Where to attach anderson connectors for front and rear winch wiring?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tom_gunnison, Jun 1, 2020.
  1. Jun 1, 2020 at 11:18 AM
    tom_gunnison
    tom_gunnison [OP] Member
    2020 TRDOR
    I recently installed mobtowns front recovery bar with the intention of having a winch in a cradle and being able to use it in both the front and rear
    with that said I am getting ready to wire the front and rear with anderson quick connects, I was wondering if anybody has done this and if so where they have attached the anderson connections on the front and rear
    any pictures and suggestions would be welcome
  2. Sep 7, 2020 at 2:45 PM
    pugetdiver
    pugetdiver New Member
    2019 Tacoma Offroad
    There's no answer for this? I have the same question.
    James
  3. Sep 7, 2020 at 6:41 PM
    caribe makaira
    Caribbean, Puerto Rico
    From Googling...
    Grossomotto likes this.
  4. Sep 7, 2020 at 6:51 PM
    caribe makaira
  5. Sep 8, 2020 at 1:12 AM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    I installed a heavy duty (high amperage) marine bus bar off of the X2 deep cycle battery to run all of my accessories. One pair of 4 ga leads off of the bus bar has an SB 175 connector. I replaced the alligator clips on the winch with another SB 175 connector. The winch will only be attached to the battery when it is in use, so I didn't see any reason to add a switch. The connectors also have dust shields, so this will prevent a short at the connector.
    To power the winch when it is in the rear hitch, I use a 4 ga, 25' set of jumper cables. I replaced the alligator clips with two SB 175 connectors, so it can connect to the bus bar and various accessories: winch, inverter, and a set of alligator clips. Because of these different applications, I decided not to mount the cables permanently to the truck. This gives me more flexibility on how and where I used the cable.In hindsight, the only thing I would have done differently is use 2 ga cables.
  6. Sep 8, 2020 at 8:10 AM
    caribe makaira
    And fix this:
    Also,is that a T-Fuse holder "repurposed"?
    therealprotaco and whatstcp like this.
  7. Sep 8, 2020 at 12:56 PM
    cactushead
    San Diego
    The bus bar is similar to this one:
    Attached to the front stud is the circuit breaker that came with my superwinch.
    The picture with the exposed cable was taken over two years ago when I was first setting it up. All of the wires were later protected with wire loom. But thanks for looking out for my safety!
