Where to find proper body clips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bigpat_ca, Oct 18, 2020.
  1. Oct 18, 2020 at 8:51 PM
    Bigpat_ca
    Bigpat_ca [OP] Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    Hey guys trying to find out the part numbers for the clips used to secure the plastic piece under the headlights on a 2014 2.5gen tacoma.
  2. Oct 18, 2020 at 8:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Oct 19, 2020 at 8:14 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I tried several sources for body clips. Amazon, AutoZoo, OReilly, AdvanceAuto.......
    Ended up at the local Toyota Dealer. Yes, they are more expensive, but they fit properly and only cost <$1.50 each.
    You Suck I Suck More likes this.
  4. Oct 20, 2020 at 6:33 PM
    Bigpat_ca
    Sacramento, CA
    Yeah, I’m ok with the dealership, but I would like to find a diagram to help figure out which ones I need.
  5. Oct 21, 2020 at 2:39 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The Amazon kit above looks like it has all you will ever need.
    I got a similar kit and found I only used the 8mm pins with 4 tabs that expand such as:
    https://www.amazon.com/gp/product/B07GN3S9NG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    They fit tightly so I push the 4 tab part in with the pin removed and push the pin in and if really tight use a small hammer to tap in. Used on the front bumper area, front fender liners, mud flaps etc. Get the tool to remove them makes it easier as a screwdriver always is a pain and really need to pull the pin on 2 sides.
    4x4cajun likes this.
  6. Oct 21, 2020 at 3:38 AM
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
  7. Oct 21, 2020 at 3:49 AM
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    Same. It's not like I'm buying 200 of them either. Only needed like 6 so the price is negligible if I know they'll work
  8. Sep 13, 2022 at 8:01 AM
    Joker8824
    Joker8824 Well-Known Member
    2014 MGM DCSB TRD Sport
    old post but did you find what you needed? I got one that comes loose on me daily and i have to pop it back in. Looks like one of those Christmas tree push in style but i cant find it on the Tacoma body diagrams
  9. Sep 13, 2022 at 8:08 AM
    YotaProject
    YotaProject Well-Known Member
    Adrian
    Charleston SC
    Fox Lifted 2007 Taco With Mods Here & There
    The green clip comes with the plastic trim. But you can use a door trim panel clip as a substitute.
    Joker8824[QUOTED] likes this.
