When to use 4D and 2L?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 97lt1ta, Jan 1, 2013.
  1. Jan 1, 2013 at 5:23 PM
    97lt1ta
    97lt1ta [OP] Well-Known Member
    Las Vegas
    07 prerunner
    I've been searching for trying to figure out the right time to use 4d and 2L on a 2wd prerunner. I'm very new to the off road scene and like to know the ins and outs of how to drive it properly with out getting stuck cause I was in the wrong gear. I'm mainly use too hooking up on a paved track then mud and dirt and that's if I don't break the rear end and make it all the way down the track lol
  2. Jan 1, 2013 at 5:36 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The selection of gears in the auto only determines the highest gear the truck will shift up to
  3. Jan 1, 2013 at 5:43 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    This.
    Also, there's not a 4D or 2L. There's a D, a 4, a 3, a 2, and an L.
    SR-71A likes this.
  4. Jan 1, 2013 at 5:50 PM
    97lt1ta
    Las Vegas
    07 prerunner
    Gotcha that makes more sense so basically in mudding you'd want to be in 4 and if you get in a bit of a pinch shift to L cause that locks the rear dif ?
  5. Jan 1, 2013 at 5:54 PM
    97lt1ta
    Las Vegas
    07 prerunner
    Sorry if this sounds like I'm a complete idiot. I just know when I started building a drag/ still street car I made a few mistakes on the track and the parts and bought my truck as a daily plus some mud/ trailing fun
  6. Jan 1, 2013 at 5:57 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    L does not lock the rear diff. The Rear Diff lock button locks the rear diff if equipped.
  7. Jan 1, 2013 at 5:58 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The gear selection has nothing to do with the locker function... Your auto transmission has 5 gears. Selecting anything lower than D only allows the truck to shift as high as that gear, that's it. The locker, if you have one, is operated completely separately.
    Actually, I see the truck with the hood scoop in your avatar so that leads me to believe you have a TRD Sport. If that's the case, you do not have a rear diff locker. You have a mechanical limited slip rear diff, it is not selectable.
  8. Jan 1, 2013 at 5:59 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Your rear diff will only be locked if you have a Trd offroad, and choose to lock it. It's not dependent on the gear. I would stick to first gear (L as in Low), for 90% of offroad driving. Unless its high speed of course.
  9. Jan 1, 2013 at 6:01 PM
    97lt1ta
    Las Vegas
    07 prerunner
    Thanks guys sorry for the rookie question
  10. Mar 2, 2019 at 6:40 AM
    NEKyota
    NEKyota Member
    Tobias
    Northeast Kingdom VT
    2010 Tacoma TRD Sport
    Bacame badass when I bought it.. well.. a little more badass..
    I know this is an old thread but in my experience shifting from D to 4 does actually alter rpms and shift points.. see for yourself.. find a speed where D is maintaining 1100-1300 rpms.. I find it more obvious at slow speeds just chugging along.. then knock it into 4.. you will find it jump up a couple hundred rpms.. experiencing this proved to ME it does more than just limit its top gear..
    GrandTheftAngel and tcBob like this.
  11. Mar 2, 2019 at 9:09 AM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    No, youre simply just changing from OD to 4th. These trucks aren’t magic, if you lock out OD all you’re doing is locking out OD
  12. Mar 2, 2019 at 9:12 AM
    NEKyota
    NEKyota Member
    Tobias
    Not at 35 mph.
  13. Mar 2, 2019 at 9:57 AM
    Newfiebruh
    Tom
    Yes, count the number of gear changes it’ll shift to a very high gear so that you get better fuel economy
  14. Mar 2, 2019 at 12:57 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I can’t believe somebody doesn’t know how to drive an automatic transmission. Thought I’ve seen it all
    eherlihy, Newfiebruh and dustin19d like this.
  15. Mar 2, 2019 at 1:03 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It proves that it does exactly what you said it doesn’t. The RPM increases because you just told the transmission to shift no higher than 4th gear while it was in overdrive so it downshifted.
    dustin19d and Bebop like this.
  16. Mar 2, 2019 at 1:07 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
  17. Dec 21, 2020 at 8:10 PM
    NEKyota
    NEKyota Member
    Tobias
    You guys are funny. All heady. Decreasing speed by coasting in the 30 mile an hour range.. shift into 4.. slow dip and suddenly an increase in rpm. I know my truck isn't hanging in the highest gear when at that speed range.. because I'm aware my truck already downshifted to be in a usable range for needed torque when asked. And next time, like the headies do, don't make people feel uneducated and like an idiot for posting their thoughts/experiences.. the above rpm changes happen even when I'm driving constantly at 35-40.. once I shift.. it all changes and moves up in rpms.. no way my truck is running its highest gear at 35-40.. but ok. I'll be the idiot this time..
  18. Dec 21, 2020 at 8:14 PM
    medic2230
    Murph
    Bama! Roll Tide
    I usually use 4D when I have 3 passengers with me.
    Haven’t been able to use 2L since my 1st gen with manual hubs.
  19. Dec 21, 2020 at 8:14 PM
    OZ-T
    Peter North
    British Columbia
    A year and a half later...
    where you been bro ?
    EdinCincinnati likes this.
  20. Dec 21, 2020 at 8:16 PM
    medic2230
    Murph
    Bama! Roll Tide
