Where is the outdoor temperature sensor located?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ingot, May 25, 2019.
  1. May 25, 2019 at 5:41 PM
    ingot
    ingot [OP] Well-Known Member
    When driving, my dash reading always seems low by maybe 10-15 degrees.
    I only have about 200 miles on the truck so far, but my truck is parked in a garage, and the temperature readout does seem to be right for the garage temperature, but it seems to hold there for at least the first 5-10 minutes of driving. After that it goes up maybe 1 or 2 degrees, but not much beyond that when it should be 10-15 degrees higher for the outdoor temperature.
  2. May 25, 2019 at 6:53 PM
    caribe makaira
    Caribbean, Puerto Rico
    tvterry, AusBerg, bgavin and 5 others like this.
  3. May 25, 2019 at 7:19 PM
    ingot
    Thanks caribe. I figured I might at least inspect it and unplug-replug it to see if anything changes.
    In general do you all find the outside temperature reading in your dash display reflects the outside temp within seconds of hitting the road on a hot day, after parked in a relatively cool garage?
    Or is what I'm seeing common and there's a long lag time? I've driven mostly short trips so far (it's not a daily driver, it's just mainly for hauling fairly short distances) and maybe I just haven't run it long enough for it to reach true outdoor temperature?
  4. May 25, 2019 at 7:21 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    I have never timed it, but I would guess usually changed within 30 sec to a minute. Seems reasonable.
    Barsoom likes this.
  5. May 25, 2019 at 8:00 PM
    john221us
    john221us Well-Known Member
    Rocklin, CA (Sacramento)
    2019 Toyota Tacoma Limited
    Bed Mat
    I have noticed it takes 3 to 5 minutes to normalize, especially if it has been in the sun for a bit.
    Taco22trdor, GreyBaldTaco and bmsgolf like this.
  6. May 26, 2019 at 6:37 AM
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    Mine takes a couple minutes to adjust from garage temp to outside temp. I find it pretty accurate, usually within a degree or two (Celsius) of posted temps when driving around
    Tacosha, Tocamo, SH10151 and 2 others like this.
  7. May 26, 2019 at 6:53 AM
    ingot
    Thanks for the replies. I guess this says I do have an issue of some kind since mine is not behaving "normally." Not worth spending time at the dealer just for this, but eventually I'll have to have it looked at. I don't have a code reader but I wonder if any error codes might be readable (I dunno..."outside temp sensor intermittent" or something like that)?
  8. May 29, 2019 at 4:04 PM
    Gabtap
    Gabtap Well-Known Member
    2017 Black Offroad
    Just hit mine in car wash and will not update was stuck on75 for 15 minutes I’ve unplugged sensor and hit with some canned air. Now it won’t budge past 79. It’s current 98 outside. Outside of warranty period on my 17 by miles
  9. Jul 8, 2019 at 5:00 AM
    Biners
    Biners New Member
    2018 Magnetic Gray Metallic Tacoma TRD OR
    Mine is 10-12 degrees lower the the outside temp. I just noticed it happening this weekend. before this it was fairly close to actual temp
  10. Jul 8, 2019 at 5:05 AM
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    Mine has read a little to high since putting the Bamf recessed grill in.
  11. Sep 6, 2022 at 11:18 AM
    pseudonym
    pseudonym Well-Known Member
    Livermore, Ca.
    2018 SR5 AC 4x4 V6, 1997 FZJ80
    Anyone know if there's a resolution for this?
    Mine just started exhibiting this same behavior.
  12. Sep 6, 2022 at 2:12 PM
    erwigg
    erwigg Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    I had one read high when stuck in metro area rush hour traffic. once on a winter/snow boy scout camping trip I new it wasnt reading right and found ice and snow frozen on the sensor
  13. Jun 21, 2024 at 1:50 AM
    Andyshine77
    Andyshine77 Well-Known Member
    Andre
    23 OR/Lunar Rock.
    Bringing this old thread back.
    It was 95 today AC was struggling and the temperature on my display was stuck at 75 "garage temperature" for like an hour before it finally toped out at 85. The gauge was super accurate and fast until recently, now it takes forever to sense any change in temperature.
    Any good source for a quality temperature sensor? apparently the OEM a piece of junk, my truck is not even a year old yet.
  14. Jun 21, 2024 at 11:55 AM
    Andyshine77
    Andre
    23 OR/Lunar Rock.
    20240621_061310.jpg No worries I ordered a new one. 30 bucks, cheaper than spending a day at the dealership.
    jmneill, tvterry and MGMDesertTaco like this.
  15. Jun 21, 2024 at 12:25 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I am usually withing 2 deg F. Close enough.
    Andyshine77 likes this.
  16. Jun 21, 2024 at 12:34 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Let us know if that solves the problem. I'm having the same issue. I thought I was going crazy, thinking "there's no way it's been exactly 75 degrees out for the last two hours".
    Also what's the part number?
  17. Jun 21, 2024 at 12:54 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
  18. Jun 21, 2024 at 1:01 PM
    MGMDesertTaco
    Maybe I need a new one. It works, but it's delayed longer than it used to be when the truck was new.
  19. Jun 21, 2024 at 3:35 PM
    Andyshine77
    Andre
    23 OR/Lunar Rock.
  20. Jun 21, 2024 at 3:37 PM
    Andyshine77
    Andre
    23 OR/Lunar Rock.
    Yeah it should get up or down to the correct temperature in about 10 minutes, not two hours.
    MGMDesertTaco[QUOTED] likes this.
