WHEN TO CHANGE MANUAL TRANSMISSION FLUID
Discussion in '1st Gen. Tacomas (1995-2004)' started by swoagman, Mar 25, 2012.
  1. Mar 25, 2012 at 2:31 PM
    swoagman
    swoagman [OP] Member
    pa
    toyota tacoma manual 1996
    I HAVE A 1996 TOYOTA TACOMA SHOULD I USE GL-4 OR GL-5 GEAR OIL FOR THE MANUAL TRANSMISSION FLUID AND HOW OFTEN SHOULD IT BE CHANGED
    THANK YOU
  2. Mar 25, 2012 at 4:46 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Get which ever you want, they both will work.
    Think the manual says change every 30k ,do yourself a favor and change your front/rear diff and transfercase all at once that way you know when you did each last.
  3. Mar 25, 2012 at 4:48 PM
    jets
    jets Active Member
    805, CA
    2018 TRD OR DCSB
    All the researching I have done has led me to believe gl4 is the way to go. Most people on here suggest the redline mt90 oil for the manual transmissions.
  4. Mar 25, 2012 at 5:03 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Why caps?
    HarborSeal likes this.
  5. Mar 25, 2012 at 5:22 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    BECAUSE IT'S IMPORTANT!!! :D
    TooMuchToDo likes this.
  6. Mar 25, 2012 at 6:09 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    manual say to check (not change) every 30k. if you put a quality synthetic in and just daily drive it, you could go 60k if you wanted.
  7. Mar 25, 2012 at 7:38 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    well, if you have just gotten the truck, and you have the ability, I believe its best to try to change all the fluids as you can, and keep a record of it so you will know.
    the advantage of using redline or any good synthetic is that is more durable, it will make a difference shifting, esp. when its cold. Amsoil is great, I have used it with others in the past, and you can go to their web site, put your trucks info in and make a cheat sheet for all the lubrication's the truck takes.
    I have spent the day doing the clutch master cylinder, and the slave rebuild, and flushing them out, thanks again everyone here with the write-up because judging from what came out its the first time its been changed.
  8. Mar 26, 2012 at 7:12 AM
    swoagman
    pa
    Thank you all for your input, it really helped....SWOAGMAN
  9. Mar 26, 2012 at 9:17 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I use amsoil severe gear and will change every 60k.
    I am coming up on 60k and I am going to try redline mt90 this time. The amsoil made the shifting a bit notchy.
    1997tacomav6 likes this.
  10. Mar 26, 2012 at 9:46 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Tacofart likes this.
  11. Dec 12, 2013 at 5:13 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    can someone tell me how many quarts for the transmission and how many for the transfer?
    please feel free to flame me, providing you also supply the answer;
    i knew at one point; but, i'm having trouble finding it now... getting impatient
  12. Dec 12, 2013 at 5:33 AM
    flatblack
    CDA
    why, sure, i'll help you out, moron!
    Transmission = 2.35 quarts
    Transfer Case = 1.1 quarts
    put Redline MT-90 in both and make sure you torque the drain and fills to 27lbs
    NEWB!!
  13. Dec 12, 2013 at 5:39 AM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Gl-5 gear oil eats brass synchros, so keep it out of your trans. Very hard to find non-GL5 fluid locally. You have to buy redine mt90 or go to your Toyota dealer and strictly buy Manual trans fluid.
    I got a case of 5 quarts of redline off Amazon, cost me like $60 though. Gl-5 is very good for your differentials though, and it's safe to put in the t-case, as there are no synchros.
  14. Dec 12, 2013 at 6:19 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    I ran Redline Shockproof Lightweight in my MR2 trans (E153) and it was great. I switched to Amsoil recently only because I sell it so I wanted to try it out. It doesn't seem to be too much different, but Shockproof tends to coat everything and stick for a while so it may take a bit for any change to be noticed. I wouldn't hesitate to go back to Shockproof. A lot of MR2 guys run MT90 as well.
    So, if for some reason you can't find MT90, I'd try Amsoil or maybe Shockproof. I should change the diffs/trans fluid in my truck, too..
    halo07 likes this.
  15. Dec 12, 2013 at 6:08 PM
    Tmiller3063
    Tmiller3063 Active Member
    04 Prerunner Limited
    Stick with oem fluid.
  16. Dec 12, 2013 at 8:38 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Owner's Manuals and Warranty & Maintenance Guides are available for download from the Toyota Owners' Web Site.
    I recommend opening the FILL plug on each component BEFORE you remove the drain plugs. That way, you KNOW you'll be able to re-fill what you drain...
    You should also get the correct replacement crush washers for the job. They're NOT all the same.
    +1 for Amsoil. I'm very happy with their Severe Gear 75W-90.
    Jaysjammin and Mlcompound like this.
  17. Dec 12, 2013 at 9:06 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    You should use GL-4 because it is safe for the synchros. Modern GL-5 is "supposed" to be safe for synchros, yet it still has a higher concentration of the extreme pressure additives that are bad for synchros. Amsoil makes a GL-4 manual transmission fluid. Redline MT90 is also a GL-4 oil. I don't know what the maintenance schedule is, but I do it every 50,000 miles. Easy to remember that way.
    Napa Auto stocks Amsoil GL-4 manual transmission fluid where I live.
  18. Dec 12, 2013 at 9:53 PM
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    If anyone can't find it locally, let me know and I can probably get it to you at retail without any shipping charges.
  19. Dec 13, 2013 at 7:03 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You can always fill through the shifters if you have a manual. Not sure about an auto though.
  20. Dec 13, 2013 at 9:45 AM
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Trans, front diff, and rear diff? ;)
    DaveInDenver likes this.
