Where is Bank 1 Sensor 2 O2 Sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by freebird4446, Apr 5, 2019.
  1. Apr 5, 2019 at 6:07 PM
    freebird4446
    freebird4446 [OP] Well-Known Member
    Pete
    Boston, MA
    2003 3.4L V6 250k miles
    I have a check engine light with two errors. One was (PO305) which is a cylinder 5 misfire so I was going to swap ignition coils and replace my plugs to see what the problem is. Shouldn't be too bad.
    The other was a (P0136) HO2S-12 which reads as a Bank 1 Sensor 2 circuit malfunction. I got a new O2 sensor to replace the broken one, but I want to make sure I replace the correct O2 sensor. I was told at the Auto store it's the downstream sensor but want to make sure that's correct. Which side of the car is Bank 1 Sensor 2 and which end (front to back) is it? I think my Tacoma only has 2 O2 sensors and it's the sensor on the passenger side towards rear of the vehicle, but would appreciate someones advice.
  2. Apr 5, 2019 at 7:12 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You're V6 right? So bank 1 is driverside and sensor 2 is the downstream, after the cat convertor. Make sure to use Denso sensor. Amazon or rockauto are usually cheapest.
  3. Apr 5, 2019 at 7:52 PM
    freebird4446
    Pete
    Boston, MA
    Yep V6 3.4L. I ordered a Denso sensor from Napa. Just checked Rock Auto for prices and boy you are right. $92 at Napa, $51 at rock auto. Might have to return it for that price wow. I just bought rotors, calipers, and pads from Napa too, should've checked rock auto...didn't know they would be so different! Thanks for the heads up.
    cruiserguy likes this.
  4. Jan 8, 2020 at 8:51 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Just got the p0136. Happy happy joy joy.
  5. Jan 8, 2020 at 9:34 PM
    cruiserguy
    Elijah
    SEKS
    The downstream guy, you want the Denso one or the Denso made one with a Toyota logo on it in a Toyota box:D one of those two are the only one you want to uae
    QMEDJoe[QUOTED] likes this.
  6. Jan 9, 2020 at 7:17 AM
    QMEDJoe
    Joe
    Both of my cats are bad. I installed a URD O2 sensor simulator a couple of years back to clear a p0420 code and it did the job. I knew I have had an exhaust leak for sometime and just got around to the one closest to the downstream o2 sensor last week. As soon as I fixed that leak and test ran it, I could smell burning plastic. I looked around but couldn't come up with an answer, perhaps that sensor was used to a certain amount of oxygen getting by and now that I fixed the leak it burnt it up? I’m kind of reluctant on replacing that sensor being that my cats are bad. Could also be the URD sensor is no longer good? Also, a wire burnt up after fixing that leak? I’m going to go out there today with a multimeter and try and check for continuity and go from there.
