Where is Fog light Fuse
Discussion in 'Technical Chat' started by Bobcat, Sep 18, 2009.
  1. Sep 18, 2009 at 10:58 AM
    Bobcat
    Bobcat [OP] Well-Known Member
    Montana
    From what I have read it is not in the fuse box but rather somewhere else. Anyone can quick let me know?
  2. Sep 18, 2009 at 11:06 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    foglight fuse is the one with the red wire on it, it is in the fuse box
    ps you will not have that wire unless you have done the fog light mod.
  3. Sep 18, 2009 at 11:51 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    Isn't that the relay? The fuse is in the fuse box, check the owner manual for position. I recently checked mine, and it is there, info in manual.
  4. Sep 18, 2009 at 11:58 AM
    Dark Knight
    Jeff
    NC/SC
    good point. I think your right that may just be the relay to tell the fogs when to turn on/off vs high/low beam etc. I bet if the OP pulls out the little compartment to the left of the steering wheel there may be a fog light fuse labeled on there
  5. Sep 21, 2009 at 9:09 AM
    Bobcat
    Montana
    So there is no inline fuse in the engine bay. I have read that on here.
  6. Sep 21, 2009 at 3:56 PM
    Warren Thompson
    Warren
    Elko, Nevada
    Yes there is. I checked it when I was working on my fog lights. I do not remember the position. It is in the back chapters of the owners manual. It will tell you. It is in the engine compartment fuse box.
  7. Sep 22, 2009 at 8:18 AM
    Bobcat
    Montana
    Thanks, I will check into that. I dont have the owners manual, but I can probably find the info somewhere.
  8. Mar 1, 2016 at 8:50 AM
    Tako9
    Tako9 Well-Known Member
    Gatineau, Québec
    07 Trd offroad access cab SWB
    Anyone know what size is the fuse for oem fogs?
  9. Mar 1, 2016 at 7:35 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    should be listed on the cover, I'm gonna go with 10 amp
  10. Mar 1, 2016 at 9:13 PM
    Tako9
    Gatineau, Québec
    Ok thanks I will try to double check...
