Where to buy water pump and timing belt kits?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Him_Down_Stairs, Apr 27, 2022.
  1. Apr 27, 2022 at 9:22 AM
    Him_Down_Stairs
    Him_Down_Stairs [OP] Active Member
    "01" Tacoma SR5
    Where's the best place and most reasonable priced sites to find these kits?
  2. Apr 27, 2022 at 6:06 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    The AISIN kits are a couple hundred bucks +\- just Google it pick one and rock on
  3. Apr 27, 2022 at 7:51 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Here's the write-up I did on the job, and links to all the tools I bought (and where I bought them). Was a great investment from my POV since I've used them a few times, and it's nice to have them around when buddies need them. I've included links below as well for your convenience.
    The full write up: Step by Step Toyota Tacoma Timing Belt Replacement for 3.4L V6 5VZFE
    As you can imagine with a job like this, there are quite a few parts and tools you need to complete it quickly and safely! As it turns out, there are a couple of great resources that make this easier:
    You can buy most of the parts you need in a kit on eBay. There are several of them, but I went for the 100% OEM parts kit from aircabinman that contained the following parts:
    Quantity
    Part Manufacturer Part Number
    2 1 Timing Belt & 1 label Toyota 13568-69095/YZZ03
    1 Idler Roller NSK OE 13503-62040
    1 Tensioner Roller Koyo OE 13505-62070
    1 Front Crankshaft Seal Toyota/NOK OE 90311-40022
    2 Front Camshaft Seals Toyota/NOK OE 90311-38051
    1 Water Pump Aisin OE 16100-69398-83
    1 Water Pump Gasket Aisin 16271-62011
    1 Hydraulic Tensioner Toyota 13540-62021
    1 Thermostat (82°c) Toyota 90916-03075
    1 Thermostat Gasket Aisin 16325-62010
    1 Air Conditioning Belt Toyota 99364-20870
    1 Alternator Belt Toyota 90080-91090
    1 Power Steering Belt Toyota 90080-91126
    There are a few parts/supplies that you still need to pick up to complete the job and aren't included in the kit, so I picked them up as well:
    1. The crank pulley bolt, which Toyota says is a single-use bolt given the 217 ft-lbs of torque it's under while in service. (90119-16006). Note: I've reused this bolt before too, with no problem.
    2. Two gallons of red coolant concentrate, to refill the radiator when it's reinstalled. (00272-1LLAC)
    3. Two gallons of distilled water - again, for the radiator.
    Toyoda213 and sonofdad like this.
  4. Apr 27, 2022 at 7:52 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
  5. Apr 27, 2022 at 8:35 PM
    02hilux
    Planet: EARTH
    Rock auto trump Amazon. Ebay and Amazon sells a ton of knockoff.
    Or buy from Napa, they sell the Aisin kit.
  6. Apr 27, 2022 at 8:45 PM
    Superdave1.0
    SoCal
    Prove it pal. :D
  7. Apr 27, 2022 at 9:24 PM
    02hilux
    Planet: EARTH
  8. Apr 28, 2022 at 7:46 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    While in general I agree with you, aircabinman has a reputation for selling quality Toyota (or OEM manufacturer) parts to hundreds (thousands?) of TWers, so that's a safe seller when it comes to buying on eBay.
    Kiloyard and Him_Down_Stairs[OP] like this.
  9. Apr 28, 2022 at 9:58 AM
    yotadude520
    yotadude520 Well-Known Member
    Will
    The Dirty T
    1986 Toyota Land Cruiser
    OME Lift - FJ62 Axles - 33x10.50 BFGs
    Him_Down_Stairs[OP] likes this.
  10. Apr 28, 2022 at 6:58 PM
    Him_Down_Stairs
    "01" Tacoma SR5
    Thanks everyone
  11. Dec 24, 2022 at 2:47 PM
    man
    man Member
    Is there an equivalent kit or guide for 2016 tacoma 3.5L ?
  12. Dec 24, 2022 at 2:51 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It has been pre Covid but Ihave bought a few kits from Aircabinman on ebay.
    No problems
  13. Dec 24, 2022 at 3:37 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I’ve used timingbeltkit.com in the past, claim to be all OEM or equivalent Japanese manufacturers, I guess I’m unsure of the part’s authenticity at this point but never had issues and they’ve been around for years. A more complete kit, comes with crank/cam seals, thermostat and drive belts, but not cheap at over $300
