When Should My Front Side Marker Lights Come On?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Honorius, May 12, 2020.
  1. May 12, 2020 at 7:29 PM
    Honorius
    Honorius [OP] Member
    2005 Speedway Blue X-Runner
    Bought a used Tacoma, the front side marker lights do not come on at all, I cycled through all the light cycles and the hazard lights, but neither will light up. Before I start troubleshooting, when should they be on and when should they be off?
    edit: 2005 and the amber light on the edge of the truck, not the turn signal light that melts the housing and not the actual headlight bulb.
  2. May 12, 2020 at 7:33 PM
    Bishop84
    Bishop84 Well-Known Member
    First off, which year?
    Secondly, do you mean the amber bulbs on the inside near the grill? or the small amber outside nearest the fender.
  3. May 12, 2020 at 7:36 PM
    Honorius
  4. May 12, 2020 at 7:41 PM
    Bishop84
    The corner markers come on with the tail lights. They are small 194 peanut bulbs.
  5. May 12, 2020 at 8:07 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This may aid you in your quest. The lamps are labeled as Parking Lights on the print. If the tail lights are working then these parking lamps should also be on.
  6. May 13, 2020 at 3:57 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    What @Bishop84 & @Jimmyh said. should come on with first click/turn of the headlight switch on the stalk.
