Where is ignition coil #2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma414, Jun 5, 2015.
  1. Jun 5, 2015 at 5:47 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    So my truck threw a misfire code and said its coil #2, can someone please help me out on where that coil is on my 2006 Tacoma V6
    Thanks
  2. Jun 5, 2015 at 6:18 PM
    Tacoma414
    Cody
    Agua Dulce
    thats what i saw too, just wasn't sure if that was correct, it makes sense though
  3. Jun 5, 2015 at 6:23 PM
    Tacoma414
    Cody
    Agua Dulce
    Just put brand new plugs on 2k miles ago...they are from the dealer so they are pre gapped
  4. Jun 5, 2015 at 6:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    always good to check,
    And AFAIK the 1GR has a coil pack per plug, the coil is actual part of the assembly that attaches to the top of the sparkplug down in the cylinder head.
    the picture above is of the 5VZ-FE
    Yup just looked at the FSM.... one coil on plug pack per cylinder. (PM me if you want the full FSM and wiring diagrams)
  5. Jun 5, 2015 at 6:43 PM
    Tacoma414
    Cody
    Agua Dulce
    Yesh I know they have a coil per plug, I'm just trying to figure out what coil is #2
  6. Jun 5, 2015 at 6:52 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    The only way to know is to go ask a service tech at a stealer ship. I have looked and the info comes back as restricted. Otherwise rock lobster in the 626 909 thread may know.
    GL
  7. Jun 5, 2015 at 7:37 PM
    Tacoma414
    Cody
    Agua Dulce
    Ok I'll call Toyota tomorrow or local shops and see if they know thanks
  8. Jun 5, 2015 at 7:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This is the correct information as DoorDing posted above.
    DoorDing likes this.
  9. Jun 6, 2015 at 9:18 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  10. Jun 6, 2015 at 10:24 AM
    Tacoma414
    Cody
    Agua Dulce
    P0302 P0352
  11. Jun 6, 2015 at 10:54 AM
    Lester Lugnut
    May be responding with what you already know. Here goes:
    P0302 - Cyl #2 misfire
    P0352 - Ignition Coil B Primary/Secondary Circuit Malfunction
    Here's another layout that includes the Coil IDs and their location. As you can see - Cyl 2 lines up with Coil B. You can try changing the plug and turning off the code with your reader or scanner. If that fails next suspect will be coil, but since you are also pulling P0352(coil), I'd bet a buck you have a bad coil. I've experienced a number of combination codes on other Toyota engines like you are now(different cyls/coils) and it always ended up being the coil, especially when code P035x occurs - x = cyl #
    1GR-FE - 6 cyl engine
    Here's the plug/coil layout - Numbers represent cyl number; letters represent coil pack ID:
    Passenger side
    Cyl 1(A) - front of engine - Cyl 3(C) - middle - Cyl 5(E) - rear of engine
    Drivers side
    Cyl 2(B) - front of engine - Cyl 4(D) - middle - Cyl 6(F) - rear of engine
    Also Reference the following:
    http://www.toyotapart.com/ENGINE_BANK_1_AND_BANK_2_A_F_AND_02_IDENTIFICATION_T-EG034-07.pdf
  12. Jun 6, 2015 at 11:12 AM
    Tacoma414
    Cody
    Agua Dulce
    That helps a lot thanks! I'm going to try switching coils like 1 and 2 to see if that changes anything, if not I'll go grab a coil
  13. Jun 6, 2015 at 1:55 PM
    Tacoma414
    Cody
    Agua Dulce
    So I swapped coil #2 with #6 because it was easy to get too, reset the codes and drove it for about 10 mins at all different speeds, it is running great now
  14. Jun 6, 2015 at 1:59 PM
    Tacoma414
    Cody
    Agua Dulce
    Exactly, I'm going to pick up a new coil and if it does happen I'll swap it out
