Where can i find these ball joint spacers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huckshot, Apr 11, 2018.
  1. Apr 11, 2018 at 4:39 PM
    Huckshot
    Huckshot [OP] Well-Known Member
    Jared
    2000 tacoma 3.4v6 auto 4x4
    3" coil lift spacer in front. 2" block spacers in rear. 6lug to 5 lug adapters. 20" tundra rims with 33" mt tires
    After putting a coil spacer lift on i want to put these bj spacers on to fix the angle.i know many think its not ideal and will say to just get new ucas but im not looking for that route. Can anyone send me a link to buy them?
    Here is a post on here showing them.unfortunately its from 2 years ago..the pic is of his post and shows the arrow pointing to the spacer im looking for.
    https://www.tacomaworld.com/threads/help-01-tacoma-newb-suspension-help.454424/
    Sperrunner likes this.
  2. Apr 11, 2018 at 4:54 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Those spacers are only designed to be used with a drop bracket lift, one that involves hacking off the suspension crossmember. You CANNOT install that spacer without moving the lower control arm mounts lower. It would be physically impossible. Even if it was possible, you would never be able to align the truck.
  3. Apr 11, 2018 at 5:08 PM
    Huckshot
    Jared
    From what ive seen people have used them on tacomas like mine to bring the upper control arm angle back up instead of binding the ball joint just like the bolt up bj spacers that screw to the uca(but mine are stock without screw holes,just press in ball joints).am i missing something on this? Do you know where to get them?
  4. Apr 11, 2018 at 5:15 PM
    Huckshot
    Jared
    This is my angle. My tires rub really bad cause the guy before thought putting 5 lug adapters with non offset 20" rims and 33s..so i need the uca spacer to bring it back above the tires and to stop the rubbing and to stop the spindle from hitting the coil spring
  5. Apr 11, 2018 at 5:17 PM
    Huckshot
    Jared
    The coil spacer i installed
  6. Apr 11, 2018 at 5:32 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Oh man..... look at your poor CV axles. I would pull the block and try to lower your truck a bit, buy some spacers for your wheels or just get different wheels.
    Kinda looks like your stacking lifts, depending on what setting your Billy's are set on, You might lower the lift and lose the blocks. Those balljoint spacers are pretty sketchy, I would steer clear. Aftermarkter UCA's would help with your balljoint angle.
    Brice, onakat, User Name01 and 2 others like this.
  7. Apr 11, 2018 at 5:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I mean if yor trying to be cheap on your lift just get ebay ucas, Proably bettery then ball joint spacers
    Brice and j_sav115 like this.
  8. Apr 11, 2018 at 5:43 PM
    Huckshot
    Jared
    I plan to drop the front diff soon. And yes different regular 6 lug rims also and tossing the adapters. I dont want it to sit lower i just want the ucas to be more straight and above the tires
  9. Apr 11, 2018 at 5:45 PM
    Huckshot
    Jared
    They are pretty bad..i havnt drove the truck alot since the lift and chomping at the bits to drive it
  10. Apr 11, 2018 at 5:45 PM
    JKO1998
    Utah
    The only diff drop thatll help your Cv's is a Drop Bracket lift. Lowering would help your truck ride better, work better, and probably handle better.
    But I guess it is your truck, do what you want.
  11. Apr 11, 2018 at 5:47 PM
    JKO1998
    Utah
  12. Apr 11, 2018 at 5:53 PM
    Huckshot
    Jared
    Thi king about 3" spacers and longer bolts should drop it enough
  13. Apr 11, 2018 at 5:56 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Poor CV’s :eek:
    JKO1998 likes this.
  14. Apr 11, 2018 at 6:00 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just convert to 2wd and then You can have all the angle u want and not worry about cvs lol
    JKO1998 likes this.
  15. Apr 11, 2018 at 6:02 PM
    JKO1998
    Utah
    Why don’t you just get different wheels and some aftermarket Ucas (Jba, light racing, are some cheaper ones). Probably be easier/safer.
    And then I guess just say F your Cv’s cause you don’t wanna lower it.
  16. Apr 11, 2018 at 6:09 PM
    Huckshot
    Jared
    I want to keep it 4x4 but i may have to adjust the bilsteins for now to lower it till i can drop the diff
  17. Apr 11, 2018 at 6:10 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Are your cv boots torn already? There looks like there is alot of oil down there
  18. Apr 11, 2018 at 6:13 PM
    Huckshot
    Jared
    The boot dislocated after the spacer install.havnt cleaned it up since i reclamped them
  19. Apr 11, 2018 at 6:19 PM
    JKO1998
    Utah
    It’s tore.
    arctic04trd likes this.
  20. Apr 11, 2018 at 6:22 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Your CV angle is the worst ive ever seen...why would anyone do that to a truck? You must get some funny looks driving down the road
