Where to find 2nd gen TRD Sport hood
Discussion in '2nd Gen. Tacomas (2005-2015)' started by the_black_tacoma, Mar 26, 2020.
  1. Mar 26, 2020 at 5:02 PM
    the_black_tacoma
    the_black_tacoma [OP] Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    Hey guys, I’ve looked around a bit and haven’t found a thread for this, so here goes.
    Wondering how/ where to get a (preferably black) TRD sport scooped hood. I’d like to swap it with my non-scooped hood. yes the only reason is that it would look better:D)
    Any advice much appreciated!
  2. Mar 26, 2020 at 5:17 PM
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
  3. Mar 26, 2020 at 6:50 PM
    the_black_tacoma
    Griffin
    IN
    A couple
  4. Mar 27, 2020 at 6:48 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    It'd be great, if you can ever find one, but hard to do. I checked for salvaged ones but for me, I never found one that didn't need some type of repair. Finally went to a local body shop, they got me a new OEM & painted & blended to match & installed. Not cheeeep, $1K to $1,200, but my search is over, & I've got what I want. Good luck.
    the_black_tacoma[OP] likes this.
  5. Mar 27, 2020 at 2:04 PM
    sceptre001
    sceptre001 Well-Known Member
    ATX
    2006 RC Prerunner 5MT, 2020 DCSB
    Don't know the seller. Good luck
  6. Mar 27, 2020 at 2:09 PM
    asudevil
    asudevil Well-Known Member
    From AZ to Central Texas/Waco
    06' TRD Off-Road w/ 15' front clip swap
    Wow good find!! Too bad I can't use it. Damn@
  7. Mar 27, 2020 at 2:11 PM
    sceptre001
    ATX
    Yea, if I did not do the 2012 conversion already on my truck, I'd be all over this.
  8. Mar 27, 2020 at 2:13 PM
    Bman562
    Bman562 Well-Known Member
    SoCal, CA
    2005 Radiant Red Tacoma Sport DCSB
    '12+ Facelift, TRD Baja Bilsteins, SCS Ray10's, K02's...
    Also consider trying offer-up, craigslist, dismantling shops, ebay motors, or you can try some generic brand, but i'm not too sure on fit.
  9. Mar 27, 2020 at 2:53 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    That add says SR5 hood with OEM hood scoop, I don't know what he has, but not that. You can't put an OEM hood scoop on an SR5 hood. You will need to get the "SPORT" hood, it's got to be stamped, or molded, for the scoop. I think my OEM hood with all parts needed for scoop was <$600, the rest was painting & blending. A good "SPORT" hood for $300 is a great deal anywhere.
  10. Feb 20, 2021 at 11:38 AM
    luka4600
    luka4600 Active Member
    Luka
    tofino Bc Canada
    06' 2.7 Turbo, 5 Speeed
    Eibach Pro truck lift, 33" Grabber atx, 4.88 Yukon Gears, custom turbo kit
  11. Feb 20, 2021 at 2:22 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    There's appx. 1/2 dozen more parts to finish the scoop opening. I'm not sure if they are available aftermarket or not, but if the got to come from a Toyota dealer they won't be cheap. Then it needs paint.
  12. Feb 21, 2021 at 12:00 PM
    luka4600
    Luka
    tofino Bc Canada
    Yes, but if u remember the scoop components block air from going through so if u wanted it to be somewhat functional and not just for looks no point in going to the dealership for all the components just put a small screen/grill to protect from debris and then ur not too far in cost wise. Now with paint it’s another story, it’s hard to colour match any second gen now cause the newest is 6 years old now and a colour match fresh coat will be different then a paint job that’s 6-16 years old you might aswell paint is a neutral colour like black or try and get it the same tone or shade as ur older faded paint, but still I think the price for that hoods a pretty good deal especially compared to what a dealership would charge for a oem one and better then a used one from a recker
  13. Feb 21, 2021 at 12:06 PM
    Wildbuckstudios
    Wildbuckstudios Member
    Daniel
    TSS blue/purple 4x4 2013 Tacoma
    this website sells it and will paint match your truck.
    https://www.partify.store/collectio...015-toyota-tacoma-hood?variant=30263418683477
  14. Feb 22, 2021 at 5:17 AM
    the_black_tacoma
    Griffin
    IN
    A couple
  15. Feb 22, 2021 at 5:40 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    I gave up on a scooped hood after following the 'swap' thread for a short while, when I first got my Taco. Checked locally, nada. If one turns up (reasonable) I'd take it, I can do the paint to match. Last I checked the wreckers (LKQ) they were running about $1000-1200, and like hens-teeth. May as well buy new. Eff that. Flat hood looking better all the time...:notsure:
    Island Cruiser likes this.
  16. Feb 22, 2021 at 5:51 AM
    Wildbuckstudios
    Daniel
    I don’t think they make one that is compatible all the way to 2005-2015, but here are the links:
    2012-2015
    https://www.partify.store/collectio...ucts/new-painted-2012-2015-toyota-tacoma-hood
    2005-2011
    https://m.theautopartsshop.com/sku/...FqlO2Vz9_G8mKbRBzeAQwKi_n_qnjWNBoCyHMQAvD_BwE
  17. Feb 22, 2021 at 6:42 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    A simple call to salvage yard got me a hood. LKQ website shows inventory, I didn’t worry about the color and just painted the entire front clip on the truck. Cost about 250 dollars total and I installed it myself. I did farm out the paint work but the truck look ok now
    Rick's 2012 and That one old guy like this.
  18. Feb 22, 2021 at 8:14 AM
    luka4600
    Luka
    tofino Bc Canada
  19. Feb 22, 2021 at 8:14 AM
    luka4600
    Luka
    tofino Bc Canada
  20. Feb 22, 2021 at 8:15 AM
    luka4600
    Luka
    tofino Bc Canada
    https://partify.ca/collections/2006...011-toyota-tacoma-hood?variant=34906417201315
    pretty good price here and they will paint it for you!
