overlap" with 1st gen option packages. For example, just try to nail down why some trucks got the heavy duty "green hub fan clutch" before the "Towing package" became a factory option in the later years.
