When to replace water pump and timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cullen2x4, Feb 8, 2018.
  1. Feb 8, 2018 at 6:45 AM
    Cullen2x4
    Cullen2x4 [OP] Member
    Cullen
    1998 Toyota Tacoma Pre Runner
    Ive heard a lot of different answers on this one. What is yall's recommendation on when to change and about what the cost would be if you were to do it yourself?
  2. Feb 8, 2018 at 6:50 AM
    tony2018
    tony2018 Well-Known Member
    If you just bought it and have no clue when the PO did it, do it
    If you haven't been following intervals, do it
    If you have to ask, do it
    jackn7 likes this.
  3. Feb 8, 2018 at 6:56 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    It is recommended at 90,000 or 100,000 and or 10 years, whichever comes first. I did mine at 120,000 and 16 years old, and it was still okay, but pushing it - the belt looked a little dry rotted with small cracks in it, so I would not recommend stretching it out that long.
    I had it done at the dealer so I don't know what it would cost to do it yourself - certainly only a fraction of the $1,200 I paid. I had all the other belts, radiator hoses, thermostat, waterpump, idler pullies and some main oil seal that was down there replaced at the same time. Still, labor was the majority of the cost.
  4. Feb 8, 2018 at 7:16 AM
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    Agree with above ^
    I would not do it any later than 100k miles. If the water pump is leaking prior to 100K, do them both then.
    Just did mine along with water pump for the cost of the kit and coolant ($250-ish).
    Super easy with a manual tranny, no special tools needed.
  5. Feb 8, 2018 at 7:31 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Right here is the answer. I did it at 112K miles, and 14 years. The belts were o.k., but the water pump was on it's way out.
  6. Feb 8, 2018 at 8:53 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I did mine for tha first time in 2012. Truck had 206,000. Belt was fine, but the water pump was on its way out. I wouldn't suggest going that long.......
  7. Feb 8, 2018 at 9:07 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Water pumps usually start leaking out the weep hole or the bearings will squeal. Giving you advance warning.
    Take the fan belts off and feel for play in the bearing. You'll get an idea if the end is near.
  8. Feb 8, 2018 at 10:05 AM
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    Did mine immediately after buying my truck at 200k as well. Belt looked ok and given how well the previous owner took care of the truck it might have been a little tempting to assume it had been done, but since I didn't have any conclusive service records, I wasn't about to roll the dice with winter coming up.
  9. Feb 8, 2018 at 2:55 PM
    Garwood
    Garwood Well-Known Member
    Pensacola, FL
    2002 TRDOR Xtra Cab 5spd MT
    Can you share where you got the kit from? Last I checked the cheapest was $300, and I think it was missing a few things.
    *Edit: Nevermind I see some now that are pretty close to that.
  10. Feb 8, 2018 at 2:59 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    You should definitely replace the water pump when doing it, leak or no leak.
  11. Feb 8, 2018 at 3:05 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I think that all applies to 3.4l engine. I have 2.7 so timing belt does not apply. And because my water pump does not leak, bearing don't squeal so I'm not touching it. 318k miles and 23 years now. Damn, this engine is so good.
    Taco302 and otis24 like this.
  12. Feb 8, 2018 at 3:26 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Mine was done when I bought the truck at 130,000 miles...not sure about before that.
    After 90,000 more miles I replaced it again at 220,000 miles. I think I spent about $380 for all OEM stuff. My AC condensor grenaded itself so I replaced all the AC components while I was at. Total for both was $900 and took 13 hours.
