Where can I buy these Baja Designs fog lights?
Discussion in 'General Tacoma Talk' started by PapasTacoMia, Dec 24, 2024.
  1. Dec 24, 2024 at 5:01 PM
    PapasTacoMia
    PapasTacoMia [OP] Member
    Collin
    2019 TRD OR
    Hey guys, I was wondering where I can buy authentic first gen Baja Designs Squadron SAE fog lights. I tried looking online and found a few sites but I can’t verify if they’re legit. I also debated getting the second gens but didn’t like their short light output and the fact you apparently can’t switch out the lens between amber and clear compared to the first gens. Lastly, should I not even worry about the BD fog lights and just get the Diode Dynamics SS3 fog lights instead? I really like the first gen BD fogs, but at this point I’m wondering if I should just settle with some DD fogs since I can’t seem to find the first gen BD. Thanks for your help.
  2. Dec 24, 2024 at 5:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    They're a vendor here in the forum, have you reached out to them?
  3. Dec 24, 2024 at 5:06 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I’ve not had the Baja fogs, but can say that the diode fog lights are awesome. I personally like the color of selective yellow and their ‘max’ trim ones are seriously bright.
    Like I could use them as headlights and they’d be an upgrade to oem.
    Stuck in VT and PapasTacoMia[OP] like this.
  4. Dec 24, 2024 at 5:07 PM
    PapasTacoMia
    Collin
    2019 TRD OR
    I haven’t actually. I wasn’t aware they were on here. Thanks for letting me know
    Kwikvette[QUOTED] likes this.
  5. Dec 24, 2024 at 5:10 PM
    MGMDesertTaco
  6. Dec 25, 2024 at 7:38 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i'm pretty sure that neither of those facts are accurate.
    on the last part, baja's site has replacement 'clear', 'baja amber', and 'factory amber' lenses available here
    https://www.bajadesigns.com/products/?page=1&cat1=lighting-lenses
    main point that baja has made is that the o-ring must always be replaced with any lense, because the old o-ring will deform enough that re-use can cause an imperfect seal.
  7. Dec 30, 2024 at 10:54 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey PapasTacoMia,
    Technically, you can't swap lenses on either model. The issue lies in the possibility of the optics shifting, which could cause misalignment and result in a non-street-legal pattern. That said, our Gen 2 SAE significantly improved over the previous generation. While you can still swap lenses, they must be sent to our HQ for replacement. However, if you choose our Sport version, swapping lenses is no problem at all. If you have any questions, feel free to reach out directly at brahianh@bajadesigns.com.
    Best,
    Brahian Herrera | Forum Sales & Support
    Email: brahianh@bajadesigns.com | Phone: (760) 560-2252
    TRD10 likes this.
  8. Dec 31, 2024 at 5:09 AM
    soundman98
    NW Indiana
    i'm wondering if it's a matter of a different need though.
    did the change to the gen 2 sae pattern make for less overall beam reach?
  9. Jan 6, 2025 at 1:20 PM
    Baja Designs
    San Marcos, CA
    Gen 2 increases output has a sharper cutoff and is significantly better than Gen 1. If you need a fog light with a sharp cutoff and wish for it to be street legal, the SAE is the best route to go. If you wish for a light with more vertical and horizontal spill, our off-road version would be ideal, but it is not for on-road use.
    Best,
    Brahian Herrera| Forum Sales & Support
