Where Can I find these wiring harness Connectors?
Discussion in 'Lighting' started by PreRunnerMan, Jan 8, 2016.
  1. Jan 8, 2016 at 9:21 AM
    PreRunnerMan
    PreRunnerMan [OP] Well-Known Member
    Alex
    SoCal, Whittier
    White 2010 PreRunner SR5
    ADS Coilovers LR UCAs Bilstein shocks in the rear Dakar Leaf Pack CMC 287/70/17 BFG K02s
    Where can I get these connectors? I bought a lightbar but I need to extend the wiring harness and wanted to make it a plug and play connection. Any one know where or have ideas on how to make a plug and play connection?
  2. Jan 8, 2016 at 11:13 AM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
  3. Jan 8, 2016 at 11:38 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
  4. Jan 8, 2016 at 11:41 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    That's the inside of housing with the pins.
  5. Jan 8, 2016 at 12:40 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    it has to do with the crimp end of the connector and the tool you need to have. you will need a special tool to correctly crimp those terminals.
  6. Jan 8, 2016 at 12:43 PM
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    Or, you could cut the wires before the connectors and add length to the harness (using a similar insulation/heatshrink and some waterproof tape at the splices.)
    http://www.amazon.com/14mm-Black-Wi...845&sr=8-2&keywords=pvc+wire+harness+covering
    http://www.amazon.com/gp/product/B001B1AP3O?psc=1&redirect=true&ref_=oh_aui_search_detailpage
    (Edit: material links added)
  7. Jan 8, 2016 at 12:44 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
  8. Jan 8, 2016 at 12:49 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    add that's probably easiest and cheapest way to do it... but i needed a good excuse for a new tool - i make my own custom harnesses with those connectors. lol
    Tacomatwo[QUOTED] likes this.
  9. Jan 8, 2016 at 1:25 PM
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    New tools: A universally good goal.
  10. Jan 9, 2016 at 10:32 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    I bought and use this kit for all wiring. Pricey, but worth it if you do a lot and make your own harnesses. If you run out of anything in the kit you can buy additional separately.
    Delphi Weatherpack Kit-1104 Pcs with Crimp Tool https://www.amazon.com/dp/B005AZWPUI/ref=cm_sw_r_awd_yQFKwbT2ST9FZ
    Edit: And there's cheaper kits with less in it. There's a 405 piece kit I think for under $100, but doesn't come with the crimp tool. Super easy to use and the crimp quality is awesome. Wires never pull out on me. Plus the plastic connectors are pretty great too. I've had those deutch connectors get brittle and break on me. Plus theyr are a pita to take apart if needing to remove the connector. Might be easier if they have a tool for that, Idk. I just like these better.
  11. Jan 11, 2016 at 7:06 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Great thanks for the replies, Sorry it took so long to get back on here, I have been preparing for a job interview this weekend.
  12. Jan 11, 2016 at 7:12 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    If those are from a light bar they are most likely stamped. The solids are the way to go, but they are more expensive, not only the connectors but the tools as well. The housings are all the same.
